Just bought a 2008 prius..key, transmission fluid
Discussion in 'Gen 2 Prius Main Forum' started by fomenter, Dec 13, 2019.
  1. fomenter
    fomenter Junior Member
    michigan
    Hi All,
    After years I am back to Prius (as a second car). It is a 08 with 123k, bought it for $3750. The car looks clean, drives nice. However, it only came with one smart key (yes, it has a push button to get in). I searched online and it looks like I can buy it around $100 then need to get it coded (assuming that it is not DIY?). Also, the transmission fluid was never replaced. Should I "drain and fill" after 123k miles?
  2. Kaptainkid1
    Kaptainkid1 Active Member
    308
    247
    Los Angeles
    Yes and only used Toyota Prius OEM fluid. It's not too expensive and can be done with a few tools. Always OEM Fluid for Tranny and gear boxes. Engine oil any synthetic brand is fine.
  3. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    If it makes you feel better, you can change the transmission fluid. It's unlikely to make a huge difference, although it's relatively cheap and easy. Also, if it makes you feel better, you can use Toyota ATF. Valvoline MaxLife is also fine if more readily available/cheaper, etc. but a lot of people worry about using it. I'm not entirely sure why.
    On the matter of the key, as long as you buy a new, "virgin" fob from the dealer you can program it yourself. Look through the second gen forums for a sticky thread about programming keys.
  4. Mendel Leisk
    41,513
    Maybe this:
    I know, everything's debatable. Me, I'll let someone else be the "pioneer", lol.
    dig4dirt and Prodigyplace like this.
  5. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    Mr. Leisk, I know your feelings on Toyota ATF. My reasons for disagreeing are as follows:
    1. I haven't seen anyone show a case of aftermarket fluid-linked transmission failure.
    2. Possibly on BITOG, someone had asked Valvoline if their product was acceptable for Prii. At first, Valvoline said they couldn't yet recommend it for hybrid transmissions because it hadn't been tested. After testing, Valvoline said it was acceptable. If Toyota has a right to say their products will work with such-and-such, Valvoline can also test and find that their products are acceptable for a particular use. Compare to Honda, who says to only use their fluids (all fluids) when we all know aftermarket fluid is just fine. Toyota also says to use all their parts, yet aftermarket can be just as good or better (obviously not in all cases.)
    3. The aftermarket is used to preparing products to meet the performance of the OEM product. If I use aftermarket parts, I feel that aftermarket fluid is similarly acceptable.
    4. While there may be some risk, such risk is minor in an era where transmissions are cheap and readily available.
    I want to sincerely thank you for all your contributions, and just know this is probably the only thing I disagree with you on.
  6. George W
    George W Senior Member
    911
    514
    San Antonio
    Play with your own e CVT, not someone else's. Use recommended fluid from Toyota.
  7. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
