Keeping the main battery powered while changing the 12 volt? Need help
Discussion in 'Gen 3 Prius Main Forum' started by J burnstick, Apr 15, 2019.
  1. J burnstick
    J burnstick Junior Member
    So my 12 volt battery is on its last limb. Got a brand new 12 volt from Toyota OEM. However, in my owner's manual it doesn't say anything about keeping power on the main battery while you change the auxiliary battery. However I've heard from people through word-of-mouth that you have to keep the hybrid battery powered with jumper cables to another car or you will lose radio presets. I haven't seen this in the owner's manual...
    49,434
    incorrect.
    the 12v holds the radio presets, window setting etc. it's not that big a deal, but if you want to retain everything, put a jump pack, or another car 12v jump to the front jump point under the hood.
    Uberdriver2710 likes this.
