Just picked up a 2004 Prius with 183,500 Miles on it!
Discussion in 'Gen 2 Prius Main Forum' started by handel, Apr 22, 2010.
  1. handel
    handel Junior Member
    Santa Cruz
    I must be crazy, but I just bought a car with a ton of miles on it. :)
    It's also my first Toyota. Replaced my 2006 Civic Hybrid.
    So far I like it. It is very different from the 06 civic hybrid.
    I bought it because it had the HOV stickers we value in California- at least until January 2011. This had package 9 which I think has everything except leather.
    Plus:
    better gas Economy.
    Hatchback is nicer than the limited trunk space.
    Love the built in GPS and HID lights.
    Love the smart key, the MFD is cool.
    Negs:
    suspension is very soft.(semi independent rear)
    Seats not very adjustable,
    would have preferred climate controls not on the touch screen.
    Ugly wheel covers (can't believe why they bothered) I removed them and saw nice alloys beneath.
    So far I've done,
    an oil change, pretty easy, didn't even need to put it up on the rhino ramps. put in Full synthetic 5w-30. -The oil filter is TINY.
    Replaced the air / AC filter(super dirty).
    Got new tires Yokohama ENVigor (just came out on the market).
    I also was able to reuse my IPOD connection I had on the Civic.
    From ISIMPLE IPOD. even though the Prius wasn't listed as supported, it worked great. only thing I don't like is the song text only shows 9 characters but I can choose playlist and all that other stuff. Very cool. I was about to buy the DENSION, but decided to give the iSimple a try and was very happy that it worked. The Prius doesn't have the "SAT" button on the dash, but if you press the mode botton on the steering wheel, you'll eventually find the ipod.
    next on my list is to get the coolant and transmission oil changed, also the brakes fluids changed out and then get an alignment since I just got new tires.
    Overall I'm pretty pleased with the new addition.
    :rockon:
  2. djasonw
    djasonw Active Member
    961
    123
    Coconut Creek, FL
    You're lucky you got one with LOW MILES. Should last you a long time. :)
    My 2004 has a bit over 100k. Thanks for the tip on the iSimple. I'll check it out as I'd love to use my iPhone in my Prius. I have SAT, but would also like to listen to my music.
  3. 4G63
    4G63 I quit boosting
    147
    Aurora, IL
    how much did u pay for the car? its interesting to find out the isimple works on the prius too. i too have a civic hybrid with the isimple kit installed.
  4. Patrick Wong
    18,209
    6,510
    Congrats on your new acquisition.
    May I suggest that you add replacement of the front struts and rear shocks to your repair list. That should help ride comfort and handling. If you agree, do that replacement before the wheel alignment, since front strut replacement will throw off the camber adjustment.
    Regarding the brake fluid change, that should be done by a Toyota dealer (or else an independent that is a Prius specialist) since a special procedure using the Toyota diagnostic laptop is required.
  5. drees
    drees Senior Member
    1,782
    247
    You can get aftermarket springs/swaybars for the Prius. Could be that after 180k miles the struts/shocks are simply worn and are due for replacement. I find that the ride in my Prius is pretty good (I have a WRX with upgraded suspension that I can compare to).
    Pretty standard sized filter in modern vehicles, IMO. You'll also notice the small oil capacity - the engine doesn't work hard 99% of the time anyway, so it's more than adequate. Most used oil analysis have found that the engine wears very nicely.
  6. handel
    Santa Cruz
    -Yes, I'm thinking the shocks may be worn out too, But it looks like a PITA to replace the fronts. I've done a suspension upgrade/swap before on my 1999 323i, was pretty straight foward except for removing the spring from the mcPersion strut that was a serious PITA. :)
    -Yes, 3.5 quarts approximately how much I put in. That compares to almost 7 in my 330i. But that car suppose to go 15,000 miles before oil changes.
    At first when i went to a local shop to buy the oil filter I couldn't believe the size, so i went to toyota dealer and sure enough it was the same small filter. Any aftermarket filters larger than OEM?
    Spark plugs this weekend. maybe the PVC Valve too.
  7. Patrick Wong
    18,209
    6,510
    I've posted on how to replace the front and rear. At least the springs are not that hard to compress (compared to a BMW.)
    You can buy a Toyota filter that is slightly longer than the original, so that it has a bit more capacity. However I think the correct filter is adequate.
    A hint regarding the PCV valve - it is hiding under the wire harness that runs along the engine valve cover. Look for the 90 degree turn in the wiring harness on the driver's side of the valve cover. The PCV valve is below that point. You will need to remove the relay box mounted to the cowl, and the wire harness to gain access. Good luck.
  8. Prius-Forever
    Prius-Forever New Member
    I'd like to know how much you paid for it as well. I personally would never buy a car with that many miles on it unless it was a steal.
  9. spitinuri
    spitinuri Member
    317
    I purchased my 04 in November of 08 with 70K miles on it. Currently I have 135K. Outside of inverter coolant, engine coolant, plugs and new tires it has only required standard maintenance.
