Just installed my 2nd user enginer 4 kwh kit.
Discussion in 'Prius PHEV Plug-In Modifications' started by glyndwr, Dec 14, 2012.
  1. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi all,
    This afternoon I have successfully installed my 2nd user enginer 4 kwh kit. Have tested it and it is all working ok. (phew)
    In my brief time owning the prius (only had it for 4 weeks) the avergae mpg in my location which is very hilly (South Wales Valleys) was 44 mpg.
    I just completed my first journey as a test run, and covered 8 miles. The average mpg at the end of the journey was 68 mpg.
    To be honest I am quite pleased with that result, to increase my average mpg by 65% in our hilly terrain is very pleasing. I am looking forward to learning to use the kit as efficiently as possible over the coming months. (hopefully dont get any reliability issues)
    Thanks to all who has helped with any informtion given.
    Best regards, Anthony.
    49,492
    well done, all the best!
  3. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi all,
    a small update. After using the system now for about a month, have done some manual balancing, as the balamcing funtion on the BMS 3.3 has been disabled.
    Originally, i could get 2.8kwh into the pack, using an electricity monitor to monitor the amps, volts and kwh input.
    I was finding cell 2 terminating the converter early, and cell 15 / 16 terminating the charge.
    Bled of about 4ah out of cell 15 and 16 at the high end, and pumped in about 6ah into cell 2 at the low end.
    The result is now the pack is taking about 3.5 kwh charge.
    I am pleased with that, but i am sure i can squeeze alittle more out of it when i get alittle spare time to spend on it to manually balance alittle more accurately.
    So far so good, i just hope it remains relatively reliable. I dont mind spending sone time to manually balance now and again, just hoping I dont get a failure.
    mrbigh likes this.
  4. wb9k
    wb9k 09 Gen II Prius w Hymotion Plug-In Batt
    174
    99
    Commerce, MI, USA
    Wow. It's hard for me to imagine anyone tolerating a balancing system that seems to work as poorly (or not at all) as I hear about from the Enginer system in what seems like every case. Good balancing is not necessarily easy, but *not terrible* balancing is quite easy if you can execute worth a damn.
    If you find you must balance manually, do so often--keep those cells away from the overcharge (and overdischarge) range. Their long term viability depends on it.
  5. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    I am still using the BMS v3.3 but only as a device to trip the converter and charger.
    I also have cellogs 8s to monitor as a check that the bms is reporting the correct voltages from the packs.
    As the unit was a 2nd user system, and i dont know the relative usage of the packs, then with the little amount of manual balancing i have done doesnt seem to drastic. Also at the moment its a bit of a hobby, not a distracting bind to me.
    As we are on 240 volts here in the uk the pack is taking 5 amps current, 989 watts usage when charging. When the charger is tripped by the highest cell the resting cell voltage generally is about 3.4 volts. I am sure I can get that higher, but also i am wary of putting excess voltage into the cells, so i will probably let things as they are as far as high voltage goes.
    Thanks for your input. Anthony.
  6. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi all,
    Just a small update on the enginer performance.
    With the climate getting warmer now in the uk my overall mpg is increasing.
    When I first started using the prius with NO kit fitted, where i live i was averaging 46mpg.
    As i was getting used to driving it, and having installed a ECT spoofer, and using the enginer kit went to 67mpg during the winter.
    Then, after more learning of driving, got 76mpg.
    Now that the climate is warmer, and driving more in ev mode and with driving more in regen position, am getting 94mpg :) . This has been done over my last 75 miles. I am very happy with that to be honest.
    The batteries in the kit are pretty much still balanced, although i do manually adjust alittle every weekend just to tinker with it ( and an excuse to get out of the house for a while :) )
    I have also got some cell loggers with relays to trip the charge earlier (before the 3.8v setting on the enginer BMS)
    I have ordered a lovely little pcb board with 8 relays on and 8 inputs (the pcb has relays with flyback diode and resistors along with a darlington transistor for each input to trigger the relay) this will be used to monitor each cell, and control the high charge cut off. I shall take a pic of it when it arrives and has been fitted and tested.
