Just bought a 2010 Insight, my review.
Discussion in 'Other Cars' started by adric22, Apr 6, 2009.
  1. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    Okay, I'm seeing a lot of bad information on some of these forums about the Insight, so I thought I'd take a moment to clear things up. First of all, I also used to own a 2003 Prius but it was sadly lost in a traffic accident. So, I can make a good, unbiased comparison of the two cars.
    First of all, I have heard some people refer to the Honda IMA system as a "mild hybrid." I cannot accept that, as there is a huge difference between the Honda IMA and some of the junk coming out of Detroit that uses the word hybrid in their advertising. Those GM and Saturn vehicles are the true "mild" hybrids because their hybrid system does very little in the way of fuel economy improvement. When Honda's fuel economy is darned near the same as the Prius, I don't know how you can refer to it is a "mild" hybrid.
    Okay.. Some people also keep mentioning that the Honda cannot drive on electric power only. This is wrong. I have been driving my Insight in electric only quite a bit. Yes, the engine is still spinning, but all the valves are closed to eliminate most of the engine drag. However, I'll be the first to admit the Prius has a far more aggressive EV mode. For example, the Insight won't take off from a dead stop in EV mode. I suspect this has to do with the fact that the CVT probably has to go into neutral to spin the engine up to operating speed and they probably don't have a good way to smoothly transition between driving around at 5 mph in electric and then moving rapidly to the gas engine. But if you get going about 5 to 10 mph you can slowly let off the accelerator pedal and you will see the screen show the gas engine go into fuel-cut mode and see that only the electric motor is providing power. You can keep it that way up to about 30 mph.
    But the truth of the matter is, driving in EV mode only doesn't really help the gas mileage. So other than being cool (which I will admit, it is cool) it doesn't really do that much for you in the long run. And again, the insights fuel economy competes easily with the prius.
    I also happen to think the car has plenty of acceleration power. It fells just about like the Prius in that regard (somebody on here said they thought it was slow) and if you check the official 0-60 times, the two cars are very close.
    I happen to like the instrumentation arrangement on the Insight much better than the Prius. I like the traditional style of instrument cluster that is directly in front, rather than in the center of the car. The LCD information screen is much smaller in the Insight than the Prius, but it presents most of the same information. there is a button on the steering wheel to scroll through various different screens of information. I actually find it easier to look at in the Honda because the information is right in front of me in the instrument cluster, rather than having to look over at the center console.
    For whoever said the Insight lacks cargo space, I would say it is just about identical to the Prius.. not sure what planet they come from and what laws of physics they were using.
    The brakes feel almost exactly like the Prius, in my opinion. Of course, I had a Gen 1 prius, so most of you probably have the 2004 or newer. Not sure how different they are. Besides coming to a complete stop, I'm not sure the brake shoes ever actually engage during my regular driving.
    And for whoever said something about the Honda system requires the engine to always be running, and consuming fuel.. do some research on the fuel-cut system they use. The little graphical screen that shows if power is coming from gas or batteries shows the engine go into fuel-cut ALL THE TIME. Even on the highway and just about anytime that the car is on a downhill slope the engine cuts out. True, it is still spinning, but if it is consuming ZERO fuel and creating almost zero drag on the car, than I would say that scenario is just as good as the Prius.
    Oh.. and one last thing.. The IMA system is better than the HSD for highway driving. And since I live in Texas and everything is wide-open spaces, that is what is important around here.
    Overall, I'd say the Insight is very competitive with the prius. And whatever people say about the technological differences, when it comes to Joe Consumer out to buy a car, I think the fuel-economy rating and the price tag are about the only things that are going to matter.
    5 people like this.
  2. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    I think the EPA estimates say the Prius (2004-2010) is the better highway MPG performer than ANY current Honda IMA product. Not my opinion, just the standardized test results. Correct me if I'm wrong.
  3. ceric
    ceric New Member
    1,114
    Fremont, CA
    Reviews from various mags have put the mpg between Gen-II Prius and Insight very close to each other.
    adric22, thanks for your review. If you owned a Gen-II before, your review would be even more interesting to me. Thanks, nonetheless.
