It's easy to knock down MPG in prius
Discussion in 'Gen 3 Prius Fuel Economy' started by Former Member 68813, Aug 30, 2014.
  1. Former Member 68813
    3,524
    981
    US
    I went to dealership to have oil change and new tires, 5.5 miles one way trip, 53 MPG.
    Came back same way, 43 MPG.
    What changed:
    New tires, same size, supposedly LRR (continental purecontact ecoplus), but not as good as the stock and worn out Ecopias, of course.
    Dealer pumped the tires to 36 PSI, I had 44/42 PSI.
    New oil, 0W20 according to the receipt.
    The HV was only 3 bars, they "idled" it a lot.
  2. fuzzy1
    10,170
    Is there an elevation change between your home and the shop? That would add to the discrepancy.
  3. Okinawa
    Okinawa Senior Member
    1,333
    317
    The number of red lights you have to stop at makes a difference as well. Real MPG killers.
  4. Former Member 68813
    3,524
    981
    US
    Right, I didn't control for that.
  5. bwilson4web
    15,524
    Actually I thought the OP was sharing how anytime you take a Prius into a Toyota shop, regardless of the mileage going in, the car will be returned with the mileage wiped out. I don't think the service staff even notices it.
  6. edwardob
    edwardob Member
    227
    33
    ireland
    new tyres will take couple weeks to break in properly.... might will be reduced
  7. bisco
    49,500
    you really need to compare a few tankfuls to your prior lifetime average.
  8. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    After you break in those new tires your mileage should normalize. I am curious how those tires compare to the stock ecopias. Is there more or less road noise?
  9. Mendel Leisk
    38,728
    Lots of idling, plus maybe a leadfoot test drive will do it. Plus the tires, plus the pressure, plus...
  10. lester williams
    227
    68
    mississippi
    Please keep us updated on the Continental Eco-Pure tires, if things level out, as G/F will need a set of tires by late fall. We have monsoon season in Jan. and Feb., these would be good here.. thanks
  11. John Bergendahl
    102
    17
    gulfport,ms
    Lester what part of MS are you in?
  12. lester williams
    227
    68
    mississippi
    South/central,,, between Mendenhall and Magee-- in the woods.
  13. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Get those tires back up to 42/40 or more... that's a big bite there....
