key detected in vehicle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pamela Francis, Jul 17, 2014.
  1. Pamela Francis
    Pamela Francis Junior Member
    cleveland, ohio
    I got this message today, twice as I was pulling out of the driveway but it went away both times. After the 1st I stopped and pulled the key out of my purse. It came back on a 3rd time and right as I was trying to determine if it was significant enough to pullover when the hood flew up and hit the windshield. The hood was closed and there were no other messages.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    You typically get this message when one of the door switches indicates the door is open while driving. The most common is the Liftback that is not completely closed and you go over a bump.
    The first I have heard with the hood open. I did not know that the hood had a closed position switch.
    It is not a very informative message ! When one of the doors indicates open while driving and then shows closed again, typically with a door not completely closed, the system attempts to re-lock the doors but detects the key in the vehicle. It does not normally want to lock the doors with the key in the vehicle, thus the message.
    This is the same message that you will get if you try to lock the door with the SKS door sensor with the key inside.
  3. ibmoses
    ibmoses Junior Member
    109
    22
    Wow!
    Pics of damage?
    acceleraptor likes this.
  4. Mendel Leisk
    38,727
    The hood must have been ajar and not hooked down by the safety latch. Someone recently popped it open??
  5. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    If the car has the (Toyota VIP) remote engine start installed, remote start won't work if the hood is open. A hood switch is included as part of the remote start installation. I don't think there is a hood switch for cars without the remote start. I can only assume there are hood switches that come with other aftermarket remote start/alarm systems.
    jdcollins5 likes this.
  6. CJ Ossom
    CJ Ossom New Member
    Fremont, California
    This warning came on this morning. Later I checked it's the tailgate that was not close tight. I would say, when any door, including tailgate, or maybe the hood, is at on-and-off status, this warning will come on. For safety, just pull over your Prius, double check if every door is close tight. A year ago, I kind damaged my tailgate when I let it open and rushed back out of my garage... I forgot the tailgate was still open, there was a warning beeeeeeep when I shifted into reverse, but it was too late. The garage door ripped off the two shocks, scratched off the wind spoiler. It costed me a thousand dollars something to fix. But the tailgate somehow was relocated a little. I guess if I don't close it tight, the warning "Key Detected in Vehicle" will comes on and off. Nothing wrong with Prius. The warning makes sense to me. Me and my wife give our Prius a nickname PP. We love this car.
  7. CJ Ossom
    CJ Ossom New Member
    Fremont, California
    Yes, your are perfectly right.
    I would like to post my message replied to Pamela again for the Prius owners happen to have this message. Don't panic.
    jdcollins5 and bisco like this.
  8. David Wilcoxson
    David Wilcoxson New Member
    Phoenix
    I imagine the answer for the Prius is the same as my Lexus. They appear to have the same problem.
    It is due to the hatchback not being firmly seated, even when fully closed.
    Buy*1/4 inch lock washers.* This cost me 48 cents.
    *Open the rear hatch door, and on both sides of the bottom of the door you will see, rubber bumpers sticking out from the door.
    *Look down by the rear bumper where those rubber bumpers hit when the door is*closed.
    * With a Phillips head screwdriver, remove the*rubber washers down near the rear bumper.
    *Place two lock washers under each of the*rubber washers*to help raise them up and screw them back into place.
    That did work for about 3 months. The addendum below shows a better fix.
    Addendum:
    I did have a recurrence of the problem after the above fix, but not as bad. At Home Depot, I obtained #14 1ΒΌ" screws. I ended up putting three 1/4" lock washers underneath. It has again cured the problem. With the 1-1/4" screw, I can always add another washer underneath if it recurs again. Total cost, less than $1 to fix the problem.