  4. thedutchtouch
    thedutchtouch prius is my SUV
    181
    Baltimore MD
    nice! welcome, and i look forward to reading more about your car
    the term mild hybrid simply comes from the way the drivetrain is designed. it's a "mild hybrid" because the ICE (internal combustion engine) never shuts off, ie the car cannot be propelled under only electric power. While the term hybrid has been somewhat stretched (ie malibu) it doesn't negate the fact that the insight is a mild hybrid. When people use the term its just describing the technology in your car, not necessarially trashing it.
    its still technically a mild hybrid. a VERY well designed one however
    true on most parts. although the prius can with the right drivers/conditions outperform an insight simply because it CAN turn the ICE off at stoplights, etc.
    sounds good, i was surprised myself with how "peppy" the prius was, i wasn't expecting much.
    i would say almost, but it's close, probably too close for the average driver to produce a difference
    ok. sounds like you made the right choice for your situation
    i agree on this last point. well written comparison, but i'll warn ya- you're going to run into a lot of Pro-Prius people on here (including quite a few with knowledge/experience/info to back up thier opinions)
  5. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    If you've read any of my posts on the Insight, you'll see that I'm a big Honda fan and I hope the Insight does well. I say that just to establish I do not have a bias against either the car or the company.
    I am very happy for you that you are pleased with your new Insight! It is very unfortunate you had to lose your Prius as you did, but the benefit to you is the chance for a newer car. With that said, however, I think your Insight, though new, is not the latest technology. There is no need to be on the bleeding edge, but for purposes of comparison, I think it will be difficult to compare the new Insight with the 2010 Prius.
    Perhaps the new Insight compares favorably with the Gen I Prius, but the Gen II Prius was such an improvement over the original, that your comparison starts to fade a bit. The 2010 is a significant improvement over the Gen II, so I will beg to differ with some of your comparisons.
    Still, I am very glad to hear of your enthusiasm for the Insight, and I am hopeful it means the car will find a solid following.
    I'm certain there will be a number of posts in this thread pointing out the technical superiority of the 2010 Prius (much of it is likely to be true), so I'll try to stay away from those responses. The critical things you've pointed out have to do with the look and amenities of the Insight which differ from those offered in the Prius. These differences should provide both some healthy competition and a greater opportunity for more people to be satisfied.
    I, for one, am much more interested in driving a full hybrid where I can not only drive in EV mode, but also glide without having to deal with a constantly spinning ICE. Yes, in the Prius the ICE still spins at higher speeds, but at 41 mph and lower, you really can save enormous energy by just coasting. Not only that, but every time I sit at a traffic light or a drive-through, or simply in a parking lot, I can experience a pollution-free idle!
    I also like the high-tech end of things, so the Prius, in this regard, is much more attractive. I would like to have all the gadgets (if I can afford it), and I am not comparing the pared-down models of both cars. We'll have to wait and see how Toyota prices the base models, but I would guess Toyota will work hard to be not much above the Insight. In that case I think you'll find that the MUCH higher MPGs in the Prius will make the purchase price difference go away very quickly.
    I've said many, many times in this forum that the best way to go about minimizing dollars spent on a car is to buy a Honda. Not a new Insight, but a used Civic. Perhaps the Insight will, eventually, fill that role, but for now a hybrid doesn't offer the best car purchase in terms of simply lowest dollars spent.
    In sum: Congrats to you! Enjoy your Insight and feel good about driving a car you've chosen for its style and peculiarities. I'll do the same as I scoot around in my '07 (for now) Prius. We are both helping move forward not only the technology, but also the social acceptance of the hybrid drivetrain (drivetrains?).
  6. Spin359
    Spin359 Junior Member
    El Paso, Texas
    The Engine always has to be in motion. burning fuel or not, without the dead weight the electrics would do better. The EV mode not being as effective does make me question it. According to several reviews (consumer reports, Car and Driver, Cars.com and people here that have driven some of each) the prius is still the best hybrid out there mileage wise, the insight at 41 and the new prius (15 inch tires) at 50. I like the insights instrument cluster better but a friend of mine said that it looks like it was designed by a drunken WWII Uboat commander.
    I am going to try them both out, and i loved the old Insight but i think i'm going to foolishly trade in my 07 prius for a 10. something about a perfect 10 i always liked...
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Hey thanks for the details of the new Insight. That's why it is better to describe IMA, ASSIST hybrid.
    Some of the facts you can not get around with the IMA system in the Insight:
    - The electric motor is rated at 13hp max
    - The HV battery pack has 2.5x less energy than the Prius
    - Very limited regen braking due to 13hp motor/generator
    - I don't think it has electric A/C due to anemic battery pack
    - Limited Stealth mode (EV mode requires ICE at 0 RPM) due to anemic battery pack
    You could probably have gotten 09 Prius (with year end model incentives) for less than the Insight.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Thanks for the review. I hope you will stay around and provide more information and answer questions.
    As pointed out above, it's too bad you didn't have a Gen II Prius before, as there are major improvements with the Gen II. To be completely fair, we need the 2010 Prius to compare to your 2010 Insight.