    I could have purchased a smaller pcb with only 2 relays on, that would have worked, but paid no extra for the 8 relay set up, if i ever did in the future reconfigure my batteries and go down the norms BMS2 route, then the 8 relay set up woild prove very usefull.
    I shall update when i get the small pcb fitted and wrking (hopefully)
    best regards, Anthony.
    NortTexSalv04Prius likes this.
  7. mrbigh
    3,686
    699
    Long Island, NY
    I'm waiting to send you a bag of Kudos until you finish.....;)
  8. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Update,
    forgot to mention, the reason for the little pcb with the relays is to protect the cell logger open collector outputs. As i have found out to my cost, these are delicate little creatures and with the wrong relays or any back emf the cell logger alarm output dies.
    So, by using a npn or darlingotn transistor (2 npn transistors inseries) this proetects the cell logger relay output. The pcb i have ordered ( and it was only £12) this has 8 individual inputs for 8 cell loggers if needed to each relay has its own transistors, fly back diodes and resistors all in circuit all ready to work, so if your like me with no experience in electronics, takes the calculations away from making the small circuit yourself.
    In additoin, the relays on the pcb are rated 240v/10A or 28v/10a, so ideal for my set up.
    If anyone wants any info on this relay pcb board, let me know.
    Thanks, Anthony.
  9. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    Hi Anthony,
    In Australia we also use 240Vac.
    The Enginer charger outputs 15 amps at 48Vdc. The rating of your relays of your printed circuit board is 240Vac at 10amps. Using the PCB relay with a 10amp rating at AC to isolate the charger output when HVC occurs will probably not cut the mustard and could lead to becoming blown or even worse lead to a welded contact. Better to use a relay with contacts rated to at least 15amp DC (not AC). Breaking DC current under load puts a lot more stress across the contacts than AC does.
  10. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi Jim, thanks for the advice.
    I only intend to use the relay board for the cell logger to switch the pcb relay 12v, then the switched output from the pcb relay will operate an additional 25A 240vAV relay to cut the charger. I already have that relay here.
    The cell log will alarm, that will trigger the on board relay to output 12v, that output will trigger the 12v coil on the 25A charge relay, switching off the charger, thats how i am going to set p the system. I hope.
    Thanks very much for the input.
  11. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi again Jim,
    it is my intention to install the charger cut off relay to the inlet side of the 240v in power cord.
    I have a power meter in this line and when charging it is taking 5 amps at 900 watts of power, on our 240v AC supply.
    Would you suggest then actually installing the charger hvc trip relay on the output side of the charger on the DC voltage line then? If yes, can you advice why this methid is better that isloating the AC input voltage. Srry to ask, new to me, not sure of the advantages of either install method.
    Thanks Jim.
  12. lopezjm2001
    1,146
    407
    Sydney Australia
    Hi Anthony,
    The Enginer kit BMS16D is designed to isolate the charger output. I presume the reason for this was to make the Enginer kit at a safe voltage for the backyard tinkerer like yourself. And as many have found out the Enginer kit is high maintenance. So exposing the Enginer user to 240Vac live parts is not a good idea and was not the intended design.
    Where as the Enginer DC Converter which has an output of 240Vdc 15amps which is more dangerous than 240Vac 10amps are not exposed as the bullet connectors on the output are designed so that the user cannot touch the metal live parts.
    So using an AC relay to isolate the charger input is OK which is what the Pacific BMS uses. I would install the AC relay inside a PVC electrical box which is waterproof and use PVC cable glands. This would insulate the 240Vac and any chance of accidentally touching live 240Vac parts. This would make It safer.
    One would expect that the isolation between the AC relay input and output will not breakdown and result in making all your 12dc also have 240Vac. Another reason probably why Enginer isolates the charger output. It's all about the safety factor and keeping the different voltage levels to a minimum.
    Just incase you do not know - 240Vac can kill you. When I installed my MiniBMS to replace the BMS16D I used a 12Vdc car relay with contacts rated for 20 amps to isolate the charger output. It's just safer.
