Just got my CSP-ZJB mailing - brake booster malfunction
Discussion in 'Gen 3 Prius Main Forum' started by Bliz12, Jun 14, 2019.
  1. Bliz12
    Bliz12 Junior Member
    CO, USA
    Well, as the title says, I just got the CSP-ZJB notification. Of course, this comes months after Toyota dealership said there was no issue and it would be ~ $2000 job. I lived with resetting the code a few times, then paid a great non-dealer shop ~600 to replace the offending part with a good used one(can never remember which is which, this was the cheaper, easier to reach one!).
    Now, with this mailing, I have a conundrum: Do I send in my information and get reimbursed for the work I already had done to fix it, or do I put the notice in the glove box and wait for the brake booster system to fail again before 150k? FYI, this is a 2012 with a little over 70k on the clock. Seems Toyota will replace both the booster and booster pump assemblies.
    Thoughts anyone?
    -Ken
  2. yiujai86
    yiujai86 Member
    35
    31
    Miami
    2020 Prius Prime
    I just received to the letter too for my 2011. My letter says unlimited miles until Aug 31, 2021. After that its 10 yrs from first use or 150,000 miles, which ever comes first.
    51,155
    how much would the reimbursement be?
  4. Bliz12
    CO, USA
    Reimbursement would be for the amount I already paid non-Toyota shop to replace with a used part, so about $600. Can't remember exactly, but I know Toyota doing it and replacing both of the expensive assemblies with new would be FAR more.
  5. bisco
    51,155
    definitely. doesn't seem right, you should be reimbursed for a new one
  6. yiujai86
    yiujai86 Member
    35
    31
    Miami
    2020 Prius Prime
    It should be for the amount you paid in total for the repair.
    Anyways, mine failed 4 years ago and it cost $3300. I sent Toyota all my neccesary documents via usps Priority Mail. Tracking says they delivered it on June 19. Just waiting now. AND SURPRISE!!! My 2nd Brake Booster just failed 1 hr ago before typing this. I hope the Prius prime does t have this problem because I've been shopping for one for the past 2 months already and the 2020s just arrived.
    Edit: I'm gonna keep driving it without the brakebooster until they send me a check. Then if they do send me the check I'm going to bring the car to the dealer for them to see if they will fix it a 2nd time. Battery is also dead so I have all kinds of lights on my dash. Just waiting for a Prius prime axle AMD I'm trading in this junk for 1k.
    #6 yiujai86, Jun 22, 2019
  7. bisco
    51,155
    ah well, if it isn't the brake booster, it will be something else. toyota aren't what they used to be
  8. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    Does anyone know if it covers the “Prius V” as well? The letter lists the “Prius PHV” but not the Prius V even thought the V is mechanically the same etc.
  9. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    Think it's time to flush my brake fluid again.
  10. varun singh
    varun singh Member
    113
    Wayzata
    How often does it honk/bark, mine does it on every spirited non conservative braking, worried if this a failure waiting to happen or just a new noise have to live with it, unfortunately Toyota won't replace it as there is no error codes.
  11. frodoz737
    4,535
    2,438
    33
    I flush my brakes as part of preventative maintenance. So many here think "Prius" DOT 3 fluid is lifetime...it is not...as might be evidenced by said failures. But that's just me...I turn a wrench for a living, so what do I know. ;)
    Montgomery likes this.
  12. Mendel Leisk
    40,586
    FWIW, the dealership changed our brake fluid sometime in 2013, I did again, in the fall of 2016, and will likely be doing again this fall.
    And I've hear the "honk" when coming to a stop, with moderate braking. I actually had an appointment set up, to have them test drive. The car seemed to get wind of it somehow, stopped making the noise. So I cancelled, for now.
    Bottom line: there is something inherently defective in some of the brake boosters, some fail, and frequent changes of brake fluid, while a good idea, is not a panacea for the brake booster problem.
  13. frodoz737
    4,535
    2,438
    33
    Panacea? Maybe not, but you and I both know what preventative maintenance is. With all the "brake problems" Prii have had...it's just common sense. ;)
  14. bisco
    51,155
    i don't do any spirited braking. i wonder if that's part of it
  15. frodoz737
    4,535
    2,438
    33
    That would then make it an NTSB thing if that's the case...but I doubt spirited braking is the cause. I've had two Prii now and I drive normal...in the city no less...without a brake issue yet. Who knows.
  16. varun singh
    varun singh Member
    113
    Wayzata
    Anyone, would be interesting to know whose had this 'honk' issue the longest,
  17. bisco
    51,155
    oh man, that issue goes way back in gen 2, with no ill effects in most cases
  18. johnHRP
    johnHRP Active Member
    579
    173
    KA, DE
    Excel
  19. ChapmanF
    17,349
    H᠎i, welcome to PriusChat, where a lot of people come looking for accurate information about their Prius cars.
    The 'campaign ZJB' document linked above applies only to 3rd generation Prius liftback and Prius Plug-in (PHV) cars, not to the v or the c. The end dates vary by model year:
    So it's already over for 2010s (unless anybody's got one that hasn't rolled 150k by now).
    For 2011s through 15s, it is still in force through August 2021 and then to your tenth year or 150k miles, whichever comes first.
    It is a replacement conditioned on specific failures ("certain internal malfunctions of the brake booster and brake booster pump assemblies"). It is good to remember that in the 3rd generation Prius, those are two different assemblies:
    There is a list of trouble codes that may mean the covered failure has occurred. They are codes that can also be set for other reasons. Sometimes a few simple steps of diagnosis will reveal that something else has caused the codes you have, and that replacement of one or even both these assemblies would not be the necessary solution.
