Just cleaned the egr valve
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tankyuong, Jul 25, 2021.
  1. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Egr valve and cooler was dirty but not clogged at 190k miles
    ETC(SS), Mendel Leisk and bisco like this.
    49,498
    does the c have a better engine design?
    edit: nevermind, i saw the c forum instead of your model car. :oops:
    that is great for a 2010.
  3. tankyuong
    1,555
    660
    Central MO
    2012 prius c has bigger holes so doesn't clog as easy
  4. farmecologist
    farmecologist Senior Member
    1,950
    1,786
    Southern MN
    Good to know!
    So do you have a Prius C or not? I'm confused by some of the comments above...(y)
  5. tankyuong
    1,555
    660
    Central MO
    I have a 2012 prius c , previously owned a 2010 prius gen 3
    farmecologist likes this.
  6. farmecologist
    1,950
    1,786
    Southern MN
    Ok that's what I thought. Might wanna change the "2010 Prius" that shows up in your profile info though. I think that is why some weren't sure. (y)
    Raytheeagle likes this.
  7. tankyuong
    1,555
    660
    Central MO
  8. PriusII&C
    PriusII&C Active Member
    370
    129
    San Jose, California
    Where do you refer the "bigger holes" to? Did you clean the EGR passage in the intake manifold?
  9. tankyuong
    1,555
    660
    Central MO
    Holes inside cooler where exhaust flows through,checked the intake manifold and was clean
  10. farmecologist
    1,950
    1,786
    Southern MN
    Interesting..so the inside of the EGR cooler on the Prius C has bigger passages than the Gen3's do? If so...that is an important piece of info. You happen to have a picture of it? (y)
  11. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Yes, as a 2011 Gen 3 hatchback owner who is currently cleaning an EGR cooler sourced off of eBay, with unknown number of miles, but totally blocked passages, I'm also very interested in seeing any pictures you might have.
    Here's a picture of the EGR cooler before cleaning.
    Raytheeagle and Mendel Leisk like this.
  12. burrito
    burrito Active Member
    274
    114
    You don't suppose the Prius C part could be used on a Gen 3 non-C?
  13. xliderider
    7,869
    3,116
    Honolulu, HI
    Highly doubtful, physically, they are very different looking.
    burrito likes this.
  14. Mendel Leisk
    38,728
    What was the miles again? Excellent pic btw.
  15. xliderider
    7,869
    3,116
    Honolulu, HI
    That's the one off eBay with unknown miles on it. I still haven't tackled the one on the car.
    I'll take a picture of it when I get it off.
    My guess is that the eBay one pictured came off a high mileage Prius that blew a head gasket. I'm hoping our EGR cooler doesn't look like that at about 125k miles on the odometer.
  16. Mendel Leisk
    38,728
    Probably not. That's around the miles @NutzAboutBolts did his, and made the video.
    xliderider likes this.
  17. Danny13pruisc3
    173
    27
    maryland
    So basically this post is in the wrong forum.. you're doing a gen 3 not a c correct?
  18. xliderider
    7,869
    3,116
    Honolulu, HI
    The OP used to have a Gen 3, now has a Prius c.
  19. xliderider
    7,869
    3,116
    Honolulu, HI
    Here's the EGR cooler I took off the Gen 3 with 124k on the odometer. Third pic is the EGR valve, oily and sooty, wipes off easily.