    Tom
  9. a priori
    3,083
    408
    23
    Chicagoland (West)
    I'd like to second the thanks and the request you stay around to respond to questions (not necessarily the barbs!) and offer your views of the new Insight.
    To the OP:
    Even if you could have gotten a 2009 Prius for about the same price, if the Insight is a car you're going to enjoy more, then more power to you! Too many of us are just wildly stuck on that perfect Prius parked out front of our homes, so please be patient with us!
    I doubt you'll convince me the Insight is better than my '07 Prius, much less the 2010, but don't worry about it. Heck, don't even try -- I'm just too much of a Prius fan! But I'm really a nut about getting rid of the useless waste of the standard ICE-driven automobile, and when a great company like Honda makes such a strong commitment as its new Insight, I'll be cheering for it to become the #2 selling hybrid in the U.S.
  10. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    That issue with "mild" and "electric only" stems from the size of the motor itself...
    10 kW = 2010 Insight
    33 kW = 2003 Prius
    50 kW = 2004 Prius
    60 kW = 2010 Prius
    ...the rest comes from the ample supply of electric available from the more active hybrid system, allowing the electric A/C to take advantage.
    Insight is exactly what Honda labels it as, an ASSIST hybrid. That's the "A" in IMA.
  11. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    I think if something were to happen to my shiny new Prius, I would go test drive an Insight. I definitely like the instrument layout.
    Regarding the Insight, I think it does what Honda wants it to: Gets great fuel economy and is relatively simple and thus inexpensive. I did expect the price to be about $1k lower in the US. Regardless, I hope it does do well.
  12. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    You're correct. It's also true on the Prius.
    However, there is a big advantage on the EV mode switch. The 2010 Prius and the modified Gen-II have the switch which is able to move the car on parking lot without engine starting, especially good late at night or early in the morning in the residential area.
    Ken@Japan
  13. msirach
    msirach Member
    321
    Southern Illinois
    Thanks for the great informative write-up!
    One point not credited to the Insight is the Blue/Green fade feature of the instrument cluster that makes it a "no brainer" for anyone to keep the Insight in an efficient operating mode. All you have to remember is: Green is Good, Blue is Bad.
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    EV mode improves MPG during less than 15 mph traffic jam in stop and go traffic. It is better to recharge the battery later when cruising at 50-60 mph than turning engine on and off during the jam.
    EV mode is also very useful to move your car for parking or drive up the ramp to change oil.
  15. MSantos
    MSantos EcoAccelerometry
    588
    257
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    As far as the EPA is concerned I believe you are correct.
    However, just as the Gen 2 Prius had the same rating as the Gen 4 IMA on the highway, the community quickly found out that the IMA system was able to achieve much more that what it was rated for.
    Now, early indications from expert test drives is that that particular situation still remains when comparing the 2010 Insight and the 2010 Prius. The Gen 3 Prius is now much better than the Gen 2 on the highway but apparently not yet enough to conclusively and definitively take down a 2010 Honda Insight. I can't wait to hear more from the experts or to live with a 2010 Prius to really confirm this.
    In any case, I am hoping that we can find an "Easter Egg" mode or behavior on the 2010 (a new SHM) as I think the car is worth a heck of a lot more than what the EPA estimates. ;)
    Cheers;
    MSantos
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Under ideal condition (Spring) the mpg gap between the 2010 Insight and 2010 Prius may be small.
    Let's wait until the heat wave and snow flakes arrives. There is no secret that 2010 Prius was designed from mpg tanking in extreme temps. We will have to see how well it does all year round.
    I believe the Insight has belt driven A/C and a tiny battery pack. Let's see how well it does in 100 deg F stop and go traffic of 10 mins duration.
    The Insight has no way of retaining (thermo bottle) or recovering the heat (EHR) otherwise lost to the environment. Let's see how the Insight does in the Winter traffic jams or short trips with the heater on.
    In the previous generations, hybrids were launched in Fall and the reviews roll in at around Winter. It looks like Honda and Toyota learned from that this time. The Insight has more advantage because it is smaller and lighter.
    I think the Prius' "Easter Egg" is in the extreme temps rather than in ideal temp. Well, I hope we find another egg in ideal temp as well.
  17. MSantos
    588
    257
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    Totally agree. Much of this still remains to be seen through the work and observations of many in the community.
    However, lets us also apply what we already do know and move on from here, and that is that an IMA equipped car will never be able to beat an HSD vehicle on a traffic jam condition under ideal temperature conditions. This is one area where our experience backs up the paper specifications. Add heat or AC and it will be carnage.
