It's fall...where's the heat??
Discussion in 'Newbie Forum' started by hypnogirl, Sep 19, 2008.
  1. hypnogirl
    hypnogirl New Member
    wisconsin
    Ok..now you know how really lame I am!!!
    I found the a/c in the middle of summer. Now, where is the heat??
    Someone please explain.
    :confused:
  2. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Ha ha! Just set the temperature higher instead of lower. :)
    Some people like to use the "climate" screen, but I love the auto settings. Hit the "auto a/c" button on the steering wheel and then bump up the temperature with the temp+ button.
  3. Jiipa
    Jiipa MGySgt USMC (Ret)
    314
    Oahu, Hawaii
    Although I've never had to use the heater in any of my cars since I moved to Hawaii :D, I assume that you just leave the A/C on and raise the temperature.
  4. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    You can still use 'auto ac', just bump up the temperature to where it's comfortable. You can use either the touchscreen or the steering wheel buttons. The term 'air conditioning' means more than just cooling - the Prius has a full climate control system that reguates temperature, humidity, and airflow. You can set it and forget it, or fine tune the settings to your heart's content.
  5. wchardin
    wchardin Senior Member
    2,055
    Nashville, TN
    Does anyone else turn off the A/C when they are using the heat?
  6. Ichabod
    1,794
    Newton, MA
    And if you have the voice-recognition feature, you can hit the voice button and then say the temperature you want: "73 degrees" and the car responds, "setting temperature to 73 degrees."
    As for turning off "a/c" in response to the above question, I never do. The climate control system regulates use of the compressor to control temperature and humidity, so I take the "set it and forget it" approach too.
  7. dropkin
    dropkin Junior Member
    New York
    the temps here are just on the border of needing heat in the morning. It looks liek there is some 20 degree difference where the AC really shuts down and the heat turns on when AC is engaged. So, for now, I shut down the AC button on the console. I'm hoping that come winter time, it will be a set-it and forget-it scenario.
  8. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    Huh? the A/C is the Heat.
  9. wchardin
    2,055
    Nashville, TN
    The a/c button at the bottom left of the screen, you can turn it off and the heat can still run through the air conditioning system.
  10. realale
    realale Junior Member
    94
    St. Louis
    That's what I've been doing on cool mornings. I like the windows down even if it's quite cool, but can't stand the idea of running the A/C with the windows down.
    I will add that it took me a while to figure out how to turn the heat on as well. I've never had a car with auto climate control before.
  11. richard schumacher
    7,663
    1,038
    United States
    Remember that "A/C" = "air conditioner", not "air chiller". Conditioning includes heating and de-humidifying. So just set the temp higher and wait a minute or two. Study the Owner's Manual and experiment with the "Climate" screen on the Multi-Function Display and all should become clear.
