JDM Chrome Front Grill Insert Add on - 2010 Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by w202mae, May 18, 2011.
  1. w202mae
    w202mae Junior Member
    59
    40
    SoCal
    Received my JDM front chrome grill insert add on today from Japan, install is rather painless and simple with 3M double sided tape. Got it on Yahoo Japan auction for US$105 shipped to my friend locally in Japan, then I paid for EMS air freight into the states. Yes, it's very steep price for 2 plastic chrome pieces, but since I can't find any here in the states (searched all over on Ebay) I will just have to live with it. Overall made the car's front end looked alot more elegant. Enjoy the pics.
    Item came in a white box and grill packed inside 2 polybag. Notice the 3M double sided tape already affixed to the underside of add on grill cover.
    Comparison of the grill add on the right compare to the left (still left stock). You can see the difference.
    Photo showing both chrome grill inserts taped on.
    Side angle shots of the grill add on.
    KLD_Prius_PI_Synergy likes this.
  2. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    Not for me, but glad to see folks experimenting with their rides.
  3. mmmdowning
    mmmdowning Junior Member
    37
    Spotsylvania, VA
    Looks nice.
  4. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Guess I'm thrifty. Rather than the plastic chrome, a $5 can of paint and some masking tape and newspaper. Easy one hour job and makes a nice subtle add.
  5. Tideland Prius
    16,125
    Nicely done. Quite subtle. I wouldn't be surprised if that will be one of the official changes made to the midlife update on the Gen 3.
  6. w202mae
    59
    40
    SoCal
    Dean, nice little paint add on you did there. I guess I am a sucker for chrome LOL.
    This chrome add on makes it look more like what it should be if Prius was badged under Lexus.
  7. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Looks really nice.
    Ya know if those came already chromed we'd be all over the black ones :)
  8. a1rjumpman23
    a1rjumpman23 Junior Member
    75
    Looks like i know what im gonna do next to my black prii haha
  9. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Yup. I plan to blacken my chrome one.
  10. w202mae
    59
    40
    SoCal
    Isn't that always the case, when it comes with something standard we want to jump to the other side. If Prius came with normal red/white lens cover, we would want to switch to the clear ones that we have now. :)
  11. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Yep, very true. The grass is greener on the other side.
  12. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Ima get some chrome ones, blacken em, then chrome them again to be different.
    :thumb:
  13. macmaster05
    macmaster05 Senor Member
    4,050
    729
    Definitely agree about the grass is greener. Although I think it depends on what you want your car to look like - If you were going for the rogue or blacked-out look this wouldn't appeal to you even if you were missing chrome.
  14. Truman
    Truman New Member
    17
    I am so sorry, but if you would have gone to AutoZone or Advance Auto store you could have bought a roll of chrome plastic, the same stuff that you use for door edge guard and used it, I did and have all my grille chromed upper and lower for just a few bucks.
    Truman
  15. wstevensiv
    wstevensiv New Member
    84
    Little Rock
    tell me more of this...:rockon:
  16. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    The roll of chrome is wide enough to cover the width of the grill?
  17. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    If I recall, it sort of looks to be about the sized of a roll of duct tape...so yeah.
  18. w202mae
    59
    40
    SoCal
    Granted there are ways to do things cheaper, but putting money aside the chrome makes the front end looks so much nicer!
  19. Tideland Prius
    16,125
    Just hope that the Autozone stuff doesn't peel or flake like what Nissan put on their Murano! I thought it was chrome-plated but it turns out to be chrome painted plastic when I saw an example peeling away and revealing the black plastic underneath. Ugh!
  20. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    The 3 dollar answer found at O'Rielly's
    I followed a suggestion from a poster here and purchased chrome door protectors for about 3 dollars. The OPs mod is designed for the Prius grille, but I had to revamp the door protectors for the plastic vertical "teeth" that are not apparent until you start the project. I needed to remove my work and notch out the bottom of the trim where those "teeth" interfere with the smooth application of the protectors, which you need to precisely cut to fit the center "rib" in each side of the grille. I'm not convinced yet, and it can be removed...but I will keep it for awhile to see if it grows on me. What to you think?
