Key and door lock don't match.
Discussion in 'Gen 3 Prius Main Forum' started by Paul2002, Mar 4, 2021.
  1. Paul2002
    Paul2002 Junior Member
    Central PA
    The previous owner our 2010 Prius 2 put on a new driver's door due to a collision. Our little physical keys in the fobs will not open the door. Suggestions please for most economical way to remedy. Thanks, Paul.
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    723
    284
    Maine
    We have two Priuii, so far we have never attempted to unlock/open a door using the physical key. I suggest that you talk to a locksmith.
  3. ChapmanF
    15,859
    As long as you can open the door with a fob, a locksmith can read the number off your lock cylinder and cut you two new key blanks that will fit, in next to no time, probably very little money.
    If you buy a replacement lock cylinder at the dealer, it will come with two already-cut keys that fit, and then you just swap that cylinder into your door, but that's probably more than the locksmith would charge.
  4. Paul2002
    Central PA
    Thanks, do you know if there is a chip of some kind in the little physical keys?
    Also, with the smith need to extract the cylinder to read the number?
    Best
    Paul
  5. ChapmanF
    15,859
    Yes, I do; no, there isn't; and yes, he/she will, which is quite easy, as long as you have a fob that opens the door.
  6. Mendel Leisk
    38,873
    Ask a dealership service department? I’d suspect they could give you an over-the-phone answer/quote without credit card extraction. But be on your toes lol.
