Featured ITM hydrogen station
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Nov 3, 2016.
  1. bwilson4web
    15,513
    I have issues with this but here it is:
    As someone who has put 1 and 1.5 kW inverters in two Prius, I have a big problem with the claim that the Mirai is configured to supply house power. I don't believe it but welcome credible source that it exists in the North American, USA model Prius/Mirai or any others.
  2. Trollbait
    11,512
    The 2016 Mirai's didn't have it, but it is suppose to be an option once the inverters become available state(California) side. It uses the same system that plug ins in Japan use to power homes. A CHAdeMO plug is used to connect the car to a power station(which also acts as the EVSE for a plug in) installed at the home. It might be like a hard wired generator, with switch over in a power loss being automatic.
    The CHAdeMO PTD is in the Mirai's trunk.
    Which I guess means you have to have it all in your garage or car port, if you don't want to risk rain in your trunk.
    49,397
    it never rains in california...
  4. Trollbait
    11,512
    how about Japan?
  5. bisco
    49,397
    good question. of course, if you leave your trunk open outside in cali, you might not have a battery when you come out in the morning.
    mrbigh likes this.
  6. Trollbait
    11,512
    It's a FCEV. They'll take the fuel cells for the platinum.
  7. bwilson4web
    15,513
    Ok, guess we'll just have to treat it as Gen-1 Mirai.
    Of course the thieves will drill a hole in the H{2} tank while smoking a cigarette:
    telmo744 likes this.
  8. Trollbait
    11,512
    That would make for some good youtube viewing. Don't even need an ignition source when the tank pressure is at 10,000psi.
