JBL Audio problem
Discussion in 'Gen 2 Prius Main Forum' started by elmofongo, Jun 1, 2008.
  1. elmofongo
    elmofongo Member
    256
    SF, CA
    Greetings,
    I have a 2006 Prius with the JBL in-dash 6-CD changer.
    Strange thing happened today. All of the dash buttons for the audio system stopped working (PWR, eject, seek, cd/aux, etc.) Basically, the only control I have now is through the steering wheel buttons. I can still control all the functions (except power on/off) as long as I use the steering wheel.
    Any suggestions?
    Thanks
    -Adriano
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    That is exceedingly strange. Since it all happened at once, it may be a loose plug connection or a fuse. Can you cycle through the different modes and turn it on and off with the steering wheel MODE button? Can you use voice commands, if you have that option?
  3. elmofongo
    elmofongo Member
    256
    SF, CA
    I can cycle through the modes using the steering wheel MODE button. I don't know how to turn it off via that button, I thought that wasn't an option.
    I haven't tried the voice commands.
    I guess this is my first opportunity to make use of the extended warranty I purchased since I am over the 36K miles limit.
  4. Patrick Wong
    18,210
    6,510
    Hi Adriano,
    Since you have warranty coverage, no worries. If you feel like experimenting, try hitting the front panel (where the non-working buttons are located) with the palm of your hand to see if this will fix the loose connection temporarily.
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Well it does sound like a loose plug problem, what ever the case, please post a "What it was" post.
    I would like to know!!
    Thanks de Pat KK6PD
  6. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    My B.E.G. .... Internal open circuit inside the head unit.
    1) A blown fuse would shut down the entire unit. Toyota uses two fuses to power the head unit, one constant power and one key power. If either were blown, the unit would not play.
    2) A loose plug would also shut off the entire unit if you have a separate amp ( which the JBL system most likely has).
    3) Since the steering wheel controls can still control the unit, I would expect the problem to be inside the head unit.
    B.T.W. To turn off the radio using the steering wheel controls, press and hold the "Mode" button for 2-3 seconds. The unit will turn off.
  7. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    has anyone ever had their radio lose its presets while playing a cd?
    i got my cd replaced even though the dealership couldn't not replicate a problem
    the errors that were (probably) logged for this event were:
    LAN MONITOR EMV
    CODE 01 - DB SUB CODE 190 - 30 -3
    DSP AMP
    CODE 01- E1 SUB CODE 110-FF-1
    I think i got it nailed down to as lightly scratched or dirty/smeard Cds
    being played and causing errors on the Prius BUS (or a lack of a better term)
    and causing the radio or cd player to disconnect and reconnect thus losing
    your presets in the process.
    sometimes you can hear a short to long beep while the cd is playing and
    the presets are gone when you switch from cd to radio, sometimes not
    the clock and window settings do not change, and the car was in ready so that
    pretty much rules out anything wrong with the 12v
    i wrote a letter saturday to toyota about it, suspecting there is a minor defect in
    the headunit or somewhere in the car
    this has happened to me personally about 6 times since feb 2007
  8. elmofongo
    elmofongo Member
    256
    SF, CA
    Thanks for all the input. I will take it to the service dept. Hopefully my local dealer will easily honor my extended warranty that I purchased elsewhere.
    -Adriano
  9. emellinger
    emellinger New Member
    Evanston, IL
    This also happened to me several months ago; luckily I am still in the warranty period. The biggest issue was that the CD player held my CDs as hostages -- I could play then using the steering wheel controls, but couldn't eject or load them (a concern with Audiobooks from the library). My Toyota dealer diagnosed it as a malfunctioning radio head, and oredered and installed a replacement. Since then -- no problems.
    I was lucky; my unit had an intermittent problem and started working again before the replacement head arrived, so I was able to eject my discs. Otherwise, I was told that the head unit would have to be returned to the service center for disassembly to retrieve the discs, and that I might get them back in 6-8 weeks. Good luck!
    -- Leangreen
  10. elmofongo
    elmofongo Member
    256
    SF, CA
    Wow, I sure hope all the CD's in my changer are mine!
  11. Bear68
    Bear68 Member
    373
    72
    As a quick try solution for retrieving stuck CD's, I usually try disconnecting the power to the radio for a few moments then reconnecting it. Sometimes, "rebooting " the system will allow you to eject the CD's. It doesn't always work, but it can save you from having to wait for the radio maufacturer to return the discs. Try disconnecting the 12v negative cable for a few seconds. A simple thing to try that may save a hassle.
  12. elmofongo
    elmofongo Member
    256
    SF, CA
    OK looks like the problem is intermittent. The CD changer console came back to life today. I quickly ejected all the CD's in case it decides to die again.
  13. Shin Chan
    Shin Chan Junior Member
    56
    Sacrameto, California
    This is almost a year old thread but I have the exact same probelm as the OP.
    Anyone have an epiphany as to the cause of controls suddenly not working, and only steering wheel controls are working.
    Please do not tell me I need a new head unit.
  14. Bear68
    Bear68 Member
    373
    72
    OK.... I won't tell you that you need a new head unit....... but that won't fix your issue..... sorry.:(
    The head unit is the most liekly source of your problems.....
  15. Shin Chan
    56
    Well this morning I go to gym, and head unit works fine. I have no clue how it "fixed" it self. I swear the indash buttons did not function...power, volume, fm,sat/am, seek, and others.
    Sorry can not shed any light on this if others have a similar problem
  16. pipet
    pipet Junior Member
    SoCal
    I have had almost the same problem as the OP... almost all the dash controls quit working... I could still change the volume from the dash and power on and off, but no other controls worked.... I could not switch FM1 to FM2, AUX, use the scan button, or even manually tune with the knob. It's kinda like what happens when I am backing up and can't switch from FM1 to FM2... except I am not backing up!
    This happened one time before and it went away the same day. This morning it happened again and hopefully full function will also return later, but I do wonder what is causing this.
    If anyone has any thoughts I'd appreciate it! I just passed the 3 yr warranty period (and I picked this up used so I couldn't get the extended warranty) so if I have a repair coming up I wanna know about it!
  17. Stoods
    Stoods New Member
    OR
    Can we bump this thread so the OP can tell us what the fix was? My unit just had the same thing happen today; cds are hostage and unit works so long as I use the steering wheel controls. I think I'm on the border of the 1-year comprehensive coverage for a Certified Used vehicle, but I did notice the intermittent problem several months ago (it fixed itself in less than 30 minutes).
    Thanks!
  18. Stoods
    Stoods New Member
    OR
    Oddly enough, my JBL system is working normally again. This is the second intermittent failure it has had. Very strange.
