July 2006 MPG Averages
Discussion in 'Gen 2 Prius Fuel Economy' started by Tideland Prius, Jul 7, 2006.
  1. Tideland Prius
    16,125
    Tank Miles: 840.9km (New Record!)
    Total Miles: 30983km
    MFD Avg: 4.2L/100km
    Calc'd Avg: 4.44L/100km
    Fuel Used: 37.366 litres
    Price: $1.124/litre
    21st June to 7th July
  2. HybridVigor
    HybridVigor New Member
    96
    Chandler, AZ
    Tank Miles: 590
    Total Miles: 15329
    MFD for last tank: 61
    Calc'd for last tank: 59.7
    Temps in Phoenix: 100-110 degrees Fahrenheit
  3. Jack Straw
    Jack Straw New Member
    137
  4. B Rad
    B Rad New Member
    295
    First Tank miles--400
    Total miles--400
    MFD--45.9--mpg
    Calculated--50 mpg
    Temps--105---114
    Air always on...
    Did my 1st fill up this morning, the MFD was at 46 until that last little hill to the station and then it popped down to 45.9
  5. VABeachPrius
    VABeachPrius Member
    155
    Virginia Beach, VA
    1st tank ever - 486 miles @ 53.5 mpg (MFD)
    Calculated MPG is off due to a short fill from Dealer at delivery. ~43mpg
    490 miles on car. 42/40. Oil Level - Full, 90% surburban city, 10% Hwy, 70-95F, 80ish% RH, Level terrain
  6. ServoScanMan
    ServoScanMan Member
    262
    Lorena, TX
    Yippee! I broke my old tank record. My previous record was 55mpg. I filled up yesterday and averaged 57mpg. I lucked out on the way to work today because there was no one on the highways tailgating me. I drove slower than usually and used the PAG (pluse-and-glide) method a lot more. My round trip average since my fill up is showing 66mpg. I know this is misleading but it is encouraging.
    VABeach, My first tank average was 45mpg. I was depressed until I learned how to drive the car from this forum. You did very well for your first tank.
    Highest average tank (MFD): 57mpg
    Temps 97-99
    Heat index 102-105
    AC set at 76 degress
    Average round trip 10 miles.
    Fuel $2.689/US gallon
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    New record tank for me as well.
    This was a slightly short fill (last tank calculated to 64.1mpg despite only showing 61.x on the MFD).
    This time at 573 miles with the last bar flashing for about 10 miles I filled up with 64.5mpg !!! on the MFD. Calculated out to 61.6mpg.
    Interestingly, but not necessarily significantly, this was a tank of Shell gas instead of my usual Murphy's gas from Wal-mart. Probablely most significant is that I was able to drive at off peak hours and keep the speeds down for all but about 200 miles of the tank.
    Anyway, even 46k miles into this car I'm still learning, improving and enjoying the hell out of this fine vehicle.
  8. kDB
    kDB New Member
    241
    Fenton, MO
    i decided to get gas a little early due to oil prices, so i didn't make it my usual 500+ miles. the MFD said 60.2, i overfilled it a bit and got a calc of 54.84 (483miles, 8.807gallons). average driving temps were around 75-80F.
    great news for me though, i found a different route home from work. managed 80mpg without using P&G, though i did glide a lot. so much gliding the ICE ran a lot of the time just keeping warm. can't wait till i get off my lazy behind and install my EV switch.
  9. Tideland Prius
    16,125
    Nice.. this is the month of record tanks.
  10. troe
    troe New Member
    83
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 13 2006, 12:56 PM) [snapback]285742[/snapback]</div>
    Well I just put in my 6tyh tank in at 3250 mi. The MFD was at 63.1, so I thought I would be having my best tank ever. The pump clicked off at 10.4 Gal at 646 MI on the tank, but I decided to make sure if was totally toped off. I was able to squeeze in 12.1 Gal. Hurt my milage a lot, (53.5 MPG) :( but it is good to see how much the bladder varies on a hot day 96F. Maybe I will get a 700 mile tank out of this next tank! :rolleyes:
  11. Tideland Prius
    16,125
    Tank Miles: 751.3km
    Total Miles: 31644.3km
    MFD Avg: 4.6L/100km
    Calc'd Avg: 4.62L/100km
    Fuel Used: 34.697 litres
    Price: $1.124/litre
  12. AndyMartin826
    AndyMartin826 New Member
    112
    Gilbert, AZ
    7/13 - 7/22 data
    255 miles (first fillup)
    8.479 gallons
    30.1 mpg (ouch)
    Had terrible mpg reading when I drove home from the dealership, so I'm sure they idled it for a while with the AC running. Ditto on the tint install, mpg tanked after I picked it up. I don't think the tank bladder was stretched out, either, so hopefully this next tank will work better. 50 miles into the new tank, my MFD reads 48.2 mpg.
  13. Tideland Prius
    16,125
    Yep, they probably did. My new tank is at 3.3L/100km and 30kms but I know I won't keep it cause I have a service appt + steering wheel recall on Wed. This means a drained battery and I expect it to read 6.x or higher.
  14. VABeachPrius
    VABeachPrius Member
    155
    Virginia Beach, VA
    Total miles: 1055.2
    AVG: 59.6 MPG
    MFD numbers averaged becuase I am still on the second tank.
    Current Tank: 564 miles, 66.2 mpg
    Tires: 42/40
    Miles on Car: 1055
    Oil: Full
    Oil Type: From factory
    AC use: minimal
    Thanks,
    Chris
  15. gnagel
    gnagel New Member
    72
    Tank miles--649.3
    MFD--64.1 mpg
    Calculated--64.1 mpg
    I've had my Prius for just over three months now and this was my record tank! My life to date average is 57.2 mpg and it is on its way up.
  16. barbaram
    barbaram Active Member
    911
    70
    Trenton, NJ
    No record tanks here! in fact, as I suspected my apparent record tank was not:
    monthly totals:
    miles: 1690.7
    gal: 36.037
    MPG: 46.9157
