Keep 2013 prius with 80,000 miles?
Discussion in 'Gen 3 Prius Main Forum' started by rosencrantz, Jun 16, 2018.
  1. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Hello folks,
    1st time posting. I've 'lurked' on this site for some time. Here's my question - I'm wondering what the odds might be that my 2013 Prius will be an oil burner before reaching 150K miles? Drinking oil, at least for me, would be 1qt/1000 miles or worse. So far, my 2013 does not consume any oil - but, I've read about quite a few prii on the carscomplaint website that do. A local repair shop that specializes in Toyota work indicated he's aware of the Gen3 Prius's tendency to consume oil. I've changed the oil on this car at 10K OCI with 0W-20.
    I normally hold onto my Toyotas 10 years or 150K miles. However, this issue has me concerned. I'm a believer in 'truth in advertising' - sooo, if I were to replace it now, I could, in good conscience, say it's running fine. We LOVE the mileage in this car. If we were to replace it, it's likely we'd choose another hybrid of some type.
    Does anyone have any data or suspicions as to what percentage of Gen3 prii end up consuming oil? I realize folks likely won't have an exact answer - I'm more interested in whether there's any consensus (from Priuschat's experts) on 10% or as high as 25% of cars have this problem before achieving 150K miles.
    Thanks much, Rosencrantz
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    766
    302
    Maine
    My 2011 needed an oil pan gasket replacement at 5k miles. Which was covered under warranty. The dealership wanted to do it again at 40k miles, but it is an expensive repair. So I shifted to using an outside repair shop to do all my maintenance. The non-toyota mechanics say that it is one of the cleaner undercarriages of any make car that they see.
    Now I am up to 170k miles, I have the oil changed [synthetic only] every 10k miles, and it has never been more than a half quart low. If it is 'burning' at all it is burning less than half-quart every 10k miles.
    bisco and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Our 2010 with 180 k miles consumes a quart of oil every 5000 miles or so.
    The best thing you can do is check your dipstick regularly ;).
    I check ours every Saturday and top up as needed. A quick 5 minute activity that can save a later headache:).
    Good luck (y).
    51,154
    read the threads on egr and intake manifold cleaning around 100k. i'd probably keep it unless you're itching for something new.
    rosencrantz and Raytheeagle like this.
  5. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    The best cure for that itch is remembering that no car payments is a great feeling(y).
    Grit and bisco like this.
  6. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    In your shoes I'd bump to 5k OCI if you want to drive it to 150000 mi or 10 years. By then your rainy day fund will be large enough to buy another in cash when oil consumption because unmanageable or insomniac.
  7. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Thanks - I have read a few of those threads and, based on info there, I was thinking I'd get the EGR circuit and intake manifold cleaned at the 120K mile major service. Hopefully, I won't have a problem with clogging before that point. I'm also considering the idea of an oil catch can - although, at 120K miles, the car would be near the end of its service life (to me).
  8. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Good point. I've thought about increasing the OCI. The last time the prius was in the shop for an oil change, I specifically asked the mechanic about a heavier weight oil. I've read about success with that on this site. The mechanic didn't seem too keen on the heavier oil.
    Grit likes this.
  9. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Actually, as a result of reading Priuschat, I check the dipstick a couple times a week! That thing is hard to read when the oil is fresh.
    Grit and Raytheeagle like this.
  10. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    I'm at 107.500 miles and have no oil consumption.
    James Powers and orenji like this.
  11. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Check mine every other day. On a side note, not sure how people check their when gassing up.
    Raytheeagle likes this.
  12. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    107.5 miles shouldn't have any oil consumption yet.
  13. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Personally wanted to move onto heavier oil just for preemptive strike but decided not to, but don't fix what ain't broke.
  14. PokerMunkee
    PokerMunkee Junior Member
    34
    23
    Denver, CO
    Drive it into the ground! Have you checked out the '18 Prius? OMG, don't do it, otherwise you'll want it! Ha.
    These 3rd gens should go to 200k with very little repair. Just basic maintenance. That's the plan with mine, just bought it with 88k miles. Not even broken in! When the battery starts to fail, that's the $1k-2k repair question that will make you consider upgrading.
    James Powers likes this.
  15. bisco
    51,154
    better read the oil burning/egr/intake manifold/head gasket threads.
  16. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    I have 135,000 miles on my 2010 and have no oil burning issues. I have stuck to the original 5K OCI and used only Toyota 0W20 oil and filters.
  17. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    Just did a quick comparison of value of 2013 Prius Two with 80K miles on KBB. The average private sale price for "Excellent" condition is ~$11K whereas for "Fair" condition (one with some mechanical problem) is ~$9K. That's only ~$2K differences in value. If you can make another 1 year without any problem, I think you are already ahead by keeping the car. And even if it develops symptom of burning oil within a year, your cost is at most $2K. If financial aspect is the only concern, then I would keep it. If you just want to upgrade and get into a new car, then it might make sense to trade it in now to get ~$2 more for it.
    #17 Salamander_King, Jun 18, 2018
  18. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Haven't checked out the Prius..... but, I have checked out the new hybrid Camry - I like it. The Prius has long been paid off and, as raytheeagle mentions, no car payments are nice.
  19. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Interesting analysis - thanks. We really like our Prius. Of the vehicles we own, we drive the Prius (by far) the most.
  20. PokerMunkee
    34
    23
    Denver, CO
