Just got back from an oil change at the dealership. Here is what they want to do to my Prius
Discussion in 'Gen 3 Prius Main Forum' started by Freeze Time, Feb 24, 2025.
  1. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    2015, 91,200 miles. Oil change was only $10.39. Which things should I get done ASAP and which ones can wait? Obviously, I will be taking the car to my mechanic and not paying these prices
    #1 Freeze Time, Feb 24, 2025
  2. Hayslayer
    Hayslayer Active Member
    404
    231
    if you already paid $110 for an engine air filter and cabin air filter.....you're asking too late.....
    what in the world did you do with the car that you lost both inner wheel- well covers and the bottom underside cover? Did you have some type of off-road excursion that caused this damage?
    Merkey likes this.
  3. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    Huh? These are all the issues they found with my car. Nowhere did I state I paid them and even have that I will take the car to my mechanic and see what he says right in my OP. I can put in a new engine and cabin filter myself. I am more worried about the axel and hybrid cooling system and other stuff out of my league. The fender liners just came off while I was driving. It was a crappy job from the previous owner to wherever he took the car to get fixed. I bought it salvaged so the accident he was in needed new liners and so now they have fallen off and I have none.
  4. bettergolf
    bettergolf Active Member
    489
    368
    Sanford NC
    That's why they change your oil for $10.39....so they can "find" all kinds of things you "need" before your car falls apart.
    My 2915 has NO under covers at all and I've been driving it for 8 years like that...no problem and the oil changes are much easier too.
    Stay away from the dealership........all these prices seem exceedingly high for what you can have it done for elsewhere.
  5. Tombukt2
    Tombukt2 Senior Member
    12,995
    2,329
    Durham NC
    You can do all this with aftermarket parts for near nothing The wheel well liners and better plastic that's more flexible or I think I paid $18 a piece in the holes line up pretty good The hydra battery cooling fan is easy to access and easy to clean like blow water through it and blow it off with some air and let it sit in the sun and dry Make sure the duct work is clear all of this stuff is stuff my daughter can do.
  6. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    WOW! I found a time traveler! On a Priuschat forum of all places. Can you show us a pic of what a 2915 Prius looks like? I am sure it flys right?o_O
    I do think the axel and hybrid system sound like they are important though. I hope my mechanic knows how to fix or service them.
    #6 Freeze Time, Feb 24, 2025
  7. Noahdoge
    Noahdoge Active Member
    202
    144
    Mississippi
    The HV fan is really easy to clean. If you have basic tools you can get it done no problem. Watch a few YouTube videos to see if its something you’re willing to tackle. It’s important especially if you have dogs. I would also recommend adding the screen that clips on the intake. Part # G92DH-47010
    I would get a second opinion about the axle, watch this video first. Sounds like bait and switch, but that’s how they make big $$$ on cheap oil changes. The techs are required to find as many issues possible and the service advisors are just salesmen to add urgency and fear to close the deal. When I had to use the dealer for oil changes I would always leave with a $1,200 timing cover leak quote, which even now is not a big deal. Most of their service recommendations are literally just based on time/miles and they don’t even look at the parts. Like telling you need filters when you just replaced them (happened to me many times).
  8. ForestBeekeeper
    ForestBeekeeper Active Member
    772
    304
    Maine
    The last time I went to the dealership for an oil change, they wanted to replace the oil pan gasket [a 5-hour procedure that would take two days] and cost me $2500.
    My mechanic looked at it and said that the oil pan was the cleanest he had seen in months. All oil pans have a little oil on them.
  9. bettergolf
    489
    368
    Sanford NC
    I'm sure it looks better than my 2015! (bad typing) ...by 2915 we will be transporting ( like Spock and Kirk) and will not need cars any more!
    Axel would be important...if there is really anything wrong with it! Hybrid fan is very easy to do yourself.
  10. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    Is this easy to you?
    We have different definitions of easy that's for sure. I definitely need to pay someone to do that. I do not have any pets.
    frodoz737 likes this.
  11. bisco
    51,950
    it sounds like it all needs to be down, based n the cars history
  12. Noahdoge
    202
    144
    Mississippi
    It seems daunting for sure but I was able to get it done with no mechanical experience at all. I was so scared to do the egr system as well, literally had never even changed the oil in a push lawnmower. This site gave me the confidence and know how to do the egr, coolant, water pump, hv fan, hv bus bars and I change the oil every 5k. The only problem this has created is I have an addiction to buying new tools :LOL:. I completely understand if you’re not comfortable with the job, just don’t do it at the dealer, sounds like you already have a trusted mechanic that works on your cars. I personally wouldn’t pay more than $100 labor for that job. You can start by buying that filter at your local dealership or online and clip that on yourself.
    BlizzMPG and Paul E. Highway like this.
  13. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    I got a lot of replies on reddit and the general consensus is to get the axle fixed(not replaced) and not really worry too much about anything else.
  14. misterduck
    misterduck Junior Member
    Earth
    Last I went to the dealer, they wanted $84 to do an oil change. If they were charging $10.39, I'd absolutely change the oil on their dime.
    $60 to change an air filter is bordering on criminal.
  15. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Run don’t walk away!!!
    MAX2 likes this.
  16. Mendel Leisk
    41,466
    What would you charge to do an oil change?
    Did that oil change include a tire rotation?
  17. misterduck
    Earth
    It does not include rotation. Tire rotation was $25 last I paid for it.
    Given parts and oil are cheaper for a dealer and it's insanely fast for them, $50 would be fair. I'd go as high as $60. $84? I'll see you under the car.
    edit: I should add I do change oil for a couple people at this point, all of whom own various priuses. I typically charge $50. That's with OEM filter/ring and 0w-20 full synthetic from costco. The filters are cheap in bulk.
    #17 misterduck, Mar 20, 2025
  18. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    Do you recommend me buying the axel rod replacement on like Amazon and bringing it to my mechanic? What would be a fair price to fix it?
  19. BiomedO1
    BiomedO1 Senior Member
    3,629
    1,873
    SacTown, Ca
    IMHO; you shouldn't bring parts to a mechanic because that voids warranties. Let the mechanic do his job and source the materials - Any issues would be on his dime. You won't get into a he said she said, if there's a warranty failure. You bringing in parts and it's a parts failure, your paying him again to do the job. It wasn't the mechanic's fault that you brought him a defective part to put into your car.
    Just my 2-cents....
    Car Repair Estimates | Auto Shop & Mechanic Reviews - RepairPal
    #19 BiomedO1, Mar 26, 2025
    ASRDogman likes this.
  20. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    I trust my mechanic so I will ask him.
    Kromis likes this.
