Jumped wire in fusebox
Discussion in 'Gen 2 Prius Technical Discussion' started by ired44, Jul 22, 2020.
  1. ired44
    ired44 Junior Member
    Connecticut
    Hi guys. New to this forum. Recently purchased a 2006 Prius and noticed that the headlights were out. Not the problem I'm worried about. Went to check the headlight fuses for the headlights in the fuse box under the hood and noticed a wire that goes from a blue wire in a harness to the P Main Conn fuse. Not sure what's going on there as it doesn't look factory. Was wondering if anyone has a clue as to what's going on there. Picture included. TIA. IMG_20200722_091116.jpg
  2. ydpplqbd
    ydpplqbd Active Member
    542
    250
    What does the blue wire power?
    If you trace the blue wire, where does it go?
    IOW, disconnect the blue wire temporarily and then see what no longer operates.
  3. ydpplqbd
    542
    250
    Your Gen2 may have been modified to clear parking code error. See Youtube video discussing this "repair":
    #3 ydpplqbd, Jul 23, 2020
    strawbrad likes this.
  4. ChapmanF
    15,649
    "I know this is kind of hokey" @ 3:38 :D
  5. ired44
    Connecticut
    That's exactly what it was. Thank you so much guys.
  6. HASA123
    HASA123 Junior Member
    Sri lanka
    guys, who know what is the reason for this parking code error
  7. ydpplqbd
    542
    250
    Sounds like the fuse being provided with power with the jump lacks power. IOW: fuse, computer, harness, connectors, corrosion, etc.