    I would buy one with high miles especially if it was taken care of properly. I'm sure you purchased for a nice price.
    Enjoy!
  10. handel
    Santa Cruz
    I paid $7500. It's definitely the highest mileage car I've ever purchased. Also my first Toyota. I've always been buying BMW or Honda :) This car has the stickers which gives free access to the carpool lane. that was the reason I got it. Also we where in the middle of buying a house and didn't want to take on a higher price car which means I'd have to get a loan and if that screwed up our house loan it would be really bad. :)
    Moving to Santa Cruz next week. Woo Hoo.
    I just picked up 4 Bosche IR Fusion spark plugs and the PCV Valve, it was from autozone and has threads on it, hopefully it's the right one. if not I'll have to go to toyota to pick one up. There was some sludge under the oil cap, wondering if the Pennzoil "Ultra" will clean that up. I just put in Pennzoil Platium, but from the marketing guys Ultra does even better at cleaning up sludge. In fact I even saw sludge hardened to the dip stick. :( Hopefully that's not a bad sign of poor maintenance.
    Still enjoying the electric drive at low speed it's very cool.
    I'm going to dig out an old phone too see if I can put contacts into the car, as i can't get it to do that with my iPhone.
  11. wicastawakan
    wicastawakan New Member
    107
    Oklahoma
    I have a 2008 & suspension is fine. I live in the country & have hauled hay & feed in the back (several hundred pounds). Check your suspension components & tire pressure.
    The climate control can be controlled on the steering wheel.
  12. spitinuri
    spitinuri Member
    317
    Sounds like a great deal. Consider using a synthetic oil. I use Mobil 1 0W-20 and justify it by doing my own oil changes. You should see a nice bump in mileage and be able to push your oil changes out to 7500 miles easily (you might want a used oil analysis to be sure). Best of luck. Btw: Patrick Wong will not steer you wrong. He's a good one to listen to.
  13. drees
    drees Senior Member
    1,782
    247
    If you're seeing any significant sludge build-up under the oil cap / dip stick - I would highly recommend a couple of short interval oil changes (1000 then 2000 mile, just use regular 5w30 oil) along with filter changes to help flush things out. After that, I also highly recommend synthetic oils to help keep things clean.
  14. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    As the new syn oil cleans the engine keep an eye out for leaks around valve covers etc
    :welcome:
  15. ormero8945
    ormero8945 Junior Member
    Lancaster, pa
    I bought a used 2005 Prius with over 100k. I got all service records... the former owner changed the oil every 5k with dino oil. For the first several thousand miles the car used no oil, until I switched to synthetic (M1). Now I use a quart every 3k. If you switch to synthetic, I would highly recommend using the "High Mileage" formulation. BTW, I am thrilled with the car... after driving 30k my first year, I'm looking for the car to last 225k or better.
  16. handel
    Santa Cruz
    yes I've been using Mobil-1 in my cars for the last 5 years, it really does not sludge. my old 323i even with 15,000 mile oil change and at 168,000 miles, I had to replace the valve cover, no sludge what so ever. I'm definitely doing a few 1000 mile oil change with the good stuff in hopes that it'll rid the engine of any sludge. After that I think 5000-7500 mile oil change with synthetic should be find. I don't think the oil is the weakest link, it's the tiny oil filter, plus also only 3.5 quarts. I don't think I can do 15,000 on the Prius for oil changes.
  17. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Hey, last night at a public used car auction I saw one of the highest mileage cars I've ever seen. It was a 98 Corrolla with 320k on it. It was unbelievable. It looked like new the back seat I don't think was ever sat in, the a/c and all the electronic stuff worked and seemed to run like a charm. I was thinking of buying it but didn't hang around till the end to see what it went for.
  18. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    The car my mom replaced with a '04 Camry (in '04) was a 1972 Ford LTD with 365xxx miles on it. She bought the car new in 1972...
  19. defrankond
    defrankond Member
    217
    23
    North Dakota
    hello everyone.
    my name is cj. after a very long time of wanting a prius i finally was able to get one. granted it has some paint chips, and ciggy burn holes in the interior im quite happy with it. it has 186k miles on it and runs as quiet as a brand new one. i do think it has been well taken care of but there are a few things that i have a question on. im not sure of the series of my prius but i have nav, 6disc 9 speaker system. everything really except leather and sun roof. but the info button, defrost button and rear defrost button on the stearing wheel dosnt work but all others do. im missing the rear cargo shade, but other than that its in decent shape. suspension is nice and firm, battery as far as i can tell has charged fully green and discharges but never gets fully green on highway driving. only in town does it fully charge with the hills. the car was listed at 5999.99 and i traded in my 98 honda accord which brought the price down to 4650.21. i think i got a good deal but my problem is the paint chips on the hood. how much is the touch up paint? i dont have alot of money im hiv+ and live on disability income but how can i find these items for cheep? otherwise im happy with the car and i enjoy driving it.
  20. Prius-Forever
    wow that is quite a bit of miles. It's nice that it has the extra options. Did you try to get it lower than the asking?
