Keeping car level while changing oil?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Frank O, Nov 15, 2014.
  1. Frank O
    Frank O Junior Member
    35
    I was watching a YouTube video of a guy changing the oil on a Prius, and noticed he drove the front wheels onto ramp devices so that the car was not level. I haven't gotten under my Prius and opened up the shroud yet to check it out, but it appears from videos as though the drain plug is at the front of the sump pan. Does that mean you'd get incomplete drainage if the front of the car is tilted up? Does anybody think it's important to keep the car level while changing oil?
  2. Mike500
    Mike500 Senior Member
    2,593
    764
    The drain plug is on the back side of the oil pan.
    The car needs only to be level when topping off the oil level.
    Frank O and TsKarma like this.
  3. Frank O
    35
    Thanks, I must have made the wrong assumption about the camera angle.
    Mike500 likes this.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    In fact you will get more out when on the ramps plus it makes it much easier.
  5. Mendel Leisk
    38,874
    The one time you need the car level during a fluid change is with transaxle fluid, when filling with the car raised. But yeah, for oil change, the pros would likely have the car level on a hoist, but having it tilting back is fine, might even drain better.
  6. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    Yea the only part that will make a difference will be when you top off the oil, you should get car off ramps for this part.
