  1. 1F7
    1F7 Junior Member
    Massachusetts
    These approaches for jacking and supporting the prius have been previously mentioned on priuschat, but it's been convenient to put them all together.
    To lift any corner of the prius with a floor jack:
    Cut a hockey puck in half and epoxy the two halves 1/2-inch apart to a round metal plate which fits in the lifting cup of a floor jack. Then fit the welded vertical metal of any prius side jacking point into the groove between the two puck halves, and lift. This puts no weight on the vertical piece and all the weight on the horizontal unibody without any scratching.
    To support the front with two jackstands:
    Cut two hockey pucks in half and fit the two halves 1/2-inch apart on the top of each jack stand. I just epoxied them to the jackstand top, but something removable could be done also.
    To jack the front without driving the car tires onto blocks:
    An American Forge AFF 200T floor jack will reach the center front jacking point. I'm sure other long and low jacks that can do this too.
    When I rotate tires, I do front-to-back and back-crossed-to-front, so it's convenient have all four wheels off the ground. I jack the front at the center front jacking point, lower it onto jack stands on the two front side jacking points, then jack the back at the center back jacking point. If I'm going underneath the back, I have two big wood blocks to support the back corners, but I don't bother with this for just tire rotation.
    So nothing original here, but I'm pleased with this approach and perhaps someone else will find it useful.
    Bill
    Jaby Glides likes this.
  2. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    That's technically the way everyone's *supposed* to deal with
    pinch welds at the bottom of the rocker panels, but a lot of
    garage guys don't care and just slam the lift pads right onto
    the metal edges. Occasionally they'll insert a piece of 2x4
    but that doesn't transfer the load to the actual bulk of the
    subframe like should be done.
    _H*
    Fostel likes this.
  3. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Excellent tip. Thanks!
