Jumping With Portable Charger?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by apistogramma2296, Dec 18, 2024.
  1. apistogramma2296
    apistogramma2296 New Member
    St. Louis
    I have a dead battery - must have left a door ajar or something dumb.
    I have a portable charger (brand ‘DBPOWER’) and my result is as follows -
    There is a good spark at the negative-ground clamp. The dashboard immediately comes to life as if ready to drive. But about 10 seconds later goes dark. The charger then appears to be quiet, and about 1/4 discharged (such as 100% to 75% in one attempt). Subsequent attempts get the same result.
    What am I doing wrong? Thanks for any help!
    #1 apistogramma2296, Dec 18, 2024
  2. Brian1954
    Brian1954 Senior Member
    1,699
    663
    South Central PA, USA
    You are probably doing nothing wrong. The 12v battery is probably very low on charge. Do you have a volt meter to measure the battery?
    What is happening is that the 12v battery is pulling all the charge out of the jump pack.
    You can try disconnecting the negative cable off the battery and connect the jump pack to the negative cable, and put the positive jump cable on the positive terminal of the battery. See if you then can start the car. If you can, then remove the jump pack and see if the car keeps running. If you try to put the negative cable back onto the battery negative terminal , you will probably get a large spark, so be prepared for it.
    #2 Brian1954, Dec 18, 2024
  3. ChapmanF
    17,180
    ... or pulling enough charge out of the jump pack quickly enough that the pack shuts down temporarily to avoid overheating.
    The one I've got has a little alphanumeric display that actually scrolls BATTERY COOL DOWN 60 SEC REMAINING and counts the seconds down until you get to try again. A lot of others just have a few LEDs and you have to pore over the jump pack's manual to be sure what some combination of the lights is telling you.
    Brian1954 likes this.
  4. apistogramma2296
    St. Louis
    Thank you! Just to clarify, my current experience is with connecting solely to the jump pack of the Prius (positive cable to jump pack tab, negative cable to ground) not the 12v battery way in back. Is that not the thing to do?
  5. rjparker
    rjparker Tu Humilde Sirviente
    9,486
    5,811
    Texas Hill Country
    A big spark is a bad sign when you are attaching the jump pack. They are designed not to spark.
    It should not be outputting power at that point. That brand and most other lithium jump packs are designed to check polarity and determine your battery has enough voltage to be jumped before engaging the jump pack's output.
    Perhaps you have overridden the protection which is designed to safeguard your car and the jump pack. Or just as likely the jump start module has failed.
    From one review
    Showed a full charge, but when I plug the booster leads in it instantly sounds the constant beeping tone and shows a red and blue light indication either a short circuit or a low battery or overheat on the unit. Both of the unit were fully charged? I went to use the second DBpower unit from my car and it seemed fine until i hooked it to a dead battery and it began to tone and show both red and blue lights as well. Both units no longer work as a booster.
  6. ASRDogman
    ASRDogman Senior Member
    7,109
    3,713
    ??? Are you connecting to the Positive in the FUSE BOX in the engine compartment?
    Are your headlamps on? The pack should be connected BEFORE turning it on.
  7. apistogramma2296
    St. Louis
    Well it finally worked. Through some quickly pushing the power button and quickly switching to ‘drive’ before the dashboard died, I was able to get rolling. Hopefully some tidbit of Prius insight comes from this. I appreciate any response about what happened.
    RE: dogman reply, I was connecting to the jump pack like this.
    ASRDogman likes this.
  8. ChapmanF
    17,180
    This is an example of the kind of 'deviousness' described (favorably) in this post, where you take the car's battery temporarily out of the picture so your little jump pack has only the much easier job of making the car READY. Then, once the car is READY, and supplying its own 12 volts, you can put away the jump pack and put the car's battery back in the picture, and let the car do the work of recharging that battery.
    In a gen 3, undoing cables on the battery buried in the back is the hard way. The easy way is to unplug the fat white cable in the underhood fusebox. Then connect the little jump pack to a ground and the fusebox jump terminal in the normal way. Once the car is READY, you can plug the fat white cable back in.
    The post I linked above says I had never actually tried that in a gen 3 at the time of writing, but I've done it since, and it works just as described.
  9. ASRDogman
    7,109
    3,713
    What's the update?
  10. apistogramma2296
    St. Louis
    Well it’s dead again. After the apparent success noted above, I drove around for an about 5 minutes and returned home. 2 days later (today/Saturday) dead again. Same difficulty of the dashboard lighting up and then dying when connecting the portable charger to the jump pack. To try Bryan’s suggestion above to connecting to the jump pack and 12v battery simultaneously I’ll need a longer cable to get from hood to trunk. This portable charger has cables less than a foot.
  11. ASRDogman
    7,109
    3,713
    5 minutes is not enough to charge the 12v battery.
    Get an AGM 5 amp or less charger, and charge the battery overnight.
    12 hours would be good. If it still dies, you'll likely need a new Toyota 12v Battery.
    Isn't that one under warranty?
    You're wasting your time trying all kinds of "tricks". It's NOT that difficult.
  12. Brian1954
    1,699
    663
    How old is the 12v battery?
  13. rjparker
    9,486
    5,811
    Texas Hill Country
    Pretty sure you misunderstood Brian's start it without the 12v battery strategy.
    Regardless a 12v battery needs at least 30 minutes runtime to get enough charge to last 2-3 days. Which assumes the battery has 50% or more capacity left. All batteries lose capacity each year but daily drivers can go really low in capacity before you get your scenario.
    Take the battery out and take it to an auto supply for free load (capacity) testing.
  14. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Skipping over the easy fixes like battery life and terminal connections are no longer the battery troubleshoot approach?!
  15. Mendel Leisk
    40,457
    Test it. With an electronic load tester (tests cold cranking amps). It’s likely a Frankenbattery at this point.
  16. apistogramma2296
    St. Louis
    I took it on a longer errand run - about 30 minutes - and a week later it started fine. So as you say, a brief drive was not enough to recharge it.
    Do you have a recommendation for a better portable jumper for a hybrid car with 12v battery like this?
  17. ASRDogman
    7,109
    3,713
    I have a Hayo pack. I've used it several times over the years on my van because I rigged up
    my ac with a switch that I would forget to turn off when I shut the car off..... and other
    people's vehicles. Never needed it on the Prius.
  18. johnHRP
    johnHRP Active Member
    550
    161
    tally, fl
    If the 12V battery is old enough >3y, complete depleted until we cannot start the car is dead penalty. If the battery is relatively new < 6 moths, it may still have 30-50% capacity back after fully charged.
    The sulphation causes irreversible capacity lost if it is below 80% charging for too long. Ideally it should be always 12.2V or more when the car is Off.
    My commons practice is replacing battery whenever if it ever been depleted and cannot start the car and >3y old. It usually will never get back to life. My current battery is 9y old but never have issue, fortunately I drive regularly. At least once a week for 30 minutes.
