Jumping a dead battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kidd, Feb 20, 2008.
  1. Kidd
    Kidd New Member
    75
    Port Orange, FL
    Not intentionally wanting to beat a dead horse, but there is so much discussion on remedies for a drained 12 V battery. I would like to know simply what is the procedure and precautions one must take to get a friend to just jump the dead Prius battery located in the rear compartment? Is it like jumping any other type battery? And why it this battery so expensive to replace? What makes it different than any other 12 volt car battery that can be bought at your local WallyWorld, Sears, or AutoZone?
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Just follow the instructions provided in your owners handbook to jump the battery. The battery is small as it only has to boot up the computers that operate your Prius. There are several threads that show how to modify other batteries to work in a Prius however most will cost about the same as the OEM battery.
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The procedure in the owner manual is correct. Use the underhood jump point. Never, ever short the positive and negative jumper cables or your Prius could need thousands in repair costs
    A lot of people like to "test" their jumper cables by briefly touching the pos and neg clamps once the car is hooked up. They get a little spark. That should never be done on any modern car, you could destroy the computer. On the Prius it can destroy a lot of components
    The battery is an odd size, think motorcycle or lawn tractor. It's sealed with a provision for a vent tube. Apparently a Mazda Miata battery can be adapted to work
  4. tochatihu
    tochatihu Senior Member
    9,698
    3,742
    Kunming Yunnan China
    2001 Prius
    Jayman and I may be saying the same thing. But the warning I want to state is *never get the jump cable polarity reversed* If nobody at the scene can be 100% sure they are correct, get smarter help!
    At a minimum you will kill an expensive hard to replace fuse block that the Prius can't run without. At worst an ECU or two.
    It may be common for ECU-rich cars to be this fragile, I do not know. But Prius certainly is.
  5. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    It amazes me that we even see reports of reversed polarity. I've never had to jump mine, but after first reading a report of improper jumping, I peeked at the under-hood terminals to know what I needed to look for. It should be a no-brainer; the terminals are clearly marked. But then I guess sometimes we unwittingly call on people with no brains to help us with our cars. :p
  6. Flying White Dutchman
    4,376
    313
    yes
    and if there is no color marking then the + is ticker/wider then the -
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    Yep. I was also talking about idgits out there who will purposely touch the pos and neg cables to make a spark, to "test" the connection. You'd be surprised how often that happens.
    Considering how expensive any potential repairs could be, a jump start box is pretty cheap. If it fries, you're only out $80 or so
  8. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    Toyota missed a great chance to help make the Prius more bullet-proof.
    Since the 12V battery doesn't power a starter, they could have put a 50 Amp diode between the jump terminal and the rest of the car. That way, if the polarity was reversed, nothing would happen. Alternators have 50 Amp diodes in them, so they're neither expensive or large.
    It would also prevent using the Prius jump terminal from being used to (try to) jump start another car thereby making sure that you don't pop the 100 Amp fuse that our cars have.
  9. tochatihu
    9,698
    3,742
    2001 Prius
    Concering polarity, some 'donor' vehicles have black-insulated cables on both (not necessarily OEM...) so if you encounter one of those be sure to identify the chassis ground.
    I guess there aren't many positive-ground vehicles on the road any more. That could ruin your day.
    Kohnen the diode pritection idea has been discussed before. I can't think of a reason it shouldn't work. It has also been suggested to Toyota via groups like this (and other means).
    A person could certainly make their own Prius jumper cables with fuse and/or diode protection. It would not have to be super-thick wire either. At least one person has made their own. Come to think of it, might be a nice Prius-specific accessory. Anybody need a garage hobby business/time-burning idea?
  10. kohnen
    317
    58
    Fullerton CA
    I wouldn't put it as part of the jumper cables - I would make it part of the jump stud. Put a large diode with the cathode attached to the Prius' positive jump terminal, and make the anode available for attaching to. Current can then go into the Prius, but can't come out - this would protect against both cable reversal and trying to jump a bigger car off of the (tiny) 100 amp fused path to the battery.
    [Yes, I know that the electrons with their negative charge are the charge carriers. For historical reasons, we engineers say that positive charge moves in the opposite direction as the electrons.]
