Juddering and traction control light
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Fefnirshead, Aug 1, 2023.
  1. Fefnirshead
    Fefnirshead Junior Member
    Green Bay
    Hello! I got my 2013 Prius a few weeks ago. It has 80,000 miles on it. I was going about 30 mph when it suddenly felt like my brakes had engaged automatically, accompanied by a scraping noise. The traction control light also came on. The noise and feeling were like a tire had blown or kind of like driving with the emergency brake on. I pulled over and didn’t see anything wrong with my tires. So I got back on the road and it happened again at around 25mph. I turned off the car and started it up again and it drove smoothly the rest of the way home. Any idea what this might be?
  2. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    The only time my traction light came on was when the front tires spun on wet pavement. Was it the 2 squiggly yellow lines?
    Probably some more help on here in a bit.
    Fefnirshead likes this.
  3. Fefnirshead
    Green Bay
    Yeah, the squiggly lines. In my previous Prius, I’ve had those come on in snow, but never just out of the blue.
  4. Air_Boss
    Air_Boss Senior Member
    4,223
    1,188
    New Yawk
    Did you pick up debris between a rotor and backing plate? Which fell off after your second event?
    Tim Jones likes this.
  5. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    This sounds Very Reasonable.... because it has happened to me with my van
    Only thing kinda funny is the traction control light.....unless it slowed the wheel down.
  6. Air_Boss
    4,223
    1,188
    New Yawk
    If something got wedged in there tight, it undoubtedly slowed the rotation, which beyond a certain delta RPM would trigger the traction control circuit and light.
  7. ChapmanF
    18,536
    Are all four tires the same size and style?
    With a scan tool, I would let a copilot watch the four wheel RPMs while I drove down a straight road, to see if they were all reading the same.
  8. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
  9. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
  10. Air_Boss
    4,223
    1,188
    New Yawk
    Catastrophic EGR failure...
  11. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    NHRA Accident Investigation Results of the cause of engine explosion was
    Air_Boss likes this.
