Just OBD'ed my Prius and got 4 errors...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius2006GuitarGuy, Sep 26, 2024 at 3:31 PM.
  1. Prius2006GuitarGuy
    Prius2006GuitarGuy New Member
    23
    Sweden
    Hey guys!
    Just got my Autel obd2 scanner, ran the diagnostics and this is what I got :
    460269214_366738023199606_7799435876712424345_n.jpg 460543036_1027218575804813_1322142915121232636_n.jpg 461058513_1051949503240470_3270961569924300683_n.jpg 460562071_435739868995200_5380767868471469555_n.jpg 460624565_925437652937984_415737453734393097_n.jpg
    I could be wrong but nothing seems too serious, even though the p0420 error is (I think) causing my check engine line to be on... was a bit surprised with the AC error, I thought all was good there!
    Now I leave it up to you more experienced peeps to tell me how to fix the above please
    Thanks!
    (The car is a Prius 2006)
  2. saneesh8
    saneesh8 Junior Member
    51
    Allen, TX
    First one you can ignore. Just search for the code.
    Second one, P0420, Cat converter? How many miles on it?
  3. Tombukt2
    Tombukt2 Senior Member
    9,986
    1,730
    Durham NC
    If you are in an emissions state you are going to have to replace your converter to get your light to go off for the 0420 code other than that the solar sensor doesn't have nothing to do with anything Just forget about it put a flashlight over it and it won't it won't come back but you know you can't leave a flashlight sitting over the Sun sensor. But that's all that is that has nothing to do with anything The PO420 you're going to need to converter You can also try a spacer but not a spark plug anti Fowler a solid steel stainless probably spacer with a little piece of catalytic material in the middle of it that may work but your state that has emissions may kick you out because of that spacer so you have to know what you're doing where you are
  4. pasadena_commut
    pasadena_commut Senior Member
    1,623
    486
    Southern California
    B1421 just means the car was in the shade. It is literally what it says. "Solar sensor" == "is the car in the sun".
