Just 1 more mile
Discussion in 'Prime Fuel Economy & EV Range' started by HypersonicPrime, Dec 15, 2017.
  1. HypersonicPrime
    74
    59
    NC, USA
    I think the answer is no, but if the EV range gets to zero and I have 1 mile remaining to go, is there any way to just use some of the HV battery reserve to drive that final mile without the engine coming on. It's just annoying to know that 1/4 of the battery is remaining (HV reserve) that I could potentially use part of for such situations.
    priuscatprimeguy likes this.
    49,516
    you are correct. and it is frustrating, because ford has had this feature for years, and we had been requesting it from toyota for many years before prime came out.
    the engine warm up puts more wear and tear on it than anything else, and is completely unnecessary in many cases.
    i'm currently at 460 miles ev, and 40 miles hv, and many of those hv miles are just from the engine kicking on when i'm only a few hundred feet from my destination.:mad:
  3. HypersonicPrime
    74
    59
    NC, USA
    They could just let us hold down the EV/EV_Auto button or something to engage an "EV Extend" mode and allow the car to use up the portion of HV reserve that it allows while in HV mode. Shouldn't be that hard. I wonder if they are just very conservative and worry that people will use it all the time, shortening the life of the battery.
    49,516
  5. ct89
    ct89 Active Member
    323
    266
    New England
    My view is more of a just chill and enjoy the car.
    The difference between EV and HV is on the order of 1-2 cents/mile.
    Even if Toyota did let you extract half of what's remaining in the battery (you made it 25 miles on 3/4 of the battery so another 1/8 of the battery could get you up to 4 miles), we're talking about something between a nickle and a dime for the trouble.
    Yes, if you save that nickle 200 times a year it is enough to grab a nice free lunch.
  6. bisco
    49,516
    it's annoying, not expensive.
  7. Tideland Prius
    16,159
    Wait so if you're in EV Mode and drain the battery and automatically go into HV mode, it automatically kicks the engine on even if you're light on the throttle or coasting?
    I would think you would be able to stay in EV even if in HV mode as long as you're not heavy on the throttle (And from Gen 4 experience, the leeway before the engine kicks in is quite generous - moreso than Gen 2 or 3)
  8. jerrymildred
    jerrymildred Senior Member
    11,516
    14,120
    Tampa, FL
    What you suggest makes a lot of sense. But from what I've heard, there is no grace period. The PiP is the same unless the engine is already warm.
  9. fuzzy1
    10,175
    Plus, we KNOW that some folks are going to abuse it, possibly creating increased in-warranty battery failures.
  10. bisco
    49,516
    engine fires as soon as ev miles are done. i think it is so there is a buffer during the warm up process.
    jerrymildred and HypersonicPrime like this.
  11. HypersonicPrime
    74
    59
    NC, USA
    I agree. After it kicks on it doesn't seem to immediately rev, but rather warm up at idle speed while some EV is still being used. That's probably part of the reason for not allowing a dip into HV reserve.
    jerrymildred likes this.
  12. bisco
    49,516
    but there's a lot more battery than the hv portion. toyota does not allow the state of charge to ever go below 25% or so.
  13. fredonly
    fredonly Junior Member
    28
    26
    Houston
    I've gotten my battery a little below 25%. I used up the EV range (obviously) and, by driving around 30MPH, it still ran off battery some of the time.
  14. jerrymildred
    11,516
    14,120
    Tampa, FL
    Naturally. Once EV range is used up, it becomes a normal hybrid Prius.
