Just picked up in 2004
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JIM777, Jan 31, 2016.
  1. JIM777
    JIM777 Member
    162
    24
    Ar
    Hi I just got a 2004, it did have a bad 12V battery which I did replace, still not charging.But First it is making a loud noise under the hood sounds like towards the right side.when I accelerate starts at 18 to 20 miles per hour. Tried sitting still with car in gear and pushing accelerator can not get it to make the noise that way, without the wheels rotating. Any help on any or all of these problems would be greatly appreciated.
    Thank you.
    Have a great day. Jim
  2. 48mpg
    48mpg Member
    193
    47
    florida
    I
    how do you know the 12 volt isn't charging?
    if your looking at the display screen that's for the main battery pack..
    theres not much on the right side to make noise, the power inverter and cvt are on the left (drivers side)
    go to auto zone and get the error codes from the computer
  3. JIM777
    JIM777 Member
    162
    24
    Ar
    12 volt battery charging seems fine its the HV battery display not charging well. mostly no bars at the most missing two bars. Also noise is coming fromfront not positive which side.also no check engine lights are on will there be still codes for the scanner to read?
    Thanks
    also I should say this Has 275000 miles on it.
    #3 JIM777, Jan 31, 2016
  4. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I didn't quite understand the description of the HV charge display. It isn't the car's goal to charge the battery to the top of the range. It's normal for the charge level to stay close to the middle most of the time, but it will go to the top after descending a significant hill and fall to the bottom after a significant ascent.
    If you can record audio/video of the sound you are experiencing, that would be helpful.
  5. JIM777
    JIM777 Member
    162
    24
    Ar
    Not very familiar with these breeds thank you.
    I tried to get the noise to happen with the front off the ground and it will not happen then even up to 60 mph.
    is it possible to make that noise if it has a bad motor mount. How would you check motor mounts on this vehicle? Thanks
  6. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    Could be a bad wheel bearing...
  7. 48mpg
    48mpg Member
    193
    47
    florida
    I
    sounds like the battery pack is bad from the age and miles or the with the grinding noise it could be the transmission and the battery isn't recharging...hope you didn't pay a lot, Id sell it as fast as possible..I have a good running 04 and cant get $3500 or an offer close too it. good luck
  8. JIM777
    JIM777 Member
    162
    24
    Ar
    As mentioned has 275000 miles how would you know if the transaxle is bad?
  9. Patrick Wong
    18,210
    6,511
    What does "right side" mean? Driver side or passenger side?
    So what does this mean? You raised the front of the car on jack stands and with the front wheels hanging down, depressed the accelerator pedal until the speedometer read 60 mph? If so, that is not helping the longevity of the constant velocity joints.
    I doubt that motor mounts are the problem.
    That is likely since you said that the noise occurs only when the drivetrain is under load. It would help if you describe the nature of the noise: is it a rattle, a squeak, a vibration, or ???
  10. JIM777
    JIM777 Member
    162
    24
    Ar
    sounds like A spinning noise maker. or exhaust leak popping but it only happens when accelerator is pressed firmly.previous owner said it let him sit on the highway and he had to have it towed.believe that was because the 12 Volt battery was definitely bad.I do have a video of the sound but not sure how to share it.
  11. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I think the most common way to share videos here is to post it to Youtube and then link to it.
  12. JIM777
    JIM777 Member
    162
    24
    Ar
    VIDEO
    THANKS
  13. bisco
    52,348
    exhaust leak?
  14. JIM777
    JIM777 Member
    162
    24
    Ar
    [QUOT
    new video by GoPro better quality.
    believe it sounds like an exhaust leak but only does it when accelerating.
  15. ExMachina08
    ExMachina08 Junior Member
    72
    27
    United States
    Sounds like and exhaust leak to me. Take a look around the headers and see if you spot and blow by. I would also pull the spark plugs and see if they have ever been changed. I've had older vehicles that would idle fine, but would not fire under heavy load so all you would hear was compression. Is the engine throwing any error codes? Most auto parts stores (napa, oreilly, autozone) will read engine codes for free.
  16. JIM777
    JIM777 Member
    162
    24
    Ar
    no dash lights are lit.is it possible to still have the codes in the computer?
    Thanks
  17. ExMachina08
    72
    27
    United States
    Possible, but unlikely. My money would be on a very mild exhaust leak. Not enough to trip the O2 sensor, but enough to be loud under heavy load. Follow the exhaust all the way from the headers to the muffler and see if you can spot it. Or on a cold morning start it up and see if you can see any exhaust steam coming from somewhere other than the end of the tailpipe.
    tanglefoot likes this.
  18. JIM777
    JIM777 Member
    162
    24
    Ar
    just wanted to close out with the answer.
    Thanks to all I did find the converter was totally clogged parently blowing out around exhaust donut.
    ExMachina08 and tanglefoot like this.
