iTouch generation 1 stops playing
Discussion in 'Gen 3 Prius Audio and Electronics' started by heintzmeister, Apr 16, 2010.
  1. heintzmeister
    heintzmeister New Member
    california
    My itouch 32gb version one ipod stops playing after a couple of songs in succession. First the meta data dissappears then it stops playing. If you turn off the car and restart it will play again for couple songs then stop again. I have a 2010 Prius III with the Factory USB interface (mounted in the center console) with the NAV option. The dealer isn't aware of any bulletins to address this issue. The itouch works fine in my other car. I've tried two different Apple cables just to make sure the cable wasn't the issue. Any idea's?? :(
  2. LakePrius
    LakePrius Special member
    99
    Nevada
    Sort of sounds like the USB is powering down (at least that's what the symptoms sound like). If you have a passenger keep an eye on the iTouch, can s/he tell if the thing thinks it isn't getting power, and thus shuts down? (I don't know what to do if that is the case - but at least you might have somewhere to start to look).
  3. heintzmeister
    california
    I took it in to the dealer today and the tech thinks it MIGHT possibly be the head unit so they have ordered it. I'll see if this actually corrects the problem or not.
  4. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I've had instances with my iPod video (gen 5?) whereby it will be playing, stop all of a sudden and then come back and say "USB not recognized" or something to that effect. It's been sporadic at best, so I've left it alone as I typically listen to XM. I'll be interested to hear your outcome.
  5. visualfx
    visualfx Junior Member
    New York
    I am currently having the same issue with my 3rd gen Prius IV. Any response from the dealer? Did they come up with fix for you?
  6. chuckc192000
    chuckc192000 Junior Member
    44
    Technically, there's no such thing as an "iTouch". The official name is "iPod Touch".
