It's all coming together...
Discussion in 'Gen 2 Prius Main Forum' started by yunebug, Jul 17, 2008.
  1. yunebug
    yunebug Gas Guzzler
    162
    Long Beach, CA
    1. = Fog lights only
    2. = Shark fin antenna
    3. = Ceramic tint
    4. = Scion TC Wheels + General Exclaim UHP 215/45/17
    5. = EV mode
    Hopefully, HID projector retrofitting is next. :0)
  2. 4G63
    4G63 I quit boosting
    147
    Aurora, IL
    nice looking! a drop would make it perfect.
  3. yunebug
    yunebug Gas Guzzler
    162
    Long Beach, CA
    Ahhh, the 4G63. I miss my DSM sometimes. :0) That turbo spooling sound and the BOV whoosh are not something one forgets easily.
  4. rigormortis
    rigormortis Active Member
    1,340
    24
    san jose, ca
    did you get a ticket yet for your front tints?
  5. yunebug
    yunebug Gas Guzzler
    162
    Long Beach, CA
    Not yet.
    *knock* *knock*
  6. SparrowHawk60
    SparrowHawk60 Happy to be green!
    411
    Town of Newburgh, NY, U.S.of A.
    Yunebug your Car looks great, I really like the way the rims look! Scion rims, hun? Good fit, with the right off set? 17", any clearance problems?
    Any way you can post a link or explain how to get the fog lights to work independently from the light switch?
    I can use a general guide, like where to tap into the wires at what fuse, relay, things like that. Doesn't have to be to technical for me.
    Thank you for your post, time and effort.
  7. yunebug
    yunebug Gas Guzzler
    162
    Long Beach, CA
    I followed Darrell's guide, of course.
    Fog lights
  8. JRMurray
    JRMurray Magnetic Gray is the only way!
    Surrey, BC, Canada
    Wow! Looks great!
    Let us all know if your fuel consumption is affected at all by your new tires & rims...
  9. 4G63
    147
    Aurora, IL
    haha tell me about it.. and the thing i miss the most... the speed! but we've chosen to do the right thing u know.. we decided to go green! :thumb: and save gas of course
  10. F8L
    19,011
    4,050
    50
    Grass Valley, CA.
    It's not a question of if, it's how much. lol
    Everyone that has installed the Scion wheels has noticed a large MPG drop. If they claim otherwise I would seriously question their measuring practices. :) They are simply too heavy not to induce a negative change and that doesn't even take into consideration the weight of the tires or their increased roling resistance.
    Car looks good man. :)
  11. yunebug
    yunebug Gas Guzzler
    162
    Long Beach, CA
    Thanks for the replies. :0)
    I wonder how much of the driver input is associated with the actual drop in MPG? I, of course, had the urge and a short burst of the lead foot after these were put on. The better traction and handling makes me *want* to drive it more aggressively.
    There is no question that there is a drop in MPG. Simply because they are heavier and wider than the stock. But let's look at the numbers:
    Prius stock 15" wheels - 14 lbs each
    Goodyear Integrity 185/65/15 tires - 17 lbs each
    Tire Specs for Goodyear Integrity
    Total weight per wheel = 31 lbs
    Scion stock 17' wheels - 21 lbs each
    ScionLife View topic - OFFICIAL 2008 Scion tC coupe stock wheel weight
    General Exclaim UHP 215/45/17 tires - 18 lbs each
    Tire Specs for General Exclaim UHP
    Total weight per wheel = 39 lbs
    We're talking an increase of 8 pounds per wheel, 32 pounds all around in rotational mass. I do not quite know for sure how the unsprung weight differs from the onboard (spring supported) weight, but 32 pounds isn't much in onboard weight (two 16 lbs bowling balls).
    Could the Scion TC wheels and new tires really have that drastic reduction in MPG? I think the blame (for the lack of a better word) goes to the driver.
    I'm also being negligent of the wider tires (185mm vs 215mm), but even with rolling resistance factored in, I think the negative fluctuations in MPG is more significantly attributed to the driver.
    I'm driving very conservatively. We'll see what happens to my MPG. :0)
  12. edthefox5
    edthefox5 Senior Member
    7,415
    3,145
    Clearwater, Florida
    That color looks like it would be invisible at dusk.
  13. F8L
    19,011
    4,050
    50
    Grass Valley, CA.
    Having tested this myself numerous times I conclude it is not the driver, at least not in my case. :). It is the actual weight and rolling resistance increase that causes the drop in MPG. Keep in mine that I own a set of 17" Centerlines w/ Kumho Ecstas 215/45/17 (combo = 37lbs). I've tried my best to justify using them but the last 3 times I've swapped them onto the car and tried to drive normal and even hypermile, I end up with consistantly 4-6mpg less than I do with the Integritys in similar weather and routes. :(
    I'm not trying to take away from your car or your post. Someone asked and I wanted them to know that there is indeed a consequence to upgrading to heavier wheel/tire combos. :)
  14. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,965
    Fort Lee, NJ
    I have the same experience as F8L. I have a lighter rim but UHP summer tires. They look awesome but I can't stealth that long as the speed drops quicker. Accelerating on battery power is slower and I can not enjoy over 50+mpg as I get less. I am now on stock rim with Nokian I3s.
    Once in a while when I want to change the look, I put 17" back on just for the show and handling.
  15. yunebug
    yunebug Gas Guzzler
    162
    Long Beach, CA
    Ah. The veterans speak . :) The MPG is definitely scientific, I guess.
    The handling is definitely better, though. It's nice to confidently turn those corners. :)
  16. usbseawolf2000
    14,487
    2,965
    Fort Lee, NJ
  17. F8L
    19,011
    4,050
    50
    Grass Valley, CA.
    I can't argue that! Handling is a lot better with the 17"s. :)
  18. ForTheGlory
    ForTheGlory New Member
    296
    Maryland
    Keep in mind that adding 32 pounds of wheel weight is much different than putting two bowling balls in the cargo area. With the wheels a great majority of the weight is away from the hub, thus the rotational inertia of the wheel is greatly increased. Since they also have a larger diameter than the stock wheels, the extra mass is moved even farther away from center.
    It certainly won't knock 25% off of your mpg, but a noticeable loss is assured.
Loading...
