Just a Rant on wheel bearings
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ALS, Apr 7, 2016.
  1. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Replace both front hubs two weeks ago and today I find out the right rear is going bad.
    58,000 miles and I had to replace three out of four wheel bearings on this car. :mad:
    Service writer didn't look happy when I told him that I was ordering the part online since his parts department wouldn't price match. I made a point of telling him in front of customers that the $130 difference between them and other Toyota dealers who sell online made it well worth the week wait for the OEM part. $327 vs $197 shipped to my door.
  2. Mendel Leisk
    41,933
    Wonder what causes this. Complacence on the part of the dealership I guess. You're waking them up.
    In all our years with Honda I never even thought about wheel bearings. Something strange going on: quality control, bearing style, and more complacence?
    52,408
    seems to be another 2010 problem. bad run?
  4. Kenny94945
    Kenny94945 Active Member
    858
    433
    Sausalito
    2016 Prius v wagon
    What caused the failure?
    Bad run? Driving through deep water? Salt air? Lack of grease? Pressure washing the rims?
    Three bearings at the same time!
    Yes, parts on line can have savings.
    OP is fortunate dealer will install parts not purchase from them!
    I hope the dealer part price is list price and not marked up additionally, that would leave a "bad taste" to me if marked up over list.
  5. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    No they're selling at list. Which in this day and age I can't believe with the popularity of the internet they aren't trying really hard to get business through the parts department. A 10% profit through price matching is better than a zero sale.
    I have a supplier that I use for work and they love it when I show up for supplies. I'm their biggest customer and they will price match anyone online. I'm buying 2/3rds of my supplies for my business, 25-30% below what my competitors are paying. I'm the only one that asks for price matching.
  6. CR94
    CR94 Senior Member
    2,756
    1,208
    Northwestern S.C.
    If none of those, it could be impact damage or overloading. However, reports of wheel bearing failure are so common that I'd suspect more likely defective bearings, inappropiate grease, or inadequate design, whether due to incompetence or corner-cutting to save weight or cost.
  7. FinToy
    FinToy Active Member
    145
    141
    Finland
    I just talked about this with my dealer. They said cars that have less miles per year tend to fail with wheel bearings more often. It seems that the original sealing is not good enough and the (salty) water gets in there ruining the bearing. However the replacement bearing has improved sealing and it should last longer. Also the cars that are driven longer times usually have their bearings in better shape.
    Hope you get the point, English is not my native language.
  8. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    What's the symptom? A lot of noise?
  9. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Yes you get a tell tail whine above certain speeds. As the bearing gets worse the noise starts at lower speeds.
    Mine sounds like the engine is screaming at 4000 plus RPMs at 55 mph even when I'm coasting in neutral.
    It is so bad at 55 mph that the drivers side window resonates or buzzes.
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I am going to guess the cold climate in the Pittsburgh area and salting roads is the primary factor.
    Knock on wood, but I just passed 112,000 miles and have not had issues with wheel bearings. I had mine up on jack stands at 100,000 miles and they check fine.
  11. StarCaller
    StarCaller Senior Member
    1,280
    732
    Cedar Crest, NM, USA
    you got an idea from what year on toyota was using this bearings?
  12. Former Member 68813
    3,524
    983
    US
    very atypical. my experience with bearings they fail over 100,000 miles.
    however, i have one toyota car which required 2 replacements (warranty) because mechanics damaged them while working on a tranny and another toyota car where 1 bearing was replaced (warranty) and it turned out to be noisy tire.
    #12 Former Member 68813, Apr 8, 2016
  13. SHH
    SHH Junior Member
    Upstate NY
    Had local garage replace Left Rear wheel bearing yesterday on my 2010 II with 88k miles on it.
    Has been a problem for over a year - I initially thought noise was due to new tires. Not.
    Based on what I have been seeing in PC - it seems like I can expect further wheel repairs
    in the not too distant future. (Never buy a car in the first Model year. :-/ )
