I've got my prime and I like it a lot.
Discussion in 'Prime Main Forum (2017-2022)' started by Waterobert, Jan 1, 2018.
  1. Waterobert
    Waterobert Junior Member
    33
    39
    Laguna Niguel California
    On the third day off the ownership I am still very satisfied with the vehicle. My last car was Toyota Highlander, so I do miss the power and acceleration off my last vehicle, however Prius doesn't disappoint in that regard. It has just enough for my needs.
    One thing I am a little wary is about is electric drive range. My first full charge gave me only 19.9 miles, second a little over 20 miles and this morning I got 21.1 miles. With each charge I am getting more, however still far away from advertised 25 miles. Temperature in my garage is about 68 F, so not that cold. Did I get bad battery? Anyway I still love that car.
    farmecologist likes this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    did you make a mistake when you filled out your profile? You said your last car was a Toyota Highlander. So do you have a 2012 PIP or a Prime?
  3. priuscatprimeguy
    2,730
    2,640
    The faster you drive (expressway driving at 70 MPH) will give you lower EV range on the guess-o-meter. driving 35 45 MPH will give you the higher EV range of about 30 36 miles EV on the guess-o-meter
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I don't think you have anything to worry about. The numbers will come as you learn how to drive the car. Keep in mind that "full" tank (gas and electricity) from the dealer may not be so full. Check & set the tire pressure and take a look at the fluids. Enjoy.
    priuscatprimeguy likes this.
  5. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    There seemed to be a break in period for mine. Range grew over the 1st month or so to almost 40. But cold weather has affected it now. I know you don't deal with that in Calif. Keep driving...it will grow.
  6. Waterobert
    33
    39
    You are right I did something wrong. Thank you for letting me know, will fix it ASAP.
  7. Waterobert
    33
    39
    Sounds good, perhaps Toyota placed some kind off safety limit.
    Is it worth to buy additional charging unit/cable? I looked on line and prices are from $300-1000. Will 15A unit charge my Prime any faster? Prime's charger uses only 12A.
  8. priuscatprimeguy
    2,730
    2,640
    The EVSE doesn't determine charging rate the charger inside the car determines the charging rate.
  9. Waterobert
    33
    39
    Right, so unless I go to 220V I will always have to wait about 5 hrs for full charge.
    bisco and priuscatprimeguy like this.
  10. priuscatprimeguy
    2,730
    2,640
    correct:D
  11. priuscatprimeguy
    2,730
    2,640
    there's also a setting in the MID where you can set the charging rate to 8 amps, that's if your house wiring has an issue with 12 amps tripping the breaker:D
  12. JasonG
    JasonG Member
    71
    50
    San Francisco, CA
    Actually, a 220V charger will charge the battery in about 2 hours 20 min vs. over 5 1/2 hours for 110V. However, if you only charge overnight that is not much of an issue and not worth the extra $ for to install a 220V.
  13. Waterobert
    33
    39
    In my single car garage I have only one outlet and it is 120V. Getting 220V would probably will cost few hundred $.
    My work commute is 11 miles one way, so I am good with charging overnight. I might talk my employer into installing charger. I will be the second employee with electric car.
    huskers, bisco and priuscatprimeguy like this.
  14. bwilson4web
    15,561
    Electric dryer socket? They are 240VAC.
    Montgomery likes this.
  15. bisco
    49,694
    speed, stops and starts, acceleration, hvac use and weather will effect your ev miles. measure your distance as you drive, and compare it to the estimator.
  16. Waterobert
    33
    39
    My fourth charge gave me 22 miles, so in few days I should get 25 miles.
    Montgomery and bisco like this.
  17. bisco
    49,694
    with that thought process, i should have been up to a couple hundred by now.:p
  18. DavidA
    2,328
    1,812
    Chicago western burbs
    Remember, your actual miles traveled in EV aren't affected by the estimated guess-o-meter's displayed number. Actual EV miles very due to cruising speeds, terrain, temperature, driving habits, non-driving parking duration (in days), headwinds, weight load in the car, Earth's direction of spin, calories consumed at breakfast, what day of the week it is, etc., etc.
    Took about ten charges to get the meter up to 31+. Been going down since the thermometer can't raise as high lately.
    Congrats on the new car!
  19. Waterobert
    33
    39
    Thank you for the good news. This morning meter gave me 22.6, so slowly with each charge it's going up !
  20. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    It’s just averaging. But since it is settling (going up) so slowly, I would say that you won’t reach 25 miles with your current driving habits. What are your eco scores usually? What’s your commute like? The most important thing with evs are speed, AC, and if you are stopping smoothly. You might have to adjust your driving style to see any dramatic improvement.
