Just changed oil but indicator notice came on.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mitchellsprius, Sep 28, 2009.
  1. Mitchellsprius
    Mitchellsprius New Member
    91
    monterey
    How do you turn the notice to change oil off? Did the Toyota tech forget something?
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Just because the oil is changed the system does not 'realize' it was changed. I don't know the procedure off hand (sorry), but it is in the manual. You just put the car in accessory and hold down a button, something like that, it is really simple.
  3. jaywolf
    jaywolf Member
    107
    Vincennes, IN
    Set the odometer to trip A
    Turn off car.
    Hold in on the MPH/Kilometers button and push the power button-
    hold both buttons till it is reset.
    You will see a scale til service going from right to left.
    when it is totally to the left let go.
    Your done.
    The reminder info in the GPS must be set seperatly.
    This is off the top of my head but I think it is correct.
  4. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Yep, took me 30 minutes to find this in the Prius manual, pg.420. after about 29 minutes, I was getting steamed because I just knew it was a Toyota service reset only. Of course my blood temp came down after I finally found it.:cool: They could have been a little more forthcoming about maintenance data and give a page link.
  5. Mr. Bill
    Mr. Bill Generation III
    86
    222
    Dunedin Florida
    Hello - Hold in on the MPH/Kilometers button and push the power button (make sure you hold down the brake pedal)
    It should take about 2 seconds to reset.
    Enjoy - Mr. Bill :)
  6. Mr. Bill
    86
    222
    Dunedin Florida
    How do you reset the oil change indicator scale ? [​IMG]
    First
    - you need to hit the trip indicator button until you have "trip A" indicated in the display (I use this at re-fueling times)
    Next - you will need to push the park button then the power off button - yes you will need to fully turn off the car.
    Next - locate the MPH/Kilometers button on the dashboard. Press and hold down and then restart the car by pushing the power on button (hold both buttons down at the same time - when the scale is re-set, let go of both buttons)
    Verify by looking at the scale indicator :cheer2:
    I believe this is correct - good luck.
  7. Mark57
    2,945
    2,740
    OK
    Or you can do as a lot of us have done and download the manual as one big PDF file. It's searchable.:D See this thread by Boo
  8. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
  9. Carleff
    Carleff Junior Member
    Alameda, California
    So many wrong answers! Does anyone read the Owner's Manual even when they know the answer is there?
    When the system power is ON, cycle the OD/Trip Mileage until it reads OD. (Folks, that is the total miltage/km used on the car since new.)
    After that, turn the Power off. Then, while pressing the Trip/OD button turn the Power back on while holding in the button. Keep pressing the button for a few seconds until the Engine Service icon turns off.
    Simple. I can't believe someone suggested doing this while pressing the MPH/Kph button which has nothing to do with distance.
  10. damack1
    damack1 Member
    123
    25
    Huntsville, Alabama
    Page 429 of the Owner's Manual:
    The oil change system should be reset. Perform the following steps:
    1. Turn the "POWER" switch to OFF with the trip meter A shown.
    2. Turn the "POWER" switch ON with the MPH or km/h button held down.
    3. Keep pressing the button until the odometer indicates "000000" and the multi-information display indicates that the reset is complete.
  11. Judgeless
    1,821
    257
    Cleveland, OH
    On the 2010 they changed they way it is done. Your method works for 2009 and lesser years. It does not work for 2010.
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    did your tech log the oil change into your maintenance log??
    **edit**
    oops, just saw you have pkg 3...nm. on Pri's with MFD, there is a maintenance log that is available that allows "someone" to enter a maintenance schedule and actions. i was wondering if just entering that info in will reset it automatically.
    i am a few hundred miles away from my first oil change. will definitely have to check that out
  13. Grateful11
    Grateful11 Member
    107
    Central, NC
    Here's my 2 cents worth: What good are Oil Life Monitors unless they're smart enough actually detect when oil needs to be changed.
  14. fuzzy1
    10,483
    Will this reset TripA and TripB? Or was that an 'extra free' service performed by the technician?
    I had to get an oil change during a very long road trip vacation. Free item #2 was to fix my 'dangerously high' tire pressure (highway temperature at elevation of 6225 feet), by letting out enough air that they became UNDERinflated when cold after descending to sea level. Free item #3 was a giant wad of used and oily chewing gum added to the carpeted floor mat.
    The price was good, $51 including the right weight oil. But I'd rather pay extra to avoid the three free unwanted services that they included, so the next mid-trip service will have to be through a different shop.
