Just changed transaxle fluid for the second time
Discussion in 'Gen 2 Prius Technical Discussion' started by gone2green, Feb 3, 2013.
  1. gone2green
    gone2green grumpier than the grumpiest old man you know ;)
    117
    17
    Mesa AZ
    2015 Prius v wagon
    I have changed the transaxle fluid the first time at 65k miles now again at 127k but this time a little more went in. I did not use the complete 4qts but real real close to it. Will that be a problem?
    it was running out of the fill hole when I screwed the plug back in . So I know it is full to the hole, but the car was leaning to the rear just a bit. Would that make too much of a difference?
    it runs and drives fine just curious as if I need to drain some.
  2. Patrick Wong
    18,200
    6,472
    No problem. Relax and enjoy your success.
    Merkey likes this.
  3. gone2green
    117
    17
    Mesa AZ
    2015 Prius v wagon
    Thanks Patrick, I will be able to sleep tonight and not in fear of my wife chopping my head off cause I screwed up her car she loves.
  4. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    How was the fluid that you drained compared to the fluid from the first change.
    John (Britprius)
    PriusGuy32 likes this.
  5. gone2green
    117
    17
    Mesa AZ
    2015 Prius v wagon
    It was a dark brown red no flakes of any kind, and it had a little powder on the magnet on the drain plug.
  6. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Just changed mine w/ 71,560 miles on the odo. Old fluid, as noted above, dark brown w/ no metal shavings.
    DBCassidy
