Just got a new 2012 C and getting 35/45 mpg
Discussion in 'Prius c Fuel Economy' started by Zindel, Jul 15, 2020.
  1. Zindel
    Zindel New Member
    i’m new to the prius world and just got a used 2012 C with 46,000 miles
    the cruising range has been 320miles the first two times i’ve filled it and it seems like everyone else is getting fantastic high numbers whereas mine aren’t anything to rave about and the difference in gas consumption vs my previous 14’ hyundai elantra is basically the same
    is there something i need to do or fix?
    i feel like the numbers should be higher
    thanks for your help in advance! :)
  2. Tideland Prius
    16,125
    Yeah, the numbers should be higher... at least 40mpg and 50mpg if you're good (especially since you're in FL with no hills)
    • Check your tyre pressures and make sure they're at least factory spec (see driver's door jamb or owner's manual for PSI values)
    • Check wheel alignment at dealer/service shop (like Jiffylube)
    • Check engine oil level to ensure it's not overfilled
    • Drive in "D" and not "B". "B" is for engine braking and if you use that in the city, the engine will idle at a stop instead of shutting down.
    • Blasting the A/C (which uses the hybrid battery), drains the battery and thus the engine has to come on to top up the hybrid battery
    Aaron Vitolins, Zindel and bisco like this.
    49,371
    congrats!
    florida: keep the a/c high for battery health, but low for mpg's. not much you can do.
    what is the cars history?
    what is your average driving like?
    what are the mpg's as measured at the pump?
  4. Zindel
    Zindel New Member
    unfortunately i’m not sure of the cars history, it only had 46k miles but the inside shows a LOT of wear that i’m working on fixing. in the beginning my driving wasn’t the best because i’m used to driving regular cars and i’d tend to accelerate quickly at a light and then cruise from there but i’ve been changing that. And each time i fill the tank the cruising range is about 310, and since i’ve had the car my avg mpg is 37
  5. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Congrats on your Prius purchase!
    Are you calculating the mpg of 37 by the 8.5gal capacity and the 310~320 cruising range on the display?
    If so, it is not an accurate way.
    Please make sure to calculate by resetting a trip on odometer, or writing down odo miles at a fillup.
    Then during next fill up divide the total gallons into the total miles since last
    i.e. 320mi/7.2gal=44.4mpg (just as an example)
    Sorry, not sure if you already are calculating it that way or just judging off the "cruising range"
    post was not fully clear.
    I can drive many miles past 0 on the cruising range, which would skew those numbers, and makes it irrelevant
    bisco and Zindel like this.
  6. Leadfoot J. McCoalroller
    7,133
    6,682
    Pennsylvania
    2018 Prius c
    Check the battery cooling fan.
    As a very general rule, the more the hybrid battery can participate, the better the MPG. The computer will automatically limit the battery's participation for various reasons including, but not limited to: temperature, recent actual usage, state of charge, and stored trouble codes.
    Many owners forget to clean the battery cooling fan and the air tubes connected to it, so it is worth checking on a newly acquired secondhand Prius, and make a habit of cleaning it annually. More often if you transport furry pets.
    A mismatch between the odometer reading and the interior condition is a strong sign of odometer fraud. Hate to mention it, but I think it has to be considered.
  7. bisco
    49,371
    by driving, i mean how long is your commute, and side trips. highway vs city, average speeds and etc.
    this all can have a lot to do with mpgs. prius don't get 50 mpg under all conditions.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    "Cruising range" is just a wild estimate and is not a useful number for determining gas mileage.
    Can't have a meaningful discussion about gas mileage without knowing HOW you arrive at your numbers.
    Assuming that you are using what the onboard computer tells you, are you resetting it at each fillup ?
    If not, you should as long term numbers can be deceiving.
    Then.....a LOT depends on your usage and driving habits.
    IF.....your normal driving routes are less than ideal, that is a LOT of stop and go or a LOT of high speeds.....your mileage will suffer.
    I can occasionally get my C to tell me that my mileage is a bit above 50 IF I happen to be able to "cruise" around 50 MPH for a fairly long time. But most of the time it is in the mid to upper 40's.
    My '13 was like that too.
  9. Zindel
    Zindel New Member
    i cleaned the battery cooling fan and got an oil change then definitely saw a slight increase in numbers. i also learned that the car was sitting on the lot for at LEAST two months before i got it which i think would explain why the numbers weren’t that good at first but as i continue to drive everything keep getting better. slowly but surely. for example, on the ecoscore it would take a while for the battery indicator to get full but now it gets full really fast.
  10. Zindel
    Zindel New Member
    I reset after each fill up but the mileage is slowly getting better as i drive the car more. my commute is 20-25 minutes with an obnoxious amount of stop and go and side trips range from a trip to the store or a trip across the state so i didn’t expect the mileage to be too outstanding but it’s definitely getting better. and after seeing that the cruising range isn’t the best way to determine the mpg i’ll be determining that with the next few fill ups
  11. rjdriver
    rjdriver Active Member
    406
    167
    Rhode Island
    37 mpg sounds just about right for 20-25 minutes of stop and go with AC on, especially if it involves traffic jams. That sounds just like the the conditions Consumer Reports uses to simulate their "city" driving mpg test, and they rated the 2012 C at 38 mpg City. Other than what you have been doing like making sure all maintenance is up to date, cleaning battery fan cover/filter, and adjusting your driving techniques, there isn't too much you can do to improve that situation.
    If you have the opportunity, check your MPG on a trip of 20-25 miles or so on back roads where there's hardly any stop and go and not too many hills, where you can stay in the range of 30-50 mph for most of the trip. Watch the ECO Score gauge on the dash and try to keep it in the lower half as much as possible by using a light foot on the gas. If you don't measure better mileage there, say 45-65 mpg, then something is wrong somewhere. A 2012 C with only 46,000 miles is a rare find. so it you don't get better MPG in the above situation Leadfoot's suspision about the low miles and the worn interior is worth considering. If not odometer fraud, at the very least, a considrable lack or care for the vehicle overall.
