Just spotted this in AliExpress. Anyone tried?
Discussion in 'Gen 2 Prius Audio and Electronics' started by mathewjg, Oct 26, 2020.
  1. SFO
    SFO Senior Member
    4,343
    3,908
    Northern California
    kenoarto likes this.
  2. bobodaclown
    bobodaclown Member
    214
    71
    Not that unit specifically. I've installed a double din unit in my 09 Prius. PX5 unit. I'm happy with it. Need a75 ohm resistor. Get the wire kit from sonic or crutch field. Steering wheel controls work.
    SM-T700 ?
  3. Moving Right Along
    Moving Right Along Active Member
    590
    482
    I wouldn’t trust anything I found on AliExpress, personally
    jimontheocean likes this.
  4. alftoy
    alftoy Active Member
    371
    168
    Saskatchewan, Canada
    SFO likes this.
  5. ebxgsxr
    ebxgsxr New Member
    Maryland
    coming from a Lexus forum, a lot of the guys bought the Android replacement from that site. they have not had any issues.
  6. TomasEU
    TomasEU New Member
    Rotterdam
    Technology
    I am about to instal this COHO radio..
    I do have a question, may I drive my Prius without ANY radio in the dashboard?
    As I am not sure if I will be done in one evening and have to go in the morning to work..
  7. TomasEU
    TomasEU New Member
    Rotterdam
    Technology
    So I did install it sucessfully :D .. see pictures below:
    What do I like is that everything works as they said (didn't tested SIM card yet).
    1. Did have a problem with a resistor (68 Ohm) as it should be inserted in pins but the same connector is for steering wheel controls, so I adjusted cables before the connector.
    2. Top of radio is not perfect aligned with the bottom of MFD, it is a bit outside, this is my fault, as I didn't want to spend more time fitting it perfectly, will do that later. Maybe it is not possible as clips were not fully inside (not cliped), will adjust this later. Those yellow clips on connectors at back of the new radio were missing - I reused clips from the original radio. I hope it wil not fall down or something as there are also clips from boths sides where wentilation is and on bottom of new radio where dummy plastic sit.
    3. For now I didn't connect a reverse camera, already have one (works from MFD)
    4. Bottom dummy plastic was very hard to fit in.
    5. Original AUX in the middle console (between seats) does not work, anybody knows what cable it is in the connector ? I want to reconnect it back.
    Steering wheel controls can be programed what I want inside Android radio - is not automatic (didn't know that). Original navigation in MFD works, airco works, consumption works. What is not working is audio in MFD (because was removed, it only say that is OFF). Startup is super fast (for now).
  8. Kiwibird
    Kiwibird Junior Member
    50
    Sydney
    i-Tech
    Great work, but how did u fix the resistor problem? I connected a Toyota radio from corolla 2005 but AC and energy no show... I connected the 68 resistor to the 9 and 10 wires white and pink but nothing changed... Still AC and energy not working on MFD...
  9. Kiwibird
    50
    Sydney
    i-Tech
    Nice unit but losing the tray underneath the radio is not an option for me, where I put my mobile phone...
  10. TomasEU
    TomasEU New Member
    Rotterdam
    Technology
    Kiwibird did you try:
    1. radio without the resistor?
    2. resistor only without radio?
    3. radio and resistor together < to this you already know is not working
    From your picture to me looks OK, if it is not working than I dont know what is problem. Try 1. and 2.
    Until now I had my phone in the holder (on ventilation grill about P button) or in middle console conected to AUX in the middle console. From now I will keep my phone in my pocket, everything is on the radio, just need to set up an automatic connection (or wifi sharing) and I am done.
    Maybe I will to DYI some shelf under that console, but that must be with wireless charging and USB's from the radio.
  11. Kiwibird
    50
    Sydney
    i-Tech
    Yeh of course I tried all that, no luck.
    I read on another post something needs to be grounded, post wasn't so clear.
  12. TomasEU
    TomasEU New Member
    Rotterdam
    Technology
    when you disconnect connectors ( all of them) and add resistor than airco and consumption MUST work,
    The difference is maybe that you connecting those two pins in the radio.. With the radio I got they are not connect only resistor.
    I would check connection resistor-cables + measure it is really 68Ohm
    I cant help you more :( I am sorry
    #14 TomasEU, May 15, 2021
Loading...
