Keep getting safety alert beep on 2012 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by irfanlai, Oct 28, 2022.
  1. irfanlai
    irfanlai Junior Member
    33
    Dallas Texas
    I have a 2012 Prius with 100K miles. New tires were installed last week.
    I have been getting a beep sound with the triangle exclamation which is the safety alert. I get this beep when I am taking a turn.
    What does that mean? I am hoping not a big expense.
  2. ChapmanF
    18,556
    What do you see on the oil dipstick?
  3. irfanlai
    33
    Dallas Texas
    I have not checked that but now if you have asked then I will check and post my findings
  4. irfanlai
    33
    Dallas Texas
    I just checked and looks like there is no oil. I wiped it with tissue and inserted it again. Next, when I wipe on a tissue, there is a little bit of oil at the bottom of the stick.
    Oh man...this is crazy
  5. irfanlai
    33
    Dallas Texas
    How did my car pass the inspection which was last week? Also there should have been engine oil light which I don't see it?
    How is that possible with so less oil.
  6. fuzzy1
    10,603
    What kind of inspection? A state safety inspection doesn't check this sort of thing. A maintenance inspection or oil change should have caught it, or may be been done improperly.
    You saw it, the warning for low oil pressure. Like most cars, there is no low oil level warning. The turn likely sloshed the oil away from the oil pump intake briefly, causing the momentary low pressure warning.
    When was the last time you, or anyone else, checked the oil level? Hopefully within the last 1000-ish miles.
    This is supposed to be a regular check item for virtually all motor vehicles. Most drivers don't check anywhere near this often, and get by just fine ... until they don't.
    #6 fuzzy1, Oct 28, 2022
    CR94 likes this.
  7. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Open the back hatch and slam it shut. The take those turns again
  8. fuzzy1
    10,603
    ^ I think that is the solution for a different cryptic message, something like "Key Not Detected".
  9. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Hate to be the bad news bear but if you don’t fill it up, big expense will be trick or treating at your door soon.
