Just Replaced 12V battery- strange smell
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MaryEllen1102, Jan 6, 2018.
  1. MaryEllen1102
    MaryEllen1102 Junior Member
    santa cruz, ca
    After ongoing issues where my prius needed to be jumped often and then would run okay, last week it wouldn't be jumped and i had to wait for the weekend to replace. I tried to jump yesterday and it worked for a minute, but then emitted an AWFUL smell. I got an instant headache. Not rotten eggs or anything, more chemically.
    Turned it off and decided it was replacement time. We are strapped for cash which is why i've been jumping it and crossing my fingers (i work 5 miles from home). Today I bit the bullet and got an optima yellow top battery and replaced it myself. I used suggested youtube videos and all went well (minus it taking almost 2 hours and some issues dropping the bolts a few times in small quarters). The lights came on as I was finishing the install, and then it started normally once I went to the front. But 5 minutes later, similar smell. Needless to say I'm feeling a bit worried.
    Any ideas about what this could be or mean?
    49,387
    welcome!
    where is the smell emanating from?
  3. MaryEllen1102
    santa cruz, ca
    I'm not sure. I replaced it in the garage and all of the doors were open. I took out battery cover and trunk cover, smelled around. Not there. Was worried it was maybe the vent thing, as it gave me a bit of sticking trouble putting it back in. The hood was closed, so not from there either.
    49,387
    could it have been leftover from the old battery? maybe hydrogen sulfide, or whatever batteries produce.
  5. Patrick Wong
    18,200
    6,472
    When was the last time that you inspected the cabin air filter? Maybe you have a dead mouse somewhere...
  6. uart
    uart Senior Member
    4,215
    1,200
    Australia
    It could also be the traction battery vent tubes (the ones attached to the cells right inside the battery pack). Apparently they sometimes soften and degrade. I've never experienced it myself, only a minority of owners have the problem, but those that do say that it smells really awful.
    Mendel Leisk and Raytheeagle like this.
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Let's hope.
    And that it is not the smell of electrical parts burning........caused by crossing the leads the last time it was jumped. :eek:
  8. ChapmanF
    15,464
    The natural smells from a lead-acid battery can be like eggs, as you mentioned, or a bit like a salad (it is acidic, after all, if sulfuric rather than acetic). A more 'chemical' smell reminds me more of the smell of wire insulation when wiring overheats. A pretty familiar melty-plastic smell.
    You could get a geeky friend to melt some wire insulation for you, and see if the smell is like that. It might not be exactly the same, unless you can get a hunk of the same kind of wire Toyota uses to try with.
    From the story that you had the smell before changing the battery, didn't notice it while doing the swap (no power), then noticed it again 5 minutes after power restored, I could be talked into an electrical fault somewhere in your car, which could also be what was draining the old battery again and again in the first place. That would be likely to get worse over time, which you don't want. You might see if you have a friend with a mighty nose who can help you better narrow it down to a place in the car.
    -Chap
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Are you the original owner? if not, you can never be sure what was done on the car before you owned it.
    I agree with Chapman, electrical, something getting hot. I like Patrick’s suggestion also.
  10. ChapmanF
    15,464
    If you keep noticing the smell, finding the battery drained, or both, there are "battery saver" switches like this one that you can use at one of the battery posts.
    It is only a stopgap until you can locate the fault and fix it, but allows you to twist a knob and completely disconnect the battery, preventing it from draining, and not sending more power to the faulted area, especially when the car is unattended. It will cut power completely off, meaning you lose your radio stations, etc., and will need the mechanical key to open the car. You might also consider not parking close to the house, until the problem is fixed.
    It doesn't matter which battery post you put one of these on; they are usually shown on the + post, but they're also usually uninsulated, which would make me prefer to put it on the − post. Works the same either way.
    -Chap
