Just rolled into 10,000 this morning...
Discussion in 'Prius c Technical Discussion' started by Mikey The Mailman, Apr 19, 2013.
  1. Mikey The Mailman
    Mikey The Mailman Delivering snail mail for you ;-)
    96
    Sacramento area, CA
    In my "B" ODO which shows since I purchased at 6 mile mark. I just rolled to 10,000 miles and I noticed it reset itself to "0" BUT it is keeping my MPG from the beginning...Is it because there's no room for 5 digit odo on either "A" or "B" odos?
  2. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Hi Mikey The Mailman,
    I also use Trip meter B to track lifetime FE. It too rolled over at 9999.9 km. I 've not noticed any changes in the lifetime FE but it could be there is only 1 data point, need more data at 20k, 30k, or more.
    Looking at my "Drive Information" screen, the Avg. Speed and Driving Time do suggest the Trip B keep track of more than 9999.9 km.
    http://priuschat.com/attachments/16042013680-jpg.50121/?temp_hash=7cf521a9815b19e1ab131206fe017d34
    Distance = Speed * Time
    = 40 * (344 + 23 / 60)
    = 13,775 km
    However, the EV percentage is wrong. It seems to use 9999.9 km:
    EV % = Distance in EV / Total Distance * 100
    84 = 8417.8 / Total Distance * 100
    Total Distance = 10,021 km
    At the rate I'm going, it should reach 100% EV when it is around 17k km. This is definitely a bug.
    I use Trip meter A for my tank FE and the EV % is correct. Since I reset at every refuel, the distance will never cross 9999.9 km.
    Vincent
    Mikey The Mailman likes this.
  3. Mikey The Mailman
    96
    Sacramento area, CA
    Thanks Vincent! I will check that first thing tomorrow morning to make sure "Drive Information" screen shows "B" as going past 10,000 miles
  4. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    That's a bummer that it reset itself.
