Just got a HV system message. Is there anyone understand japanese?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by erdenee, Oct 18, 2018.
  1. erdenee
    erdenee New Member
    Mongolia, Ulaanbaatar
    I'm seeing this message for 3 days.But i'm able to drive my car(prius 2006). Still can't find anyone that understands japanese kanji. Can anyone help please? 44194830_408140296389859_6987743264665239552_n.jpg
  2. Tideland Prius
    16,165
    ! Warning
    HV System
    Details will be displayed when vehicle is stopped.
  3. PriusCamper
    PriusCamper Senior Member
    11,119
    4,529
    Pacific Northwest, USA
    You could be doing way more damage to your car by continuing to drive it. Just because you don't speak Japanese doesn't mean you should ignore it and keep driving. Once the error codes are read you can make an informed decision about waiting for repairs or driving more.
  4. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    Look into a compatible OBD2 reader for this vehicle, then you (or the mechanic) won't need to learn Kanji (y)
    Raytheeagle likes this.
  5. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    My speculation is the inverter pump has failed.
    HOW TO CHECK INVERTER PUMP:
    1) Prop open engine hood.
    2) Open inverter reservoir (that opaque coolant container, next to the big square silver thing in the middle of the engine compartment).
    3) Visually look inside the inverter reservoir. NOTE the calmness of the coolant inside this reservoir.
    4) Make the car IG-ON or READY.
    5) Visually look inside the inverter reservoir again. Do you see fluid movement? It should have a flow rate like a calm tranquil stream.
    6) If it is quiet enough, you may even hear the inverter pump; its sounds like an aquarium air pump.
    7) DO YOU SEE FLUID MOVEMENT in the inverter reservoir? Do you hear the inverter pump? If yes (fluid movement), Inverter pump is GOOD. If NO (fluid movement), inverter pump is bad and needs to be replaced.
    A failed inverter pump will produce different symptoms (ie A/C shutting off) and the same warning icon, with English
    ( [​IMG] ) on the MFD (Multi-Function Display) in the top left corner, when the inverter begins to overheat.
    #5 exstudent, Oct 19, 2018
  6. exstudent
    2,214
    901
    Torrance, CA
    You may want to download an English version of the Prius Owners manual. Try the Toyota UK site, as the UK Prius will be most identical to your JDM Prius; My Toyota | Toyota UK
    As a back-up, try Toyota USA; but there are some differences between a USA vs JDM Prius, besides left vs right hand drive position.
    Toyota Online Owners Manuals and Warranty
    If don't already have mini VCI w/ Techstream, get it.