    Another reason why you should not use a AC relay to isolate the charger input is because the charger output latches off once it senses that the output has been disconnected and stays latched off even if the HVC relay connects again. That is only until you switch off the charger at the power point (which isolates the input). If you isolate the input of the charger the charger will charge again once the HVC connects again. This results in the charger cycling on and off all night on the HVC signal. And as you should probably already know that if you kept cycling the charger at a HVC of 3.8volts it will cause lithium plating on the RFE battery pack cells that reach 3.8 volts. I hope that this makes sense to you.
    I doubt that the Hymotion kit would take the chance to introduce 120Vac or 240Vac. Maybe WB9K could comment on this.
    John (not Jim).
  13. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi John (sorry for the Jim bit)
    I have electrical knowledge but not electronics, although i do intend to learn abit in the near future along with playing abit with arduino. In my days with sony making tv`s they tought me on plc programming for automation processes using Omron plc`s. i`m hoping arduino is easier, i can program ladder logic ok but havent tackled arduino yet, when i get some spare time i shall have a good read on how it works and how to write basic programs
    I am a mech eng, used to work for Sony manufacturing in making large CRT tv`s.
    I have got the HVC cut off relay housed in a plastic case in the corner of the load area (behind light cluster portion at floor level. This is alseady in circuit waiting for the relay pcb to arrive. The HVC relay has a mech on/off swtich on top and its set to on all the time at the moment awaiting the low voltage circuit to be completed.
    I did consider cutting off after the charger, but didnt want to alter the wiring too much. On the 240v side, its only cutting into the power cord and directing the live and neutral through the relay. The earth is continuous around the relay.
    I am considering some time in the future if the enginer kit fails and too expensive to repair, i would contemplate altering (or getting new) batteries into 48v banks to 240vdc lke other have dome and make a kit to run with BMS2. I have the skills and tools to do this, and with keeping the banks to 48v keeping it safer to work on (ie 5 banks of 48v batteries in series seperated with anderson plugs)
    I would welcome any info on what kind of performace these systems give in relation to the enginer kits. If i can get over 90mpg with my enginer kit, what coiuld i expect out of a system using norms bms2 and a 240v pack.
    Thanks again John.
  14. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi John, i had thought about this,
    I have the HVC cutt off signal from the relay going througha push button switch and the HVC relay latched upon the pressing of the pushbutton to allow charging. Once the HVC trip signal is given, the relay latches out, and cannot start again until the high voltage alarm has receeded and the push button is once again pressed.
    I intend to set the high voltage cut off at 3.5v initially, then check with the power meter device to see how many kwh has gone into the pack, and reduce the high cut off to 3.45v and again check the kwh into the pack, if the kwh is very small (maybe less than o.2kwh) then i shall probable leave it at 3.45, its a case of checking when i get it all working properly.
    Thanks again John.
  15. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Ok, have finally got the system working where the cell logger high alarm cuts off the charger AC via a relay.
    What i have got is a pcb with 8 12v 10A relays with protection for input devices like arduino outputs and open collector outputs, the protection is in the form of fly back diodes and a darlington trnasistor for each relay. You will see a pic of the pcb along with a schematic of one relay and the shematic for the cell log open collector.
    The relay pcb only cost £12 delivered, i couldnt buy the parts for that never mind assemble and solder them into a breadboard. I bought the board with 8 relays on it, in case i mod my system in the future. Relay pcb`s were available from the supplier with 2, 4 or 8 relays fitted.
    The cell log open collector output mus have a 10k resistor fitted inline from the output to the input of the pcb with a +12v supply. The diagram will show what I mean.
    Additionally i have drawn a diagram of how i have wired up my system, may be of use to you.
    It has worked now for 5 charges and works as it should.
    I am really happy i have now got it working. Note, I have not connected up the black wire from the cell logger alarm port. The alarm port open collector opens internally to neutral to cell 1 -ve (so i have read). It works anyway.
    Please feel free to comment, or if i can help in any way please ask.
    Additionally, just got past the 100mpg mark, very pleased with that with an enginer kit. Averaged this for the last 140 odd miles. really loving the prius and am getting hooked on projects for it, wouldnt mind in the future upgrading and fitting a system like john`s with a duionomite.
