[ KB ] How Do I get my Prius to idle for Emissions Testing
Discussion in 'Knowledge Base Articles Discussion' started by efusco, Dec 13, 2004.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Category: FAQs
    Type: FAQs
    Article Name: How Do I get my Prius to idle for Emissions Testing
    Author: efusco
    Description: "Easter Egg" to get the ICE to maintain idle
    >>Read Full Article
  2. lgeisz
    lgeisz Junior Member
    83
    Sun City AZ
    Re: [ KB ] How Do I get my Prius to idle for Emissions Testi
    I was under the impression that with the onboard computers that you would not have to idle you vehicle for the test (the last test I had on my 01 nissan they just plugged into the OBC and the info was downloaded).
  3. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    If that doesn't work turn the heat all the way up and turn on the front defroster. That should make the car stay on. I beleive I read somewhere to do this for valets so they don't think the car has stalled, or forget to shut it off when they park it.
  4. DaveG
    DaveG Member
    806
    Vancouver, BC
    Hmph...
    Now what we need is "how to convince government that the Prius doesn't need to be tested in the first place..."
    Dave
  5. 8AA
    8AA Active Member
    550
    62
    Maryland
    Has anyone measured the ICE RPMs if the car is put in Park (in the READY mode) and then you press on the accelerator pedal (maybe half way to the floor)? Is it 1500, 2200, or something else? Also, what are the RPMs if you press the pedal further and the ICE changes to a higher speed?
  6. naterprius
    naterprius Senior Member
    1,843
    The Prius is exempt from emissions testing in Colorado. This saves me $1 a month! ($25 every two years for testing otherwise).
    Nate
  7. jtmhog
    jtmhog Member
    151
    In Northern Virginia, cars are tested at idle and at 35 mph. We have clogged roads here and garbage coming out of the Congress. VA believes in more interstates but, MD doesn't--gridlock!!
  8. 8AA
    8AA Active Member
    550
    62
    Maryland
    <div class='quotetop'>QUOTE(jtmhog\";p=\"104212)</div>
    Actually Maryland supports a beltway bypass, but wants to build it on the east side of DC. Virginia on the other hand wants to build it on the west side of DC. Until they come to a consensus, nothing will be built.
  9. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(8AA\";p=\"104138)</div>
    I believe it is about 1000-1200 if I remember right. Not sure tho,but will check on next one I see.
  10. twdusa
    twdusa New Member
    53
    Eastern North Carolina
    How do you get the car to idle for the test?
    To get the Prius to maintain a steady idle
    (such as for emission testing) follow this procedure:
    The following must be done within 60 seconds:
    1)Ignition on (not READY mode)
    2)Vehicle in Park
    3)Step on accelerator pedal twice
    4)Place vehicle in Neutral
    5)Step on accelerator pedal twice
    6)Place vehicle in Park
    7)Step on accelerator pedal twice
    8)Place car in READY mode.....ICE WILL RUN continuously (see rpms below)
    A warning icon on the MFD will be displayed.
    With less than 60% throttle applied.....idle is 1500 RPM (approx)
    With more than 60% throttle applied.....idle is 2250 RPM (approx)
  11. rick57
    rick57 Member
    572
    Circleville, Ohio
    As per the KB and repair manual, you are right twdusa. What I was thinking about was base idle. It is set at 1000 RPM's with no depression of the accelerator in Inspection Mode. Accel applied under 60% is 1500 RPM's for all Prius' but over 60% is different. The 1st gen is 2250 RPM's and the 2nd gen is 2500 RPM's. How you get to the Inspection Mode is the same for all years.
  12. 8AA
    8AA Active Member
    550
    62
    Maryland
    Thanks for the information Rick.
  13. Anonymous
    Anonymous Guest
    Prius Exempt From Virginia Emissions Testing
    The Prius is exempt from emissions testing in Virginia. See
    http://leg1.state.va.us/cgi-bin/legp504.ex...0+cod+46.2-1178
    subsection B1.
