JBL No Bass
Discussion in 'Gen 2 Prius Main Forum' started by ajayre, Dec 1, 2010.
  1. ajayre
    ajayre Junior Member
    44
    UK
    I have the bass turned up to the max but there just isn't any. I'm guessing it's broken. Any hints, suggestions on what to do to try and diagnose the problem? I don't know much about audio systems unfortunately.
    Thanks, Andy
  2. Azipod
    Azipod Member
    139
    NorCal
    The JBL system doesn't have much bass to begin with. Perhaps its normal?
  3. macmaster05
    macmaster05 Senor Member
    4,050
    728
    depends what your media is. if it's radio, it could be the signal. Plug in your iPod or use a CD and play some normally base-heavy music. That will be an easy indicator.
    My JBL bass is pretty substantial. Not subwoofer good, but better than average for a car.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Disagree completely with that. I have the JBL "premium" stereo. Definitely not normal.
    Yep.
  5. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hmm,
    I have had people look over at my car, when the music I have the music loud, and there is sudden loud bass in the music. I have the JBL music system. I turned the bass down, it was anoying other drivers. Its not a subwoofer bass, but its definately hearable.
  6. biff_debris
    biff_debris WOOF!
    81
    Prescott, WA
    Even at normal levels and with not very extreme music, my stock JBL system will make the rear view mirror vibrate and excite rattles in the doors. I think you've got something wrong, but there are some folks here that are used to more highly powered custom installations and may say the JBL system sucks.
  7. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    Concur with others, the JBL has OK bass (will vibrate mirrors) but it can't hold a candle to the factory option Harmon Kardon with sub in my wife's Cube. In the grass is always greener world, folks on the nissan forum diss' it as wimpy.
  8. Blackmamba
    Blackmamba New Member
    113
    usa
    Interesting. I've always thought Harmon Kardon bass was better than JBL for multimedia speakers too. I guess all across the board H/K is better than JBL.
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    A - Are you sure ALL speakers are working and putting out sound approx the other speakers?
    B - Veify that you have gotten into the Audio setup menu and adjusted all 3 level adjusts as well as the Balance contol. Dd you get satisfactory results with adjustments
    C - What is your souce of audio, and do you get same results on any input?
    I felt the bass lacking on my JBL in the '08. I added a simple, but effective powered subwoofer to my system. Maye that mght be an answer to your problem.
    Keep us posted!
  10. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    how can you tell if you have the premium jbl system or just regular??
  11. Azipod
    Azipod Member
    139
    NorCal
    It will say JBL on the tweeter speaker grille.
  12. pwrstick
    pwrstick Junior Member
    32
    Do you have a factory installed amp under your front seat?
