Key battery low ?
Discussion in 'Gen 4 Prius Main Forum' started by Chris Wolfgram, Nov 8, 2021.
  1. Chris Wolfgram
    Chris Wolfgram Active Member
    412
    167
    Sacramento CA
    2019 Prius
    Have this message popping up ?
    I don't even see how to open the darn thing ??? I've been using it for almost 3 years, and never had to replace it ? What type battery does it take, and how do I open the darn thing ?
    Will post a pic, in case their are different ones...
  2. Striker325
    Striker325 Junior Member
    25
    24
    Los Angeles
    Hey the fob is simple to open. Remove the physical key and you will see a notch. Stick the physical key in the notch and wiggle it and the plastic casing will open. If you do not feel comfortable you can also take the fob to your dealership and I'm sure the parts department will assist you.
    In terms of the battery it is a CR2032
    For reference I will attach the battery photo.
    Let me know if you have any other questions.
  3. jdenenberg
    jdenenberg EE Professor
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There is a mechanical key that is attached to the key ring. You need to slide the tab next to the key and pull it out. The case can then be gently pulled apart to gain access to the CR2032 battery.
    JeffD
  4. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Awesome :) Plus, I have about 18 of those batteries at the house :) I think I ordered 20 for $11.99
  5. Reypac24
    Reypac24 Junior Member
    17
    McAllen, Texas
    2020 Prius
    How do you know when key fob battery is running low?
  6. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    I actually had a popup message on my dash display that said "Key Battery Low"
    Surprised me. I've never seen that before.
    pilotgrrl, Ingapone and Reypac24 like this.
  7. Reypac24
    17
    McAllen, Texas
    2020 Prius
    good to know. Thank you.
  8. tucatz
    tucatz Active Member
    501
    416
    Manzanita, Oregon
    Four Touring
    The car will alert you when the battery is low. Replace with CR2032. It’s a good idea to have couple of spares on hand.
    pilotgrrl and Reypac24 like this.
  9. jdenenberg
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Since I have more than a dozen battery operated sensors/remotes that use CR2032s, I always have a supply on hand.
    JeffD