    Thanks, Anthony.
  16. 2007blueprius
    2007blueprius Member
    461
    30
    any word of advice?
    I looked into this before an my conclusion at the time was that phev upfront kit was not worth the potential savings, also engineer apears to be a low end product and the unnecesary converter takes lots of space if only the bateries were adding up to 240v or whatever other setups use,
    these days I came across a used engineer kit, so I'm back looking into it, I'd rather build a custom proper highvoltage system given all the time and money in the world but that is not the case here,
    What is there to consider here?
    I know these bateries are rated for about 1000 cycles before the capacity starts dropping, that's 3 years of daily use, if the system is 2 years old not looking so good is it?
    Than I read about all the unreliability, and bad balancing, I read through these forums before and spent lots of time on youtube looking at various components but I get more confused the more I read up on it.
    Anywho any input is apreciated
  17. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi 2007blueprius,
    i was in the same position as you, then a 2nd user enginer kit came available, i weighed up options, and decided to buy the kit, as it was so cheap, couldnt buy the realforce batteries for the price i paid for the kit. Alwayas a chance when buying 2nd user that there may be issues with something but thats the risk of buying used.
    Ok, my driving is only small local journeys, and the enginer kit is ok for this type of running, even in ev mode i can do most of the journey using very little or no gas. The enginer bms balancing function has been in the OFF position since new, which is recommended, so knowledge of manual balancing is required to get the best out of the pack.
    The converter is the main restriction though only allowing in my case 12 amps output into the prius battery, but as my journeys are so short this is not too much of an issue for me personally.
    Now that i have run this system for around 7 months, and really like the ev driving, and not putting much gas in the vehicle, I am considering another mod, where i may re-configure the batteries from 16 cells at 48v to 72 cells in series (have to buy another 4 cells as i have already got 4 spares) to make up 230vdc and use a plug in supply used controllers or buy norms bms2, this will take away the 14 amps max issue. Again this is done elatively cheaply, i can reconfigure the batteries myself for littl cost, just alot of time.
    There is no BMS (battery managemtn system) then, but will control it with mre cell loggers with the relay board i alreadfy have maybe with another additional charger relay as a fail safe. I do though have to source a charger, as the 48v one i have will be of no use.
    I can then try to sell the converter and charger to recover some of the costs outlayed modifying to the newer and hopefully better system.
    I do not regret buying the enginer system, but it has taken quite some time in learning and balancing manually the cells, fortunately, time and patience i do have, and that isnt costing me anything (other than some frustration).
    The way i looked at it, for the driving that i do, to try to get as much ev use as possible, this was the best way.
    Car was £3200 (2004 gen2 prius with 62000 miles full service history one pevious owner, very good condition)
    Enginer kit £1250
    Cell loggers and relay board plus additoianl relay £50
    so for £4500 I have nearly acheived my goal, (as much ev driving as possible with my driving journeys ) without a massive price tag, I was looking at a new EV like the mitsubishi imiev, or nissan leaf, they are dropping in value here, Leaf is £15000 with 5000 miles, the imiev sells for £10000, again 5000 miles, if i get a small windfall, i shall definately sell the prius with the kit and buy a full ev but that is when they either drop in value to around £6500, or i get a really good offer for my prius.
    Hope this helps you in some way.
  18. 2007blueprius
    461
    30
    I am kind of in the same boat, I do appreciate the detailed reply, and I must say I noticed before how relatively cheap cars are in the uk, granted fuel is $9 per gallon and that could explain it, but around here you can touch a prius for 5k even if it has a 1/4 million miles, seen one the other day in the classifieds for 8300, at the same time what turned me off from any ev, is my electricity is 65% coal generated, that pretty much defies the point right there, the prius is already efficient and at $4/ gallon even the 3500$ engineer would never pay off, never mind the any issues I may come across or the electricity cost, all in all it's just not feasible yet, a cheap used kit maybe.
