Just to be clear with PCS (Disabling)
Discussion in 'Prime Main Forum (2017-2022)' started by EyePrime, Feb 6, 2019.
  1. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    I have been looking at other threads and I keep seeing people think that its impossible to disable PCS and just leave it on In carwashes when It's rather easy.
    I Also don't think that its good to just leave it on in a carwash beacause what if your car just stops and you get rear-ended. Your bumper might crack or theirs.
    All you do Is go to setting on the MID and scroll down until you see the PCS and tss-p area and disable it.
    It has a yellow light on your dash notifying you it's off so you don't forget to turn it back on
    Tideland Prius likes this.
  2. EyePrime
    268
    115
    2018 Prius Prime
  3. schja01
    schja01 Senior Member
    1,842
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    There is a recall campaign that addresses PCS and car washes.
    I just reprogrammed my car to turn PCS off when in Neutral. Easy Peazy.
    benagi likes this.
  4. CharlesH
    2,797
    1,165
    Roseville, CA
    Note in the excerpt from the User Manual that turning PCS off is not "sticky". I will be ON the next time you start the car.
