Just changed the spark plugs in my Prius prime 2017
Discussion in 'Prime Main Forum (2017-2022)' started by Pdxprimeguy, Dec 13, 2019.
  1. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    Here’s some pics of the old spark plugs. It took me 1 hour to do it myself. Easy job glad I got it done.
    3CBD586F-A16C-4D93-87DD-98CB3F4C021B.jpeg 3FB4C561-8FE8-4E4A-A612-13582ABF7F3E.jpeg 403ECAE8-FF94-4C2A-B8DA-4C1A410AAF50.jpeg 75E2C2D4-67CD-4628-9AAC-4371C93510BC.jpeg 1725654A-8DF1-419A-B59B-331177C11076.jpeg
    Raytheeagle and Mendel Leisk like this.
  2. Mendel Leisk
    41,163
    No need to remove wipers? (y)
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    What’s the actual mileage on those plugs?
    What’s your lifetime mpg?
  4. Mendel Leisk
    41,163
    And most importantly: what do for a living, pull nails with your bare hands?
    I'm pushing 70 and my pinkies look all smooth. :oops:
    Raytheeagle likes this.
  5. Salamander_King
    Salamander_King Senior Member
    11,013
    8,942
    New England
    Wow. Already? I have at least 5 years to go, but good to know it's easy DIY.
    jerrymildred and Raytheeagle like this.
  6. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    A workin man;).
    I sit around a table or at my desk most of the day:).
    Not a bad gig, but it isn’t always peaches and cream(y).
  7. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    Hands are old. But I am 43, Lol. I have 95,000 miles on them. I only had to remove the larger windshield wiper. It’s easy to remove the wiper. Took me 1 hour to complete.
    here is the link to a short video I just uploaded on YouTube.
  8. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Thanks for the video:).
    What’s the lifetime mpg:whistle:?
    Haven’t looked in the manual in awhile, but the gen3 plugs were to be changed at 120k miles. Is it the same in the Prime and if so, any reason for changing them early?
    Hope the drive afterwards didn’t show any issues(y).
  9. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    life time MPG is 63. I charge 1-2 times a day but have long drives. No issues so far. If there’s any problems will update. I always like to stay on top of replacing my plugs. No issues. Just wanted to get it done and over with. Transmission fluid change is my next big project. I need this car to last at least 300k
    bisco and Raytheeagle like this.
  10. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    The trans drain and fill isn’t bad at all;).
    Getting the car up to work on it is the biggest challenge:cool:.
    I changed the trans fluid in our 2019 Prime at 4 k miles and will do the same somewhere around 50-60k miles most likely:).
    I’m a piece of mind guy myself(y).
  11. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Great idea to put the wrap of tape on the extension so the socket stays attached instead of sticking on the plug. By the way, if you ever need to use a universal socket and the universal it too floppy, a wrap of tape around it can make it more controllable.
    MTN, Pdxprimeguy and Mendel Leisk like this.
  12. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    Only 1 hour? That's a lot better than on my 2013 where it seems you've got to do a lot of disassembly just to get to the plugs.
  13. Mendel Leisk
    41,163
    Plus one on taping the spark plug socket to the extension. Especially with a new socket with real grippy rubber insert: torque the spark plug carefully, pull up, see the socket's still down there, and the only thing to do is to back it out. :cry:
    Pdxprimeguy likes this.
  14. mister2cool
    mister2cool Member
    98
    51
    New Jersey
    2020 Prius Prime
    wow those are some really oily plugs. Is this normal for Prius? I have never seen plugs out of Prius but all the ones I have done in the past never came out in that color.
  15. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Hmm... I thought the electrodes actually looked pretty decent, not carbon fouled or burnt. As a thrifty old gear head (translation: cheap SOB shade tree mechanic), I've cleaned, re-gapped, replaced compression washers and re-used worse looking plugs.
    scona likes this.
  16. mister2cool
    mister2cool Member
    98
    51
    New Jersey
    2020 Prius Prime
    Yes the electrodes do look pretty good. It's brownish stain in the threads I am a bit puzzled about, looks like a good bit of oil was deposited there.
  17. Gokhan
    Gokhan Senior Member
    6,061
    2,402
    Paramount CA
    Plugs are looking good, only minor wear and deposits. There is no oil. When there is oil, it doesn't dry up -- it stays wet on the threads.
  18. jrodz09
    jrodz09 Junior Member
    42
    22
    Visalia
    Crazy. Tracking the manual has them due for change @ 150k. I’ll wait. Lol
  19. Mendel Leisk
    41,163
    Miles? 120k IIRC. Or 10 years.
    Mambo Dave likes this.
  20. jrodz09
    42
    22
    Visalia
    I stand corrected. It is 120k. That 150k is for a PZEV. I’m at 83k. Got some time to go. Lol
