JiffyLube told me this about my MAINT REQUIRED light...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sparky9292, Aug 1, 2009.
  1. Sparky9292
    Sparky9292 Junior Member
    37
    Earth
    Took my Prius 2005 into JiffyLube for an oil change. After declining the $64 dollar price to fill it with synthetic oil, the mechanic said that the Maint Required idiot light only turns on when the sophisticated sensior measures varnish levels and turns on.
    He said it would automatically turn off after an hour after the oil change.
    It's been 24 hours and the light is still on?
    Did they actually change my oil? Why is the light still on?:confused:
  2. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    and thats why i dont go to jiffy lube,..... look for the reset info here....
  3. Sparky9292
    37
    Earth
    He fibbed? Hmmmm
  4. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    Try doing this:
    Press start button until car turns the ignition on
    Make sure the odometer displays "ODO" NOT TRIP
    Press and hold the ODO trip reset button in
    press start button until car turns off
    press start button until car turns back to ON
    Hold the ODO button in until all the flashing lines on the odometer go away and the mileage returns and the maint reset light stops flashing
    Your'e done.
  5. brick
    brick Active Member
    1,083
    78
    Upstate NY
    They didn't know how to reset it so they made up a story. Or they were too lazy to reset it so they made up a story. Or the guy was delusional, hence the story. Take your pick.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Some cars (?GM only?) have oil life sensors, so that part isn't a complete fabrication. But the Prius does not. The Maint light starts flashing 4500 miles after it was last reset and starts beeping and stays lit 5000 miles after it's last reset and it will stay on until you reset it again...whether you've actually changed the oil or not.
  7. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    yes, its posted elsewhere but I will list the procedure here.
    step 1 set the ODO display where it shows the cars ODO Miles (not trip A or B before turning off car)
    step 2 hold the ODO button while turning the car on to READY mode continue to hold for about 5 seconds while the ------ (dashes) on the ODO disappear.
    For further instructions this is also listed inside the owners manual. The Maintenance required reminder resets and will come back on at 5000 miles regardless the current quality of the oil.
  8. richard schumacher
    7,663
    1,038
    United States
    My GF's Civic has an oil life sensor. Maybe all Japanese cars look alike to the Jiffy Loob guy.
    ObOilChangeAdvice: Always check the oil level yourself before driving away from every oil change, no matter who does it. This can prevent some dumb mistakes from becoming expensive mistakes.
  9. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    No such thing. This person has no idea what he is talking about. Every vehicle with an oil life monitor must be reset at oil change time, sometimes (Expensive German cars, some VW's, etc) needing a dealership scantool
    The expensive German cars use a software routine that examines total fuel used, engine run time, start cycles, etc, to determine when to turn on the Change Oil indicator. The GM oil life monitor works the same way
    The Prius turns on the Maint Reqd reminder at 5,000 miles, period. Actually warns around 4,500 miles
    How? By magic?
    Yep, it sure is. And will remain on until you go through the documented reset procedure
    Good question. Wonder what they refilled it with? Wouldn't be a bad idea to verify the oil fill cap and dipstick are still present and accounted for. Also wouldn't be a bad idea to check if the oil filter is barely hand tight, or if the drain plug is dripping
    Most likely, next time you change the oil yourself, the oil filter will be on super tight, and so will the drain plug. Perhaps the drain plug will be cross-threaded too
  10. Old Bald Guy
    Old Bald Guy Old Bald Guy
    89
    Ft. Worth, TX
    Here's a thought. I used to take my SUV to WalMart and paid about $50 for a synthetic oil change. I take my Prius to my dealer and pay about $50 and get the oil change, the tires rotated, the brakes checked AND a car wash. Last time I priced an oil change at one of those 10 minute oil change places, they wanted more than $60 for a synthetic change.
    Oh yeah, I get my service in 29 minutes ... or less.
    Your oil is the life blood of your car and you change it 2 or 3 times a year ... with average miles driven. Do you want to trust your car to someone who knows what they are doing and uses the right parts ... or do you want to go somewhere where they don't have a clue, use who knows what kind of oil, and probably stick a JUNK Fram filter on your motor?
    There is no such thing as a "sophisticated sensior measures varnish " device on a Prius ... or any other car that I know about.
  11. dogfriend
    7,512
    1,185
    Carmichael, CA
    The Jiffy Lube guy is an idiot.
    2 people like this.
  12. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Thanks, Dogfriend for saving me the time of typing a reply. (except this one, of course)
    Sparky, if / when you return to that same Jiffy Lube, take your manual with you and be sure to whack him over the head with page 122, section j. Swing hard; there's a lot of thickness you're going to have to get through.
  13. efusco
    19,891
    1,192
    Nixa, MO
    NEWSFLASH!
    Leader of the top Prius web site advocating violence against those who sell fossil fuels. New eco-terror movement?!
  14. TonyPSchaefer
    14,816
    2,497
    66
    Anyone who references me as a leader has far bigger problems than eco-terrorism.
  15. dogfriend
    7,512
    1,185
    Carmichael, CA
    I don't think he was advocating violence, just negative reinforcement*, like when you catch your dog soiling the carpet. :madgrin:
    * Dogfriend does not advocate hitting your pet, but he might take a swing at the Jiffy Lube guy if he thought it might do some good.
  16. jayman
    13,439
    640
    Winnipeg Manitoba
    What I would really worry about is the Iffy Boob guy pulls the Prius in, and the gas engine is off. So, and this is VERY important, he does NOT power down
    With the car up on the hoist, in the middle of the oil change with the pan empty, the Prius decides to restart the gas motor to charge the traction battery
    Oops
    Good idea, except I wouldn't waste my time swinging the owner manual, possibly crinkling it in the process. My fist works SO much better
    :hail:
    Forgive us, Oh Glorious Leader
    It has been my experience you will probably have to take quite a few swings. Some of those skulls are positiviely Neanderthal in construction
  17. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    Wow! Also, anyway to make it only start with the FOB in the slot?
  18. hschuck
    hschuck Member
    385
    17
    bay city, ca
    On your 2009 you can turn off the SKS system by pressing the 'key' button at the bottom of the dash. As I understand it the 2010 does not have a way to turn off the SKS.
  19. dogfriend
    7,512
    1,185
    Carmichael, CA
    You could disable SKS using the button under the steering column, but what would prevent Jiffy Lube guy from leaving the fob in the slot?
    Easier and safer for your car to avoid Jiffy Lube guy altogether.
  20. ETP
    2,801
    1,170
    Auburdale FL
    Yep/just thinking! So if you asked for the key after he pulled it in you would be good to go.
