Jerking when the fuel engine turns on
Discussion in 'Gen 4 Prius Main Forum' started by rahmani, Mar 10, 2021.
  1. rahmani
    rahmani Junior Member
    Bangladesh
    While in park mode, usually the car is in electrical engine but when the fuel engine turns on, my car jerks a little while turning on after wards there’s just a little noise of the engine running but no jerking. Is it normal?
  2. priusman09
    priusman09 I used to be a TDI
    67
    76
    wisconsin
    This was normal in my 2009 over the 225,000 miles I had it. On my 2017 Prime it is less noticeable. It usually happened when I was sitting for long periods with the air on and the engine finally kicked in to charge the battery on the ‘09.
    rahmani likes this.
  3. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Our Prii (I have had three) implement "neutral" using software control of the MG opposite the Engine on the Hybrid Synergy Drive. That MG is controlled to spin in reverse to compensate for the engine running forward so that the torque applied to the drive shaft is minimal. This is not perfect and when transients occur (like the engine starting up which requires some counter torque to spin the ICE), some torque is momentarily applied to the driveshaft and you will feel some movement.
    rahmani and alanclarkeau like this.
  4. rahmani
    Bangladesh
    Thanks
    Thanks
    #4 rahmani, Mar 22, 2021
  5. ISFdude
    ISFdude Junior Member
    Queens New York
    I have a 2017 Prius 2 and Yes mine moves forward about 2 or 3 inches when the engine fires up and it’s a normal thing as it’s been doing this for awhile.
  6. ChapmanF
    18,547
    I've noticed for my Gen 3 they actually made the ECM coordinate with the brake ECU. When it is about to start the engine and it's parked, it applies the brakes first, to minimize any roll of the car. If things are quiet enough, I can hear the brakes apply, and pretend I have precognition of when the engine's going to start.
    I don't know if they added that only in Gen 3 or if Gen 2 did it too. I know my old Gen 1 didn't.
    vvillovv likes this.
  7. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    Is the parking brake on?
  8. Ramo_958
    Ramo_958 Junior Member
    22
    Doylestown, Pennsylvania
    2018 Prius
    One of the cylinders might misfire.
  9. Chris Wolfgram
    Chris Wolfgram Active Member
    422
    169
    Sacramento CA
    2019 Prius
    You could at least wait until you get home to do that ! :) lol
