key doesn't work
Discussion in 'Prius c Main Forum' started by Scott p, Nov 7, 2019.
  1. Scott p
    Scott p Junior Member
    South Carolina
    i have a (i assume) standard 4 button key. It no longer opens doors remotely. How do I fix it?
    Thanks
    49,694
    there's a battery inside. the o/m has instructions to access it, or you can find utube videos
    also, the 12v battery can be a culprit
    Leadfoot J. McCoalroller and LnG like this.
  3. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    This is one i watched.
  4. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    Either replace the battery in the remote or check fuse for door locks, even though if it was a fuse, i think more than door locks wouldnt work
    SM-S367VL ?
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    First, where is the spare key remote ?
    If you lose them both...or they both go bad.....and you have push-button keyless start.....getting it running again can be VERY expensive.
    Like $600 maybe.
    It is likely that the battery is just dead in your remote.
    Given that you didn't know that, I suggest that you call around to a few locksmiths and find one that works on keyless car remotes and go there and let them help you.
    IF....you can hear some clicking coming from the doors when you push the buttons on the remote, the electric actuators in the doors could be going bad. Let's hope it is just a battery in the remote.