    The situation changes somewhat when the ambient temps and commute distance force more frequent ICE idling. At this point the contest is much tighter and something that has been traditionally a win for the IMAs. Toyota knows this has been a sore spot with the Prius II and one that we know has been radically addressed in the 2010 Prius... What remains to be seen is how much FE potential that translates into in the hands of experts and common folks alike. But, I have no doubt the design changes will make the 2010 Prius THE stand-out performer in low ambient temp conditions if not the absolute best. ;)
    Yes, the battery pack is smaller on the Insight but unless you are always deadlocked in a traffic jam routine, keeping off the pack remains the best way to achieve higher MPG and lower emissions in just about any hybrid on the road today. The ICE remains the primary power source and avoiding a forced charge at any cost is still the best we can do to minimize losses. It just amazes me when people WANT to run on electric each and every time and then complain the FE is not high enough. :(
    By "Easter Egg" I was referring to the discovery of a sweet spot in the highway FE/Speed range that takes the Prius III though the FE roof. Similar to what the SHM (Super Highway Mode) technique did for the Prius II but in an easier way to lock and over a wider range of speeds.
    Cheers;
    MSantos
  18. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    glad you are happy with your car. if you do something that greatly increases your mileage, i dont care what you drive. i wish you had experience with the Classic Pri's so a better comparison could be had. by all accounts, the 2003's and 2004+'s were hardly the same car in any respect.
    definitely keep us posted on your experiences
  19. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    A poster focused on narrowing gap under ideal condition. I was pointing out the wider gap when the conditions are not so ideal. The A/C and battery pack got worse in 2010 Insight compared to 2009 Civic hybrid while the Prius made improvement.
    Yes, it is the best not to have traffic jam at all but that is not how the real world traffic works. I am going to stop here because it is going back to ideal condition topic.
    There may be a few lucky ones that have close to ideal traffic everyday. However, that market will be much smaller and we know 2010 Prius is designed to attract a very wide range of buyers.
    I would think so since the ICE has more torque to maintain wider range of speeds without having HSD out of the heretical mode.
  20. adric22
    642
    146
    Fort Worth, TX
    I'm not sure what happened to my reply I posted this morning, but it never showed up, so I guess I'll have to write this all again.
    As the original poster of this topic, I think I should clarify some things.
    First of all, I was never attempting to say that the 2010 Insight is better than the prius. I was mearly trying to say that it is in the same class as the prius. I will agree whole-heartedly that many of the domestic cars that slap the name "hybrid" on the back are called "mild hybrids" because those generally do not even assist the car, they do little more than start and stop the engine. I consider the Insight a "full hybrid." I think parallel vs. serial hybrid would be a better choice of words to use when describing the Honda IMA vs. the Toyota HSD. I do believe the Prius has a more advanced and perhaps even desirable hybrid system, but sometimes you have to look at the whole package.
    Now, lets talk a little bit about this small 13 HP electric motor that the Insight has. I keep seeing a lot of comments about how small it is, and that it can't possibly handle any decent regen braking or give much accelleration.
    I didn't mention this in my previous post, but besides having a 2003 Prius, I also built my own EV from a 1993 Eagle Talon. I did all the work myself and built a pure EV that can drive about 20 miles and gets up to about 55 mph (under ideal conditions) Guess what? The HP rating on the electric motor was 10 HP. That is right, a 10 HP motor was the only thing in the car and it was sufficient to move the whole car, which due to those lead-acid batteries, end up weighing more than the Insight.
    So does that shed more light on the 13 HP motor used in the Insight? Lets also keep in mind that Honda doesn't need as big of an electric motor because they have a transmission between the IMA and the wheels of the car. True, the Toyota system has a transmission too, but it works much different. The electric motor can be used to affect the gear ratio being applied to the gas engine through the planetary gearset. But, what about MG2? When that motor is propelling the car and the gas engine is off, there is no way to adjust a gear ratio for that electric motor. So the motor has to be more powerfull to move the car from a standstill. In the Insight, the CVT transmission will just gear down to give more power. Take my EV I built, for example. If I had tried to take that 10 HP motor and make it a direct-drive, it would have had trouble moving the car. Fortunately, I could put the car in 1st gear to start moving.
    As for regen, the insight uses regen for the vast majority of braking. To engage the brake shoes I have to literally stomp on the brakes like I'm about to have an accident or something. So regen works very well on the insight, despite 13 HP motor.
    And one last thing to keep in mind. An electric motor's HP rating is usually associated with the voltage it is being fed. The Prius is a much higher voltage than the Insight, which probably affects the motor's HP rating, even if the motors were of similar physical size.
