Jump The Fuel Pump
Discussion in 'Prius c Main Forum' started by PriusII&C, Jul 14, 2021.
  1. PriusII&C
    PriusII&C Active Member
    370
    129
    San Jose, California
    Trying to get fuel out of the tank, and wonder if someone has jumped the fuel pump by by-passing the relay?
  2. Danny13pruisc3
    173
    27
    maryland
    why are you trying to get fuel out of the tank? i've seen cars that sat for 3 years start up and run and drive with the old fuel.
    I haven't tried it on the C, but generally you can unhook the fuel line somewhere... or there is usually a schrader valve you could remove the core and jump a relay..
  3. douglasjre
    douglasjre Senior Member
    1,877
    653
    Orlando, FL
    Use techstream
