Just how much can I install?
Discussion in 'Gen 2 Prius Audio and Electronics' started by PLPrius, May 28, 2008.
  1. PLPrius
    PLPrius New Member
    Sacramento
    Hey Guys,
    Called a local install shop and they told me they never did much with a Prius. His big concern was how much headroom (current draw/amperage/excuse my lack of knowledge) there was on the 12V battery above and beyond what the car uses. He’s trying to match up my amps power draw with what is available from the 12V.
    When/If you respond to this thread, could you tell me how you discovered this knowledge(spoke with Toyota Tech Supp, or know how to measure yourself). I’m not questioning your validity; I just don’t want to mess up my car with someone that throws out a random number.
    Thanksfor the help.
  2. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Uhhh, what are you trying to install? A sauna/hot tub... satelite dish...
    submersable sprinkler well pump... combo washer/dryer... all of the above?
    Yo, you gotta say what you're trying to do so folks can try to help.
    Right now, you're coming across as a "random number" yourself!
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    welcome to the group. :)
    I believe your limit is around 1000w of power.. i'm sure others will chime in with the exact amounts.
  4. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    I think the Prius is the perfect car if you need lots of power. :D
    But strongly consider a bigger battery if you will ever need much power with engine off.
    Prius - UPS Project
    Read the "UPS Testing" section. This guy was able to get 1000 watts or 80+ amps at 12 volts continuously with the engine starting and stopping as needed to maintain battery charge.
    There's some speculation here http://priuschat.com/forums/prius-modifications/47346-110v-outlets-your-prius.html that you may be able to get more than 1000 watts for short term bursts anyway.
    If you need/want more power :D you could tap the 200 volt battery for 3000 watts (perhaps more) continuous. See PriUPS-getting electricity FROM your hybrid vehicle . It may void your warranty and/or electrocute someone if your not careful, but it's possible.
    Hmmm, 3000 watt sub-woofers. Reminds me of a Mythbusters episode where they turned an engine into a speaker driver... :eek:
  5. PLPrius
    PLPrius New Member
    Sacramento
    Let me rephrase. Take the amps and any other equipment out of the equation.
    1. how many amps does the battery output.
    2. on average (I know that air conditioners and other electronics can change this) what does the car use from the battery in the form of amps.
    3. If you see a flaw in my terminology please correct in a constructive manner (don't include any sauna/washer and dryer jokes). I'm sorry that i'm not at your level O'Great Rokeby. Even you were once a neophyte trying to find your way through the totalitarian rule engorged universe known as forum posting ( re-read that last sentence using the James T Kirk way of speaking, it makes it sound cool.).
    4. If the answer to Q#1 is: the same as any other 12V battery, then why is it so small and why don't other vehicles like trucks use them?
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    PLPrius,
    Hey man, you got it all wrong.
    My post was meant to prevent the situation that has come about; folks here
    don't know exactly what to say because you haven't given them good enough
    info to work with. On it's face, my crack about a submersible sprinkler well
    pump sounds outlandish, but one poster has provided you with threads that
    suggest that you could do it.
    There are many incredibly talented people here. There are also some only
    just believable projects that are routinely discussed. Some examples:
    * Hacking the power steering
    * Adding an extra HV battery pack with maybe 300+ AA rechargeable batteries
    * Running X-box, Wii, or some such on the MFD while underway.
    * Using the Prius as an emergency generator
    In every case, specific detailed info on the equipment is provided by the
    poster seeking info/help. In your case I suspect it's on a data plate or in the
    owner's manual. Look it up. Post it.
    Believe it or not, you may know more about things electrical than I do.
    Check this thread out:
    http://priuschat.com/forums/prius-technical-discussion/42651-dead-12v-battery-glove-box-remedy.html
    Pretty pathetic huh? (Ain't sparkyAZ a saint?)
    The only reason I was able to move forward was the repeated, patient help
    that I got from folks here. With a slight course adjustment on your part, I'm
    confident the e-smart folks here will bend over backwards to help you.
    If you want to attract bees, honey works better than vinegar...
    but be prepred, a hornet or two may also show up.
    At the risk of causing offense, I would suggest that you start a new thread with
    a catchy, product specific title. Something like:
    Bang & Olafson XYZ Woofer -- Will it Work?
  7. Popeye
    Popeye New Member
    The reason people asked for more information is because when you want to use the power is important to the answer. If you are using the power when the car is running then the size of the battery is irrelevant, the size of the charging system is what matters. Since you talk about subtracting the standard loads, it seems like this would be your question. On the other hand, you ask specifically about the battery. The battery capacity would only matter if you are trying to run your whatever with the car off.
    This is true of all vehicles, hybrid or not. In a standard vehicle, the amount of available 12V power is determined by the alternator when the car is running, by the battery when the car is off. Same for the Prius, although the alternator is replaced by the DC/DC charging system. If you use more than the charging capacity then you will eventually drain the battery down to nothing.
    The Prius has such a small battery because when you start the car all the 12V battery has to do is boot the computer, then the high voltage battery does the rest. In a "normal" vehicle the battery is bigger because it has to crank the starter. This results in the side effect that there is more power available from the battery when the car is not running.
    Having said that, the 12V standard battery is specified at 28AH. In theory that means that you could draw 28A for one hour and the battery would go from fully charged to completely dead. In reality, you can only get about half that much out of a battery, and even that is not great for it on a regular basis.
    On the other hand, the main 12V fuse is 100A, so, in theory, the charging system can provide up to 100A or about 1380W (typical charging voltage is 13.8V).
    Then one part of the answer I can't give you is what the "normal" loads are in the car. Maybe someone else here has that answer.
    Good Luck.
  8. V8Cobrakid
    3,790
    152
    my prius tends to charge at 14.4 volts.
    my observations are seen though the secret screen on the 04 and 05 models...
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I'm installing a second car audio amplifier today (400watts rms) so that will bring my total up to 1,900watts rms or continuous as some perfer. This is for car audio purposes so rarely will I ever be running everying at peak current draw for very long. So far I have had no issues with the vehicle itself but the stock battery on the other hand, is on it's way out. I cannot play the system hard with the car off or it fails to supply the needed current and the system cuts out. This was with just the 1,500watt subwoofer amp alone.
    I'll be adding a new battery soon. :)
  10. patsparks
    10,664
    567
    Adelaide South Australia
    I forgot about that, mine is 13.8 volts.
