Keeping the car in full electric mode
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 100 mph, Mar 7, 2014.
  1. 100 mph
    100 mph Junior Member
    40
    One of my pet peeves about the Prius Plug-in is that the car won't stay in full electric mode under hard acceleration. Has anyone heard about any mods to keep the car in pure electric propulsion?
  2. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :)"Ain't" going to happen. Steady as she goes. Aye, Aye, Captain. For me hard acceleration would be a rare exception and I would want the ICE to assist.
    retired4999 and JimboPalmer like this.
  3. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    PHV is Plug-In Hybrid Vehicle. Expect Hybrid behavior.
  4. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Our European version of the PiP has EV-City instead of PWR as the third mode. Makes it even harder to turn the ICE on through acceleration, but at the cost of very sluggish acceleration over 35mph
  5. markabele
    5,084
    1,782
    Nebraska
    As others have said, you bought a hybrid, expect the engine to turn on sometimes.
    Also, I hope you are leasing because you are probably shortening the life of the battery if you are routinely accelerating hard in EV.
  6. bisco
    49,694
    i suppose you could tinker around with the wiring to achieve this, at the expense of the battery. but properly programmed, it might not hurt it too much. judging by your moniker tho...
  7. jfschultz
    jfschultz Active Member
    635
    114
    Germantown, TN
    2013 Prius Plug-in
    Given his moniker, he should get a Lexus GS450H or a Testla.
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    You have 38 kW power from the battery.
  9. Ian Mayo
    Ian Mayo Junior Member
    32
    I suppose you could put a wooden block under the accelerator pedal.
    I had had hire cars during your 55 MPH national limit days with a metal bracket welded to the pedal to limit its movement preventing high acceleration and speed.
  10. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    It's mostly about the size of the battery. As usbseawolf2000 noted, Toyota has decided they can only draw a peak of 38 kW (about 50 hp) from the 4.4 kWh battery so the rest of any power demand needs to come from the gas engine.
    A Chevy Volt can draw up to 111 kW (149 hp) from its 16-16.5 kWh battery which is about 3.7 times larger in capacity so it never has to start the gas engine for power demand reasons.
    The Ford Energi models are in the middle and, from what I can recall, can draw approximately 67 kW (about 90 hp) from their 7.6 kWh pack so the Energi can support an "EV now" mode button that keeps the engine off under almost all circumstances but it causes the car to drive like a gutless mid-1970's econobox (Ford Pinto) at freeway speeds.
  11. bisco
    49,694
    so, no mods available?
  12. fuzzy1
    10,254
    (1) Unbolt license plates;
    (2) Remove PiP;
    (3) Exchange in a Leaf, or Volt, or Tesla, or ...
    (4) Re-bolt license plates.
    ckam1989 and Godzuki like this.
  13. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
  14. bisco
    49,694
    golf cart mode.
  15. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    Many of us wouldn't mine the PIP going into HV mode on accidental acceleration, as long as it wouldn't stay in HV while it Warms Up. I'd like a button to Skip Warmup and go back to EV mode.
    Chazz8 likes this.
  16. markabele
    5,084
    1,782
    Nebraska
    Please read in many other threads about engine knocking and rattling if you don't let it do its full cycle.
  17. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    I got to say all this tinkering, buy a Lexus GS350 or a Lexus GS450h and get all the acceleration you would ever want and more luxury by far than the PIP. If you buy a Prius Plugin then you want economy and low carbon footprint. The two goals are vastly different!
  18. bisco
    49,694
    i think the o/p is hip deep into his dashboard right now.:p
  19. Zythryn
    Zythryn Senior Member
    6,284
    4,283
    Perhaps GM had it right, in not using the term hybrid, after all?
  20. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    Mod is available for the driver with adjustment of expectation.
    Use EV mode for city driving and use HV for highway. Make the best use of both the battery and gas.
    I did exactly that and my first year averaged 132 MPGe on electric miles and 56 MPG on gas. Remember, these are fuel economy, not gas consumption.
    They used to mean the same but not anymore in vehicles that use two fuels. My gas consumption was 100 MPG (electric miles added and ignored electricity usage).
    I had instances where gas engine came on due to acceleration or cold temp or cabin heater. What matters is the end result. Both power sources are set up to boost each other's efficiency.
    My first year average included weekday 2 miles trips (with 5-6 stop lights). Some weekends drives had about 100 miles trip. Also 1,000+ miles trip to Canada.
    A regular Prius wouldn't get 56 MPG with that many short trips (engine warmup penalty). Nor would I be able to average 132 MPGe with Leaf (highway miles and winter drivings) or make that Canada trip.
    The end result for me was the best of both EV and HV worlds without having to buy/insure two cars. For me, focusing on a specific situation where one of the fuel was used when instead of the other, just seem silly and missing the big picture. Again, understand the design, mod the expectation and the result should not dissapointed.
    Lourun likes this.