    here's a thought for you something I am in the process of thou it is much easily attained where you live, LPG, for about 1250 you can have it installed and they are pretty dialed in and issue free, at half the fuel cost, your mpge would be about double the stock, you'd pretty much achieve the same result, much cleaner and domestic fuel, I know a couple good guys in the UK I have been bugging with questions
    my routine is rather similar to yours thou ev is out of the question, speed limit is 45 mph but "blended" should yield some results, in that aspect I don't think the 12 amps will bother me much, as for balancing cells I thought a parallel connection is how that is done best so not too much to worry about there either, the mini bms I looked into before, now the other controllers and bms2 canviews and all that other stuff is where I am lost.
    anyways like I said I gave up on this Idea a while back and it seems like almost everybody else did too , I hear Engineer is done and so is Hymotion or another manufacturer , and I really did not car for it at this time and I am in the middle of other priorities, but this used one came up if I can get it cheap enough sure, why not, I'll tie the cells in parallel and set them aside for week till I find some time to screw with it
  19. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Well, as far as electricity goes, I have a 4kw solar array, so getting most of my ev driving for free for about 8 months of the year, after that got to buy it at 15p per khw. I,m not In this as a tree hugger or to be super environmentally friendly (I could lie to you but that's the truth), for me it's about the spiralling costs of motoring here in the uk, with petrol at £1.40 per litre or 9 odd dollars, it's getting so expensive it's a joke. This was the most cost effective way to get as much ev miles without spending a small fortune on a modern ev with lithium batteries.
    The engineer kit will get you 80 mpg easily, and with driving like miss daisy close to 100, if your journeys are local.
    The other methods, ie, norms bms2 and plug in supply do send fake state of charge commands to allow more ev miles and are not limited to 14 amps so are easier to live with ( I hope) as I will probably go this route myself shortly.
    I am an mechanical engineer by trade and looked at this as a hobby and project to get me knowledge on the technology and learn how the batteries cycle, which has been good to learn.
    I have enjoyednthenexperience and don't regret it at all. And of course saving money, in the last 13 weeks I have only used £34 of fuel. That is a massive saving for me.
    LPG is also expensive here and a kit installed here is around £1500, there a very few lpgmfillingnstations and of course you still have to buy the LPG, whereas most of my electric I am generating myself, as a guide I have generated 240 kwh of electricity in the last 9 days, plenty enough to charge the prius multiple times per day.
    Best regards with whichever route you choose.
  20. 2007blueprius
    461
    30
    oh I am going for both, and to me it is a bit of a tree hugger thing because as cheap ( thou everybody else is bitching ) as fuel is here still, It does net make any financial sense to own a prius in the first place, unless you get it for the right price ( same idea as the plugin kit ), at the same time our fuel prices are somewhat a result of the troops being dispatched I'm sure, I have a 4 year old, I'm sure todays parents did not consider their children future 25 years ago when they were running their v8's and they still do, I am all for the solar and wind and that is in the works too, however you have to consider their initial cost too if you want to compare apples for apples, and last I checked into that same Idea there is not much gain there either I think my electricity is $.13 per kw, I can not generate my own for that, it is cheaper to buy it but it's coal, I might as well run petrol, I know I am getting sidetracked here, I also know road taxes in the uk are a joke too, in that aspect it is worth financially on your end as for lpg I stock it for work, the only reason it makes sense to me or It would actually cost more at the pump, and they are not many, even then it is 95% domestic to me that's worth the premium for now. too bad no one else feels the same, they may get the clue eventually but it will be too late.
    thanks for the tecky stuff, I am just as inclined thou I have not pursued it professionally, I have read about the spoofing and I am leaning in that direction too, a used Engineer might be a good start but I don't think is that efficient, speaking of your solar, are you running grid tie? some setups I read about used batteries and inverters, my thought was to put that into the pack directly and do away with chargers inverters and all that 48 v seems to be a common number for solar and wind therefore the added interest in an engineer kit, I also purchased a 48 v ebike kit mostly for experimenting purposes with wind, does that make sense to you? Ideally I'd like to pump renewable right into ev of some sort, off grid, off the MAN's books
