Jumping Prius Prime with Hulkman Alpha85
Discussion in 'Gen 5 Prius Main Forum' started by bbowards22, Oct 25, 2024.
  1. bbowards22
    bbowards22 New Member
    Massachusetts
    2024 Prius Prime
    XSE Premium
    Hey All:
    Not sure if anyone has tried this yet. I didn't need to jump the car - just scoping things out. To me, there doesn't seem to be a clear place to attach the negative clamp under the hood - the length of the Hulkman pack being somewhat limited. Has anyone tried this? If so, where did or would you attach the negative clamp?
    Thank you!
    51,020
    any unpainted metal should work. manual might mention something
    soft_r likes this.
  3. Gokhan
    Gokhan Senior Member
    5,632
    2,219
    Paramount CA
    Any unpainted metal away from the battery. The idea is to avoid an H₂ explosion caused by a spark when you complete or break the circuit, as H₂ is concentrated around the battery. As long as you are in a well-ventilated space and you fan the battery to spread out any H₂, you should be probably OK with connecting it directly across the battery.
  4. bbowards22
    Massachusetts
    2024 Prius Prime
    XSE Premium
    The manual references a connection point some distance from the fuse box - far too long for the Hulkman cables. As for an unpainted connection point, I don't see one other than some module that is to the right of the engine and slightly above it - I guess I need to figure out what the component is exactly.
  5. bbowards22
    Massachusetts
    2024 Prius Prime
    XSE Premium
    In this Prius, the battery is in the back (not sure if this is true for prior models). I could connect it there, but I would like to do it up front at the fuse box connection point (and avoid climbing into the back of the vehicle). The manual directs the reader to the connection point under the hood/at the front of the vehicle.
  6. Mendel Leisk
    40,459
    Add a ground cable of an old school jumper cable to your jump pack kit, then you can reach whatever point.
    That said, I'd also pay some attention to avoiding the need for a jump pack.
    #6 Mendel Leisk, Oct 26, 2024
  7. Mendel Leisk
    40,459
    Another thought: look for a jump pack with longer cables?
    Check your prospective ground points too; make sure they work. You can do this with a test light probe, or the resistance mode (or continuity function) of a multimeter. Attach one probe to a very “for sure” ground, the other to prospective point.
    come to think of it, in Vancouver’s Stanley Park there’s a Prospect Point. :coffee:
    If you stay on your toes about battery maintenance, look into smart chargers, you’ll likely only be using a jump pack on other cars. ;)
  8. bbowards22
    Massachusetts
    2024 Prius Prime
    XSE Premium
  9. bbowards22
    Massachusetts
    2024 Prius Prime
    XSE Premium
    I see there is a Schumacher brand jumper pack, which I might just buy. It looks like the cables are significantly longer than the Hulkman brand cables (which is what I have from a previous vehicle). This is my wife's car, and she is not only not mechanically inclined, she is mechanically phobic. Consequently, I want to make this as simple as possible for her should she ever leave something on and have the need to jump it alone (which has happened in the past).
    There is an unpainted bracket with an unknown (to me) component attached to it on the right side of the engine. The bracket seems to be bolted onto the engine block, but I'm not a thousand percent sure.
  10. Mendel Leisk
    40,459
    Again, check for continuity, between a known good ground and the "prospect".
    For your wife, maybe look into a quick-connect system. You run cables from 12 volt positive and ground, to a socket, mounted somewhere conventient (maybe even in the cabin), and have the jump pack cables wired to a corresponding connector. Preferably one that cannot be reverse-connected.
    Here's our CTEK charger connection, very simple to hook up: One lead goes to a bolt in the corner of the engine bay (it was an empty threaded hole, from the factory), and the other to the 12 volt positive feed into the fuse box.
    #10 Mendel Leisk, Oct 27, 2024
  11. bisco
    51,020
    they must have really changed the engine bay, gen 3 has all kind of ground points
  12. bbowards22
    Massachusetts
    2024 Prius Prime
    XSE Premium
    Thank you for this - finding a prospect is what I’m going to do.
  13. Hammersmith
    Hammersmith Senior Member
    1,961
    1,966
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    There's a chassis/body ground just below the fuse box where the positive blade is located. Considering the short length of the Hulkman's cords, that's probably where I would attach.
    edit: Actually, I might have to take that back after thinking about it for awhile. It's one thing to use a bare metal part as a ground, it's another to attach to an actual grounding wire without knowing where that wire goes. There's a (tiny)chance power could be routed somewhere it shouldn't go. Probably better to use the fuse box bolt right next to that ground wire if the jaws of the boost pack can be secured to it..
    #13 Hammersmith, Oct 27, 2024
  14. Gokhan
    5,632
    2,219
    Paramount CA
    Just get a jumper cable as an extension cable as @Mendel Leisk suggested so that you avoid an H₂ explosion, which could still happen if the chassis connection is within two feet of the battery. The chassis connection needs to be at least two feet away from the battery.
    bbowards22 likes this.
  15. Hammersmith
    1,961
    1,966
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Lol. Why would there be an H2 problem when using the jump point under the hood?
    Blackat and bbowards22 like this.
  16. Gokhan
    5,632
    2,219
    Paramount CA
    Alternatively, if you turn off the device before connecting and disconnecting it, there shouldn’t be sparks; so, you can connect the device directly across both battery terminals if you do that.
  17. NMT
    NMT New Member
    Carlsbad
    2019 Prius Prime
    I used a jumper cable as an extension so the negative clamp could reach where the manual said to connect. It worked great!
    Gokhan likes this.
  18. chris johnson 2
    chris johnson 2 New Member
    29
    Netherlands
    2024 Prius Prime
    Can you give a photo? I see a few likely points but it would be great to know which one works. The Toyota standard connection is obvious but from 20 years ago and the modern leads are too short.
  19. Zeromus
    Zeromus Active Member
    495
    258
    Ottawa Canada
    2024 Prius Prime
    SE
    Yeah people are really forgetting that the jump point at the front of the car is ... the whole length of the car away from the battery in the gen 5.
    They put it back in the trunk. I should know, because when I was changing my tires on two cars this past weekend, I must have been triggering the damned proximity dome light feature so much that I had to climb into the trunk to boost my battery with a pack. The car was in the single car garage, so no way to boost with our second car.
  20. chris johnson 2
    29
    Netherlands
    2024 Prius Prime
    The guy who arrived to jump start my 2024 Prius Prime had the longest leads I have ever seen - must be 10 metres or more. He did not even bother to investigate the problem and assumed the 12V was flat. It was in the middle of a snow storm but even so .... it should say enough to anybody from Toyota who is listening. This is a systemic problem!!
